72-13760
72-13760
    TENMA
    TENMA - 72-13760 - STACKING PLUG LEAD RED
72-13760 数据手册
4mm Banana Plug to Plug Stackable Patchcord - 1mm2 PVC TM Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Resistance Cable Contact Material Insulator Material Insulator Colour Temperature :2  50mm/9.9” 500mm/19.7” 1m / 3.3ft 1.5m / 4.9ft 2m / 6.6ft : Stacking 4mm Banana Plug : Stacking 4mm Banana Plug : ≤33VAC/≤70VDC : 20A :2  50mm: 12mΩ 500mm: 15mΩ 1m: 25mΩ 1.5m: 35mΩ 2m: 45mΩ : 1mm2, PVC : Brass and Beryllium Copper, Nickel Plated : Polyamide and Polypropylene : Blue, Yellow, Black, Red and Green : -20°C to 80°C Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Insulator Colour Lead Length Part Number Test Lead, Stacking 4mm Banana Plug to Plug, 1mm2 PVC, 33V AC/70V DC, 20A Blue 250mm 72-13764 Yellow 250mm 72-13766 Black 250mm 72-13768 Red 250mm 72-13770 Green 250mm 72-13772 Blue 500mm 72-13774 Yellow 500mm 72-13776 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0 4mm Banana Plug to Plug Stackable Patchcord - 1mm2 PVC Description Test Lead, Stacking 4mm Banana Plug to Plug, 33V AC/70V DC, 20A 1mm2 TM Insulator Colour Lead Length Part Number Black 500mm 72-13778 Red 500mm 72-13780 Green 500mm 72-13782 Blue 1m 72-13734 Yellow 1m 72-13736 Black 1m 72-13738 Red 1m 72-13740 Green 1m 72-13742 Blue 1.5m 72-13744 Yellow 1.5m 72-13746 Black 1.5m 72-13748 Red 1.5m 72-13750 Green 1.5m 72-13752 PVC, Blue 2m 72-13754 Yellow 2m 72-13756 Black 2m 72-13758 Red 2m 72-13760 Green 2m 72-13762 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-13760 价格&库存
很抱歉,暂时无法提供与“72-13760”相匹配的价格&库存,您可以联系我们找货
