72-14198
72-14198
    TENMA
    TENMA - 72-14198 - Banana Test Connector, Jack, Panel Mount, 36 A, 1 kV, Gold Plated Contacts, Yello...
72-14198 数据手册
4mm Golded Banana Jack w/ 14.5mm Round Nut - Pin Connection TM Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Resistor Contact Material Pin Dimension Connector Colour : 4mm Banana Jack : Panel Mount : Pin : CAT III 1000V : 36A : < 12mΩ : Gold Nickel Plating : Ø1.9mm x 11mm :W  hite, Blue, Brown, Grey, Yellow, Black, Red, Green and Purple Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description 4mm Golded Banana Jack w/ 14.5mm Round Nut, Pin Connection, Panel, 1000V, 36A Insulator Colour Part Number White 72-14190 Blue 72-14192 Brown 72-14194 Grey 72-14196 Yellow 72-14198 Black 72-14204 Red 72-14206 Green 72-14208 Purple 72-14210 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-14198 价格&库存
很抱歉,暂时无法提供与“72-14198”相匹配的价格&库存,您可以联系我们找货
