72-2645
72-2645
    TENMA
    TENMA - 72-2645 - Bench Power Supply, RS232/USB, Adjustable, Fixed, 3 Output, 0 V, 30 V, 0 A, 5 A
72-2645 数据手册
TM Triple Channel Programmable DC Power Supply Features •  •  •  •  •  •  •  Complete programmable 10mV / 1mA resolution Low noise and ripple CV / CC constant voltage and constant current modes 5 sets of parameters can be stored and recalled Industrial grade, with load for a long time Interfaces USB and RS232 Specifications Table Performance 72-2645 Channels Dual Channel Adjustable, One Channel Fixed AC Input Voltage 230V, 50/60Hz Output Voltage Range 0-30V Output Current Range Load Regulation Line Regulation Setup Resolution Setup Accuracy (25°C ±5°C) Ripple (20Hz - 20MHz) Temperature Coefficient 5A × 2, 3A × 1 Voltage ≤0.01% + 2mV Current ≤0.02%+5mA Voltage ≤0.01%+3mV Current ≤0.01%+3mA Voltage 10mV Current 1mA Voltage ≤0.5% + 20mV Current ≤0.5%+15mA Voltage ≤1.5mVrms Current ≤3mArms Voltage ≤0.1﹪+10mV Current ≤0.1﹪+5mA TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 17/07/19 V1.1 TM Triple Channel Programmable DC Power Supply Performance Read Back Accuracy Read Back Temperature Coefficient Reaction Time (10% Rated load) 72-2645 Voltage 10mV Current 1mA Voltage ≤100ppm+10mV Current ≤100ppm + 5mA Voltage Rise ≤100mS Current Drop ≤100mS (10% Rated load) Indoor use Altitude: ≤2000m Ambient temperature 0 to 40°C Relative humidity ≤80% Operation Environment Interfaces Accessories RS-232, USB User Manual, 1x UK power cord and 1x Euro power cord (1.2m), USB cord (1.2M), software CD Weight 9.4 kg Dimension (W × H × D) 380mm × 250mm × 145mm Ambient Temperature: -10°C to +70°C Relative Humidity: ≤ 70% Storage Environment Part Number Table Description Part Number Triple Channel DC Power Supply, Programmable, 315W 72-2645 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 17/07/19 V1.1
72-2645 价格&库存
很抱歉,暂时无法提供与“72-2645”相匹配的价格&库存,您可以联系我们找货
