72-823
72-823
    TENMA
    TENMA - 72-823 - IR / Infrared Thermometer, -32°C to +650°C, 2 %, -32 °C, 650 °C
72-823 数据手册
TM IR Thermometer Description This model is infrared thermometer which can determine the surface temperature by measuring the amount of infrared energy radiated by the target surface. It has different distance to spot (D:S) ratios and different temperature ranges. The thermometer is a non-contact infrared instrument designed with low power consumption, which can make the measurements much faster and easier and meanwhile save you amount of time from frequent battery replacement. It can be powered by the battery or the source with USB connected to. Features •  •  •  •  •  •  •  Specifications °C/°F Selection Laser Switch Display Hold (s) : 8 Seconds Data Hold Auto Power Off Low Battery Indication MAX Mode Temperature Range : -32°C to +650°C (-26°F to +1,202°F) Accuracy : ±1.8°C or ±1.8% Repeatability : ±0.5°C or ±0.5% Resolution : 0.1°C/0.1°F Distance to Spot Size : 20 : 1 Response Time : 250mS(95% of reading) Emissivity : 0.1 to 1 Adjustable Laser Type : Class 2(II) Laser Power :
72-823 价格&库存
很抱歉,暂时无法提供与“72-823”相匹配的价格&库存,您可以联系我们找货
