76-1560
76-1560
    TENMA
    TENMA - 76-1560 - Crocodile Clip, 22 mm, 20 A, Yellow
76-1560 数据手册
37.5 mm (overall height). 31.0 mm (overall height). 23.0 mm (overall width). 91.0 mm (overall length). 91.0 mm (overall length). 22 mm maxi.. Ø15 mm maxi.. 6 mm (width of the end). The 4 mm banana female connection complies with the 4 mm banana plugs of the worldwide most famous manufacturers. Fichier «Datasheet_TENMA_5004-LM-IEC». 28/11/2016. Indice A. Information in this publication supersedes all earlier versions. Specifications subject to change without notice. © 2016. European Union marking. Current and voltage markings. Dimensions in millimeters. ACCESSIBLE. Able to be touched with a standard test finger or test pin. BASIC INSULATION. Insulation of HAZARDOUS LIVE parts which provides basic protection. CAT II. Measurement or overvoltage category II. For measurement performed on / equipment connected to the building wiring. CAT III. Measurement or overvoltage category III. For measurement performed on / equipment connected to part of a building wiring installation. According to EN / IEC 61010-031:2008. 1000 V CAT II / 1000 V CAT III / 600 V CAT IV, reinforced insulation, 20 A (at +40 °C). CAT IV. Measurement or overvoltage category IV. For measurement performed on / equipment connected to the origin of the electrical supply to a building. CLEARANCE. Shortest distance in air between two conductive parts. These specifications come from the creepage distances, clearances, accessible parts, and solid insulation of the clip. And the considered specifications of the environment are :  pollution degree, 1 or 2 ;  relative humidity, 80 % maximum for temperatures up to 31 °C decreasing linearly to 50 % relative humidity at +40 °C ;  temperature range, +5 °C to +40 °C ; Barrier. Keep behind this  indoor use ; and barrier to operate safely the  altitude, 2000 m maximum. clip while connecting to hazardous live voltages (more than 33 V AC and 70 V DC). According to EN / IEC 60529. IP2X (touchproof) when the jaws are closed. CREEPAGE DISTANCE. Shortest distance along the surface of a solid insulating material between two conductive parts. CTI. Comparative Tracking Index of the insulating material in accordance with IEC 60112. DOUBLE INSULATION. Insulation comprising both BASIC INSULATION and SUPPLEMENTARY INSULATION. EN / IEC 60529. European / international standard regarding the degrees of protection provided by enclosures. EN / IEC 61010-1. European / international standard regarding the safety requirements for electrical equipment for measurement, control, and laboratory use – Part 1: General requirements. EN / IEC 61010-031. European / international standard regarding the safety requirements for electrical equipment for measurement, control and laboratory use – Part 031: Safety requirements for hand-held probe assemblies for electrical measurement and test. "LVD". European Directive 2014/35/EU on the harmonization of the laws of Member States relating to electrical equipment designed for use within certain voltage limits. (Usually called the Low Voltage Directive.) -20 °C mini., +80 °C maxi. (please see above too). MAINS. Low-voltage electricity supply system to which the equipment concerned is designed to be connected for the purpose of powering the equipment.  European Directive "Low Voltage Directive" 2006/95/EC.  International / European standard EN / IEC 61010-031:2008.  European Directive "RoHS" 2011/65/EU.  European REACH regulation n°1907 / 2006.  International / European standard EN / IEC 60529.  Standard NF C 93-440:1986. MAINS CIRCUIT. Circuit which is intended to be directly connected to the MAINS for the purpose of powering the equipment. OVERVOLTAGE CATEGORY. Numeral defining a TRANSIENT OVERVOLTAGE condition. POLLUTION. Addition of foreign matter, solid, liquid or gaseous (ionized gases), that may produce a reduction of dielectric strength or surface resistivity.  "RoHS" compliant, Pb ≤ 4 % in conductor, Pb ≤ 0.1 % in insulator, Hg ≤ 0.1 %, Cr VI ≤ 0.1 %, Cd ≤ 0.01 %, PBB ≤ 0.1 %, and PBDE ≤ 0.1 %.  REACH compliant, no substances from the candidate list of SVHC for authorisation at mass concentrations greater than 0.1 %. Conductors : nickel-coated steel, tinned steel, and brass. Insulators : please contact us. Black Red Yellow Green Blue POLLUTION DEGREE. Numeral indicating the level of POLLUTION that may be present in the environment. POLLUTION DEGREE 1. No POLLUTION or only dry, non-conductive POLLUTION occurs, which has no influence. POLLUTION DEGREE 2. Only non-conductive POLLUTION occurs except that occasionally a temporary conductivity caused by condensation is expected. REINFORCED INSULATION. Insulation which provides protection against electric shock not less than that provided by DOUBLE INSULATION. White "RoHS". European Directive 2011/65/EU on the restriction of the use of certain hazardous substances in electrical and electronic equipment. 0.023 kg. SOLID INSULATION. Insulating materials. Designed and manufactured in France. Year of 1st placing on the market 1995. SUPPLEMENTARY INSULATION. Independent insulation applied in addition to BASIC INSULATION in order to provide protection against electric shock in the event of a failure of BASIC INSULATION. One piece per bag. TRANSIENT OVERVOLTAGE. Short duration overvoltage of a few milliseconds or less, oscillatory or non-oscillatory, usually highly damped. WORKING VOLTAGE. Highest r.m.s. value of the a.c. or d.c. voltage across any particular insulation which can occur when the equipment is supplied at rated voltage. Fichier «Datasheet_TENMA_5004-LM-IEC». 28/11/2016. Indice A. Information in this publication supersedes all earlier versions. Specifications subject to change without notice. © 2016. Dimensions in millimeters.
76-1560 价格&库存
很抱歉,暂时无法提供与“76-1560”相匹配的价格&库存,您可以联系我们找货
