Straight 4mm Male Banana Plug
TM
to Right-Angle 4mm Male Banana Plug Lead
Characteristics
Electrical Safety
: According to EN / IEC 61010-031:2008: 1000 V CAT II /
1000 V CAT III / 600 V CAT IV, reinforced insulation, 12A (at +40°C).
These specifications come from the creepage distances, clearances,
accessible parts, and solid insulation of the lead. And the considered
specifications of the environment are :
Pollution degree, 1 or 2 ;
Relative humidity, 80% maximum for temperatures up to 31°C
decreasing linearly to 50% relative humidity at +40°C
Temperature range, +5°C to +40°C
Indoor use ; Altitude, 2000 m maximum.
According to EN / IEC 60529 : IP2X (touchproof).
Operating Temperature
: -20°C to +80°C
Materials
:C
onductors of the plugs: Nickel-coated brass.
Wire jackets: silicone. Insulators and lantern contact spring
Colour
: Red, Black, Blue, Green & Yellow
Overall Length
: 1 meter (100cm) & 1.5 meters (150cm)
Part Number Table
Description
Length
1m
Straight 4mm Male Banana Plug to
1.5m
Colour
Part Number
Red
76-018
Black
76-019
Blue
76-1408
Green
76-1410
Yellow
76-1412
Red
76-020
Black
76-021
Blue
76-1414
Green
76-1416
Yellow
76-1418
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016.
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
www.mcmelectronics.com
TM
Page
28/03/17
V1.0
很抱歉,暂时无法提供与“76-1410”相匹配的价格&库存,您可以联系我们找货
