315306SW
315306SW
    WALTER(华德)
315306SW 数据手册
IEC 309 PIN & SLEEVE DEVICES • LIGHT & STAGE DEVICES NEW ! New Light & Stage Style Standard Style Well hidden from View! It is necessary that electrical installations on stages function without interruption and not be a distraction to the viewers. The Walther Electric Solution: Black devices which prevent bothersome light reflections and thus make the electrical installation on stages almost “invisible”! Now You See It Male Plugs IP 44 - Now You Don’t for Light & Stage Applications 2P+E 4 3P+E 5 3P+N+E Poles 3 Amperage IEC/EN 60 309 110 V 230 V 400 V 500 V 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz pole 4pole 5pole 3 4h 4h 4h pole 4pole 5pole 3 6h 9h 9h 3pole 4pole 5pole 9h 6h 6h pole 4pole 5pole 3 7h 7h 7h g Part numbers 16 16 16 32 32 32 63 63 63 125 125 125 231SW Plugs with gland entry, in 16 - 63 A = IP 44 16 215306SW 230SW 3 211 306 SW 4 211 406 SW 5 211 SW 3 231 306 SW 4 231 406 SW 5 231 SW 3 261 306 SW 4 261 406 SW 5 261 SW 3 279 306 SW1) 4 279 406 SW1) 5 279 SW1) 3 Plugs IP 44 215 304 SW , in 125 A = IP 67 10 112 10 154 10 170 10 211 10 217 10 240 5 475 5 566 5 613 2 1185 2 1329 2 1473 1) 215 306 SW 10 101 with inverted cable entry 16 5 210 SW 10/60 176 32 5 230 SW 10/60 250 Plugs IP 44 , with cable gland Consult customer service for other amperage and voltage ratings and configurations. 32 iec309final.indd 32 9/25/2008 12:05:27 Pm CEEtyp LIGHT & STAGE DEVICES NEW ! Female Connectors & Socket-Outlets IP 44 2P+E 4 3P+E 5 3P+N+E 110 V Poles 3 Amperage IEC/EN 60 309 230 V for Light & Stage Applications 400 V 500 V 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz pole 4pole 5pole 3 4h 4h 4h pole 4pole 5pole 3 6h 9h 9h 3pole 4pole 5pole 9h 6h 6h pole 4pole 5pole 3 7h 7h 7h g Part numbers 16 16 16 32 32 32 63 63 63 125 125 125 331306SW Couplers with gland entry, 16 - 63 A = IP 44 16 315306SW 310SW 3 311 306 SW 4 311 406 SW 5 311 SW 3 331 306 SW 4 331 406 SW 5 331 SW 3 361 306 SW 4 361 406 SW 5 361 SW 3 379 306 SW2) 4 379 406 SW2) 5 379 SW2) 3 315 304 SW Couplers IP 44 , 125 A = IP 67 2) 315 306 SW 10 140 , with inverted cable entry 16 5 310 SW 10/60 219 32 5 330 SW 10/60 311 3 410 304 SW 410 306 SW 4 410 406 SW 5 410 SW 10 10 10 128 106 165 3 430 306 SW 4 430 406 SW 5 430 SW 10 10 10 208 215 226 3 460 306 SW 4 460 406 SW 5 460 SW 125 3 479 306 SW3) 125 4 479 406 SW3) 125 5 479 SW3) 5 5 5 586 645 776 Couplers IP 44 16 16 16 32 32 32 , with cable gland 63 63 63 430SW 10 147 10 197 10 214 10 265 10 278 10 300 5 656 5 771 5 787 2 1362 2 1536 2 1710 Panel sockets, straight, 16 - 63 A = IP 44 , 125 A = IP 67 2 990 2 1155 2 1319 3), fingerproof acc. to BGV A2 Consult customer service for other amperage and voltage ratings and configurations. 33 iec309final.indd 33 9/25/2008 12:05:29 Pm
315306SW 价格&库存
很抱歉,暂时无法提供与“315306SW”相匹配的价格&库存,您可以联系我们找货
