72-9480
72-9480
    TENMA
    TENMA - 72-9480 - Clamp Meter, Average, 600 V DC, 28 mm Jaw Opening Max.
72-9480 数据手册
TM 400-600A Digital Clamp Meters 72-7226 72-7224 72-9480 Features •  •  •  •  •  •  •  •  72-7224, 72-7226: 8 Functions 72-9480: 10 Functions 33/4 digits LCD Display 4000 Counts Display Manual Function Select and Auto Ranging 28mm Jaw Opening Diode and Continuity Test Continuity Buzzer •  •  •  •  •  •  •  •  Data Hold Relative and Sleep Mode (72-7224 & 72-7226 only) Max Mode (72-9480 only) Setup (72-9480 only) Duty Cycle: 0.1% ~ 99.9% Low Battery Indication and Auto Power Off Over Load Protection Input Impedance for DCV: 10MΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 10/04/18 V1.0 TM 400-600A Digital Clamp Meters General Characteristics Safety Rating Power LCD Size Colour Weight Dimension (H × W × L) : CAT II 600V, CAT III 300V : 9V Battery (6F22) : 35.6mm × 18mm : Orange & Grey : 260g : 208mm × 76mm × 30mm Electrical Specifications Model 72-7224 72-7226 72-9480 True RMS No Yes No Max. Jaw Opening 28mm 28mm 28mm DC Voltage 400mV / 4V / 40V / 400V / 600V, ±(0.8% +1 digit) 400mV / 4V / 40V / 400V / 600V, ±(0.8% + 1 digit) 400mV / 4V / 40V / 400V / 600V, ±(0.8% + 1 digit) AC Voltage 4V / 40V / 400V / 600V, ±(1% + 5 digits) 4V / 40V / 400V / 600V, ±(1% + 5 digits) 4V / 40V / 400V / 600V, ±(1% + 5 digits) DC Current 40A / 400A, ±(2% + 3 digits) 40A / 400A, ±(2% + 3 digits) 40A / 600A, ±(2.5% + 5 digits) AC Current 40A / 400A, ±(2.5% + 5 digits) 40A / 400A, ±(2.5% + 5 digits) 40A / 600A, ±(2.5% + 5 digits) Resistance 400Ω / 4kΩ / 40kΩ / 400kΩ / 4MΩ 400Ω / 4kΩ / 40kΩ / 400kΩ / 4MΩ 400Ω / 4kΩ / 40kΩ / 400kΩ / 4MΩ / 40MΩ, ± (1% + 2 digits / 40MΩ, ±(1% + 2 digits) / 40MΩ, ±(1% + 2 digits) Capacitance - - 4nF / 40nF / 400nF / 4µF / 40µF / 100µF ± (4% + 3 digits) Temperature - - -40°C to 1000°C, ±(2.5% + 3 digits) Frequency 10Hz-1MHz, ±(0.1% + 3 digits) 10Hz-1MHz, ±(0.1% + 3 digits) 10Hz-1MHz, ±(0.1% + 3 digits) 6F22 Battery, 1 Pair Test Leads, Operating Manual, Carrying Case 6F22 Battery, 1 Pair Test Leads, Point Contact Temperature Probe, Operating Manual, Carrying Case Standard Accessories 6F22 Battery, 1 Pair Test Leads, Operating Manual, Carrying Case Part Number Table Description Part Number 400A, Digital Clamp Meter, 3 /4 Digits 72-7224 400A, True RMS Digital Clamp Meter, 3 /4 Digits 72-7226 600A, Digital Clamp Meter, 33/4 Digits 72-9480 3 3 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 10/04/18 V1.0
72-9480
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过内部发光二极管和光电晶体管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP-6封装。
72-9480 价格&库存
很抱歉,暂时无法提供与“72-9480”相匹配的价格&库存,您可以联系我们找货
