BECKHRT
BECKHRT
    TENMA
    TENMA  BECKHRT  Soldering Iron Tip, Straight, 4 mm
BECKHRT 数据手册
TENMA  Brand  Soldering  Irons  and  Tip  data  sheet General  purpose  soldering  irons The iron features a small barrel to handle ratio, enabling users to manouver easily for better control when soldering. 100% impact resistant handle assuring well built, long lasting quality. Seamless stainless steel barrel restrains heat expansion, prorecting the internal heater, and ensuring a long life for the heating element. Supplied with a metal sheet stand. Iron  P/No Plug  type Wattage 2452841 2452842 2452843 2452844 2452845 2452846 2452847 2452848 2452849 2452850 2452851 2452852 UK EU UK EU UK EU UK EU UK EU UK EU 15 15 30 30 40 40 60 60 80 80 100 100 Tip  Temp  °C Tip  size  mm 320 320 430 430 470 470 500 500 530 530 560 560 3.5 3.5 4 4 5 5 6 6 7 7 8 8 Mfr  P/no Bit  P/No BECKGRT BECKGRT BECKHRT BECKHRT BECKJRT BECKJRT BECKKRT BECKKRT BECKLRT BECKLRT BECKMRT BECKMRT 2475537 2475537 2475538 2475538 2475539 2475539 2475540 2475540 2475541 2475541 2475542 2475542 Industrial  soldering  irons   The iron is designed for high power soldering jobs which require heat retention at the tip. Available in 100W and 200W, thess irons are useful mainly for soldering metal sheets, or as a branding tool. It can also be used to cut vinyl canopy fabric. The high quality heater element ensures a long life. It features an ON/OFF switch on the handle and is fitted with a Copper tip. Supplied with heavy duty sturdy stand. Iron  P/No Plug  type Wattage 2452853 2452854 2452855 2452856 UK EU UK EU 100 100 200 200 Tip  Temp  °C Tip  size  mm 380 380 430 430 9.5 9.5 19 19 Mfr  P/No Bit  P/No BEBKNRT BEBKNRT BEBKQRT BEBKQRT 2475543 2475543 2475544 2475544 Replacement  tips Long life tips are excellent heat conductive soldering tips made from pure copper. They  are  iron-­‐plated  making  them  multiple  times  more  durable  than  regular  copper  tips.   They  are  chrome-­‐plated  on  the  outside  and  therefore  are  corrosion  free. The  tip  is  factory  pre-­‐tinned  which  improves  the  performance  of  the  tip. Note:  Long  life  tips  cannot  be  filed  as  this  will  damage  the  tip  structure.
BECKHRT 价格&库存
很抱歉,暂时无法提供与“BECKHRT”相匹配的价格&库存,您可以联系我们找货
