76-350
76-350
    TENMA
    TENMA  76-350  GROUND LEAD, BLACK, OSCILLOSCOPE PROBE
76-350 数据手册
TM Oscilloscope Probe Ground Lead Description Alligator clip ground lead for standard 5mm oscilloscope probes. Specification: Voltage : 300V Part Number Table Description Part Number Oscilloscope Probe Ground Lead 76-350 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 06/10/15 V1.1
76-350
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,具有低功耗、高效率的特点。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817主要用于红外线发射,常用于遥控器、红外线通信等领域。
6. 应用信息:广泛应用于家用电器、汽车电子、工业控制等领域。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.8mm x 1.8mm。
76-350 价格&库存
很抱歉,暂时无法提供与“76-350”相匹配的价格&库存,您可以联系我们找货
