72-2985
72-2985
    TENMA
    TENMA - 72-2985 - Clamp Meter, True RMS, 100 A AC, 600 V DC, 17 mm Jaw Opening Max.
72-2985 数据手册
TM True RMS Mini Clamp Meter Features •  •  •  •  •  •  •  2000 Counts Display LCD Backlight Manual & Auto Ranging 17mm Jaw Capacity Diode and Continuity Test NCV Detector VFC Function •  •  •  •  •  •  •  Continuity Buzzer Data Hold Zero/MAX/MIN Modes Auto Power Off Low Battery Indication Input Protection Input Impedance for DCV: 10MΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.1 TM True RMS Mini Clamp Meter General Characteristics Safety Rating Power LCD Size Colour Weight Dimension Standard Accessories : CAT II 600V, CAT III 300V : AAA 1.5V Batteries × 2 : 39.3mm × 26.5mm : Orange and Grey : 170g : 175mm × 60mm × 33.5mm : Batteries, Test Lead & User Manual Electrical Specifications Parameters Range Best Accuracy AC Current 2A/20A/100A ±(2.5% +5 digits) DC Current 2A/20A/100A ±(2% +3 digits) AC Voltage 2V/20V/200V/600V ±(1% +3 digits) DC Voltage 200mV/2V/20V/200V/600V ±(0.7% +3 digits) Resistance 200Ω/2kΩ/20kΩ/200kΩ/2MΩ/20MΩ ±(1% +2 digits) Capacitance 2nF/20nF/200nF/2μF/20μF/200μF/2mF/20mF ±(4% +5 digits) Jaw Capacity 17mm Auto Power Off Around 15 minutes Low Battery Indication ≤ 2.5V Part Number Table Description Part Number True RMS Mini Clamp Meter, 17mm Jaw 72-2985 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.1
72-2985 价格&库存
很抱歉,暂时无法提供与“72-2985”相匹配的价格&库存,您可以联系我们找货
