72-14082
72-14082
    TENMA
    TENMA - 72-14082 - Test Lead, 4mm Stackable Banana Plug, Shrouded, 4mm Stackable Banana Plug, Shroud...
72-14082 数据手册
Stacking 4mm Banana Plug to Plug Safety Patchcord – 2.5mm2 PVC TM Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Resistance Cable Contact Material Insulator Material Insulator Colour Temperature :5  00mm/19.7″ 1m / 3.3ft : Stacking 4mm Shrouded Banana Plug : Stacking 4mm Shrouded Banana Plug : CAT II 1000V : 36A :5  00mm: 15mΩ 1m: 20mΩ : 2.5mm2, PVC : Brass and Beryllium Copper, Nickel Plated : Polypropylene : White, Blue, Brown, Grey, Yellow, Black, Red, Green, Yellow/Green and Purple : -20°C to 80°C Applications General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Insulator Colour Part Number 72-14096 Blue 72-14098 Brown 72-14100 Grey Test Lead, Stacking 4mm Shrouded Banana Plug to Plug, 2.5mm2 PVC, 1000V, 36A Lead Length White Yellow 500mm 72-14102 72-14104 Black 72-14106 Red 72-14108 Green 72-14112 Blue 72-14078 Brown 1m 72-14080 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 24/10/18 V1.0 Stacking 4mm Banana Plug to Plug Safety Patchcord – 2.5mm2 PVC Description Insulator Colour Test Lead, Stacking 4mm Shrouded Banana Plug to Plug, 2.5mm2 PVC, 1000V, 36A TM Lead Length Part Number Grey 72-14082 Yellow 72-14084 Yellow/Green Black 72-14086 1m 72-14088 Red 72-14090 Green 72-14092 Purple 72-14094 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 24/10/18 V1.0
72-14082 价格&库存
很抱歉,暂时无法提供与“72-14082”相匹配的价格&库存,您可以联系我们找货
