76-1412
76-1412
    TENMA
    TENMA - 76-1412 - TEST LEAD, 4MM BANANA PLUG-PLUG, YEL, 1M
76-1412 数据手册
Straight 4mm Male Banana Plug TM to Right-Angle 4mm Male Banana Plug Lead Characteristics Electrical Safety : According to EN / IEC 61010-031:2008: 1000 V CAT II / 1000 V CAT III / 600 V CAT IV, reinforced insulation, 12A (at +40°C). These specifications come from the creepage distances, clearances, accessible parts, and solid insulation of the lead. And the considered specifications of the environment are : Pollution degree, 1 or 2 ; Relative humidity, 80% maximum for temperatures up to 31°C decreasing linearly to 50% relative humidity at +40°C Temperature range, +5°C to +40°C Indoor use ; Altitude, 2000 m maximum. According to EN / IEC 60529 : IP2X (touchproof). Operating Temperature : -20°C to +80°C Materials :C  onductors of the plugs: Nickel-coated brass. Wire jackets: silicone. Insulators and lantern contact spring Colour : Red, Black, Blue, Green & Yellow Overall Length : 1 meter (100cm) & 1.5 meters (150cm) Part Number Table Description Length 1m Straight 4mm Male Banana Plug to Right-Angle 4mm Male Banana Plug Lead 1.5m Colour Part Number Red 76-018 Black 76-019 Blue 76-1408 Green 76-1410 Yellow 76-1412 Red 76-020 Black 76-021 Blue 76-1414 Green 76-1416 Yellow 76-1418 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 28/03/17 V1.0
76-1412 价格&库存
很抱歉,暂时无法提供与“76-1412”相匹配的价格&库存,您可以联系我们找货
