5SI-216N-BC
5SI-216N-BC
    TENMA
    TENMA - 5SI-216N-BC - Soldering Iron Tip, Pointed, 1 mm Tip Width
5SI-216N-BC 数据手册
Temperature-Controlled TM Soldering Station for Digital Display Features •  •  •  •  Comply with CE, ESD safe certification Adjustable temperature control with lock/set screw Temperature range 200°C to 480°C (392°F to 896°F) Soldering iron handles are insulated and ergonomic-designed for ease and comfort. •  Celsius or Fahrenheit temperature setting •  Control IC modular design for easy and quickly repair Specifications: Power Consumption 60W Output Voltage 24V AC Display Digital Heater Alumin ceramic heating element Temperature Range 200°C to 480°C (392°F to 896°F) Station Size (mm) 145 × 95 × 130 Voltage 220V ~ 240V 50Hz B type C type Standard Plug    Replacement heater 9SS-900N-HT Soldering Iron 9SS-900N-SI Individual packing Colour Box Tips / Nozzles Part Number Table Description Part Number Temperature-Controlled Soldering Station For Digital Display (AC110/220V switch) SS-207BC-F Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 25/05/16 V1.0
5SI-216N-BC 价格&库存
很抱歉,暂时无法提供与“5SI-216N-BC”相匹配的价格&库存,您可以联系我们找货
