21-10130 UK+EU
21-10130 UK+EU
    TENMA
    21-10130 UK+EU
21-10130 UK+EU 数据手册
TM 2 in 1 SMD Rework Station Features •  •  •  •  •  •  •  •  •  •  •  2 in 1 SMD Soldering Rework Station MCU and PID algorithm controlled temperature Double-window LCD display High flow diaphragm pump for variety of nozzles Dormancy, Automatic shut-off and sleep mode Memory stores up to three air & temperature presets Intelligent cooling system and deferred power-off function Built-in patent auger-type heating core Malfunction alert function Includes Rework Station, 4 Nozzles and power cord Soldering & Rework station, Nozzle, Bracket and Power Cords Technical Specifications Input Voltage 220V AC 50Hz Total Power Air heating: 800W Max, Pump: 40W 900W Max. Temperature Range Soldering Iron: 50W Hot Air Rework Station 100°C to 500°C Soldering Station 200°C to 480°C Temperature Unit °C / °F Convertible Temperature Controlling Stability Static ±2°C Temperature Controlling Accuracy Static ±10°C Celsius 50°C to -50°C Fahrenheit -58°F to 122°F Setting Storage (3 groups) Hot Air Rework Station 200°C, 40% flow; 300°C, 60% flow; 400°C, 80% flow Soldering Station 200°C; 300°C; 400°C Range of Air Volume Hot Air Rework Station 020 - 100 level Calibration Range Dimensions (L × W × H) 245mm × 187mm × 135mm Weight 4.4kg Part Number Table Description Part Number 2 in 1 SMD Soldering Rework Station, 900W, 220V AC, UK/EU Plug 21-10130 UK+EU Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 10/04/18 V1.0
21-10130 UK+EU 价格&库存
很抱歉,暂时无法提供与“21-10130 UK+EU”相匹配的价格&库存,您可以联系我们找货
