21-21310 EU
21-21310 EU
    TENMA
    TENMA - 21-21310 EU - Soldering Station, 80 W, 240 V, 480 °C, Heater, Power Supply, Iron Stand, EU P...
21-21310 EU 数据手册
TM ESD Safe Soldering Station Features •  •  •  •  •  •  LCD display MCU controlled temperature calibration 3 Preset and 2 variable button adjustment On / Off switch on side unit Pluggable four-core heating element Includes main unit, handle set, iron stand, AC power cord, sponge and manual www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 03/09/18 V1.0 TM ESD Safe Soldering Station Technical Specifications Voltage Power Heater Voltage Temperature Range Temperature Offset Range Temperature Stability Temperature Accuracy Heater Tip to Ground Impedance Tip to Ground Voltage Dimension (L × W × H) Weight : AC (220V ~ 240V) 50Hz : 80W : 26V AC : 150°C to 480°C (302°F to 896°F) : ±50°C / ±90°F : ±2°C (still air, no load) : ±10°C : High quality pluggable four-core heating element : < 2Ω : < 2mV : 146mm × 120mm × 91mm : 1.8kg Part Number Table Description Part Number Soldering Station, ESD Safe, 80W, 220V AC, 480°C Max. Temp., UK Plug 21-21310 UK Soldering Station, ESD Safe, 80W, 220V AC, 480°C Max. Temp., EU Plug 21-21310 EU Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 03/09/18 V1.0
21-21310 EU 价格&库存
很抱歉,暂时无法提供与“21-21310 EU”相匹配的价格&库存,您可以联系我们找货
