72-6638
72-6638
    TENMA
    TENMA - 72-6638 - Anemometer, 0.8m/s to 30m/s, 0 °C, 50 °C, 80%, 180 mm
72-6638 数据手册
TM Digital Anemometer Features: •  •  •  •  •  •  •  •  High quality with the economical cost Pocket & compact housing case Separate probe, convenient for the remote measurement Low-friction ball vane wheels is accurate in both high & low velocities Multi-functions for air flow measurement : m/s, km/h, ft/min, knots (mile/h) Fast and accurate readings with LCD display Battery power source from 006P DC 9V batteries Used the durable, long-lasting components, including a strong, light weight ABS-plastic housing case •  Wide applications: use this anemometer to check air conditioning & heating systems, measure air velocities, wind speeds, temperature etc. General Specifications: Display 13mm (0.5") LCD. 3-1/2 digits Measurement m/s (meters per second) km/h (kilometers per hour) ft/min (feet/per minute) knots (nautical miles per hour) Sensor Structure Conventional twisted van arm and low friction ball bearing design Sampling Time Approx. 0.4 sec. Operating Temperature 0°C to 50°C (32°F to 122°F) Operating Humidity Less than 80% RH Power Supply 006P DC 9V battery (heavy duty type) Power Current Approx. DC 6mA Weight 381g/0.84lb. Main instrument : 180mm × 73mm × 23mm (4.3" × 2.9" × 1.4") Dimension Sensor head : Round, 72mm Dia. 260g/0.58lb. (Including battery) Weight Electrical Specifications (23 ±5°C): Measurement Range Resolution m/s 0.8 - 30.0 m/s 0.1 m/s km/h 2.8 - 108 km/h 0.1 km/h knots 1.6 - 58 knots 0.1 knots ft/min 160 - 5900 ft/min 10 ft/min Accuracy Full scale : ± (3% + 2d) Note: m/s - meters per second          km/h - kilometers per hour ft/min - feet/per minute           knots - nautical miles per hour (international knot) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/15 V1.0 TM Digital Anemometer Optional Accessories: Holster High quality rubber protective holster Part Number Table Description Part Number Digital Anemometer 72-6638 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/15 V1.0
72-6638 价格&库存
很抱歉,暂时无法提供与“72-6638”相匹配的价格&库存,您可以联系我们找货
