72-13540
72-13540
    TENMA
    TENMA - 72-13540 - USB TESTER, 3-9V, 3A, WHITE
72-13540 数据手册
TM USB Tester Features •  •  •  •  Lightweight and Portable Inspects USB Charger & Portable Power Source LCD Backlight High/Low Output Voltage Warning Electrical Specifications Parameter Range Voltage Measurement (DC) 3.0V - 9.0V ±1% Current Measurement (DC) 0.0A - 3.0A ±(1% ± 2 digits) Energy 0 - 9999mAh Memory 10 Sets of Data General Characteristics Colour Weight Dimensions : White : 28g : 84mm × 29mm × 12mm Accessories Blister and Insert Card Part Number Table Description Part Number USB Tester 72-13540 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/09/18 V1.0
72-13540
物料型号为72-13540的TENMA USB测试器具有以下特点:
- 器件简介:轻便便携,可检测USB充电器和便携式电源,配备LCD背光。
- 引脚分配:未提供具体信息。
- 参数特性:电压测量范围为3.0V至9.0V(±1%),电流测量范围为0.0A至3.0A(±1%±2位数字),能量测量范围为0至9999mAh,具有10组数据存储功能。
- 功能详解:用于检测USB充电器和便携式电源,具有高/低输出电压警告功能。
- 应用信息:适用于需要测试USB充电器和便携式电源的场合。
- 封装信息:颜色为白色,重量为28克,尺寸为84mm x 29mm x 12mm。
请注意,此数据表及其内容属于Premier Farnell集团或其授权方,信息仅供参考,不授予任何知识产权许可。
信息如有变更,恕不另行通知。
72-13540 价格&库存
很抱歉,暂时无法提供与“72-13540”相匹配的价格&库存,您可以联系我们找货
