72-14132
72-14132
    TENMA
    TENMA - 72-14132 - 4MM UNINSULATED SOCKET
72-14132 数据手册
TM 4mm Uninsulated Banana Jack w/ Ø2mm Hole Terminal – M6 Threaded Stud and Hex Nuts Application To repair or make panels or boxes providing 4mm banana connections for power supplies, measurements, controls, tests. Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Contact Material Terminal Dimension : 4mm Banana Jack : Panel Mount : Ø2mm Hole Terminal – M6 Threaded Stud and Hex Nuts : ≤33V AC, ≤70V DC : 36A : Gold Nickel Plated (Optional) : M6 × 0.75 Diagram Part Number Table Description Part Number 4mm Uninsulated Banana Jack w/ Ø2mm Hole Terminal, M6 Threaded Stud and Hex Nuts, Panel, 33V AC/70V DC, 36A 72-14130 4mm Uninsulated Gold Plated Banana Jack w/ Ø2mm Hole Terminal, M6 Threaded Stud and Hex Nuts, Panel, 33V AC/70V DC, 36A 72-14132 Dimensions : Millimetres Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 29/04/21 V1.1
72-14132 价格&库存
很抱歉,暂时无法提供与“72-14132”相匹配的价格&库存,您可以联系我们找货
