IEC 309 PIN & SLEEVE DEVICES • PERFORMANCE SPECIFICATIONS • INTERNATIONAL RATINGS
ELECTRICAL
TABLE 1
Insulation Resistance
Per IEC 309-1, Clause 19
Dielectric Strength
Norm. Operation, Connect
& Disconnect Cycles
Per IEC 309-1, Clause 21
Breaking Capacity
Per IEC 309-1, Clause 20
Temperature Rise
Per IEC 309-1, Clause 22
500V for 1 min. Resistance ≥ 5MΩ
3000V for 1 min.
See Table 1
Tested at 110 % of the rated operating
voltage and 125% of the rated current.
Maximum 50 K rise at full rated current.
TABLE 2
MECHANICAL
Cable Secureness
Per IEC 309, Clause 23
Impact
Per IEC 309, Clause 24
See Table 2
A device is wired with a 2.25m length
of flexible cord and dropped from a
height of 75 cm, 8 times. The device
is then tested for applicable degrees
of protection against moisture.
ENVIRONMENTAL
Flammability
Ambient Temperature
Range
Moisture Resistance
UV Resistance
Connect and Disconnect Cycles
Cycles with
Device
Load at Rated
Rating
Current and
No-Load
Amperes
Voltage
Cycles
Sequence
16
5000 p.f of 0.6
1000 p.f of 0.6
1000
Alternating
63
1000 p.f of 0.6
1000
Alternating
125
250 p.f of 0.7
250
Alternating
The test sequence is conducted by using a no-load, followed by a load
sequence.
Cable Secureness Test
Device
Maximum
Rating
Force
Torque
Displacement
Amperes
N
N•m
mm
16
80
0.350
2
32
100
0.425
2
63
120
0.8
2
125
200
1.5
2
The flexible cord or cable is twisted and pulled. Values for the applied
twisting torque and force of pull are shown in Table 2. In all cases the cord
displacement is less than 2mm.
Self-extinguishing
Per IEC 309-1, Clause 27
Minimum: -25°C with impact
Maximum: 90°C
Watertight (IP67): Device immersed for
24 hours in water at a temp. of 25°C, the
highest point of the device being 5cm (2”)
below the water level.
Splashproof (IP44): Device is sprayed with
water for 10 minutes and immediately
afterwards subjected to splashing water in
all directions (360°).
Exposed plastic materials are UV stabilized.
DECLARATION OF CONFORMITY
WALTHER WERKE, Ferdinand Walther GmbH
Ramsener Strasse 6
67304 Eisenberg
We declare, under our sole responsibility, the conformity of the following
products and standards:
Plugs and Sockets (Pin and Sleeve devices)
DIN EN 60 309, T. 1/BS 4343
DIN EN 60 309, T. 2
DIN EN ISO 9001
Certificate Registration No. 4678-01
This declaration of conformity is according to the EC regulations 73/23,
91/368 and 89/336 (Low Voltage Directive), module A, in consideration of
DIN EN 45 014.
19
16 AMPS
IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS
MALE PLUGS
No. of
Wires
WATERTIGHT (IP67)
Voltage AC
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
6P
G
400
7
3
2P + G
Voltage AC
4
5
with cable gland
with cable sleeve
Angled 90°
211304
211306
211309
211404
211409
211406
211411
211407
211410
211402
211504
211509
211
211511
211706
210304
210306
210309
210404
210409
210406
210411
210407
210410
210402
210504
210509
210
210511
210706
216304
216306
216309
216404
216409
216406
216411
216407
216410
216402
216504
216509
216
216511
Clock
Position
of Ground
Contact
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
FEMALE CONNECTORS (Couplers)
No. of
Wires
SPLASHPROOF (IP44)
219304
219306
219309
219404
219409
219406
219411
219407
219410
219402
219504
219509
219
219511
WATERTIGHT (IP67)
SPLASHPROOF (IP44)
with cable gland
with cable sleeve
Angled 90°
311304
311306
311309
311404
311409
311406
311411
311407
311410
311402
311504
311509
311
311511
311706
310304
310306
310309
310404
310409
310406
310411
310407
310410
310402
310504
310509
310
310511
310706
316304
316306
316309
Clock
Position
of Ground
Contact
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
319304
319306
319309
319404
319409
319406
319411
319407
319410
319402
319504
319509
319
319511
FEMALE PANEL MOUNTED SOCKET-OUTLET
No. of
Wires
Voltage AC
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
WATERTIGHT (IP67)
16 AMPS
SPLASHPROOF (IP44)
Straight
Angled 15°
Angled 80°
Straight
Angled 15°
Angled 80°
419304
419306
419309
419404
419409
419406
419411
419407
419410
419402
419504
419509
419
419511
519304
519306
519309
519404
519409
519406
519411
519407
519410
519402
519504
519509
519
519511
518304
518306
518309
518404
518409
518406
518411
518407
518410
518402
518504
518509
518
518511
410304
410306
410309
410404
410409
410406
410411
410407
410410
410402
410504
410509
410
410511
411706
510304
510306
510309
510404
510409
510406
510411
510407
510410
510402
510504
510509
510
510511
514304
514306
514309
514404
514409
514406
514411
514407
514410
514402
514504
514509
514
514511
514706
Clock
Position
of Ground
Contact
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
Note: See page 28 for surface mount socket-outlets.
MALE APPLIANCE PLUG (Inlet)
No. of
Wires
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
6P
G
400
7
3
4
5
2P + G
Voltage AC
WATERTIGHT (IP67)
Angled 80°
Surface
Mount
619304
619306
619309
619404
619409
619406
619411
619407
619410
619402
619504
619509
619
619511
618304
618306
618309
618404
618409
618406
618411
618407
618410
618402
618504
618509
618
618511
SPLASHPROOF (IP44)
Straight
Angled 80°
615304
615306
615309
615404
615409
615406
615411
615407
615410
615402
615504
615509
615
615511
615706
611304
611306
611309
611404
611409
611406
611411
611407
611410
611402
611504
611509
611
611511
611706
Surface Mount Surface Mount
External Mounting Internal Mounting
Clock
Position
of Ground
Contact
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
610304
610306
610309
610404
610409
610406
610411
610407
610410
610402
610504
610509
610
610511
610706
616404
616409
616406
616411
616407
616410
616402
616504
616509
616
616511
616706
21
32 AMPS
MALE PLUGS
No. of
Wires
WATERTIGHT (IP67)
Voltage AC
110
230
400
3P + G
110
230
400
380/440*
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
7 6P + G
400
3
2P + G
4
5
Voltage AC
110
230
400
3P + G
110
230
400
380/440*
440
500
>50 (100/300Hz)
>50 (300/500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
* Only for refrigerated containers.
22
22
with cable gland
with cable sleeve
Angled 90°
231304
231306
231309
231404
231409
231406
230304
230306
230309
230404
230409
230406
236304
236306
236309
236404
236409
236406
231411
231407
231410
231402
231504
231509
231
231511
231706
230411
230407
230410
230402
230504
230509
230
230511
230706
236411
236407
236410
236402
236504
236509
236
236511
Clock
Position
of Ground
Contact
4
6
9
4
9
6
3
11
7
10
2
4
9
6
11
6
No. of
Wires
SPLASHPROOF (IP44)
239304
239306
239309
239404
239409
239406
239403*
239411
239407
239410
239402
239504
239509
239
239511
WATERTIGHT (IP67)
SPLASHPROOF (IP44)
with cable gland
with cable sleeve
331304
331306
331309
331404
331409
331406
330304
330306
330309
330404
330409
330406
331411
331407
331410
331402
331504
331509
331
331511
331706
330411
330407
330410
330402
330504
330509
330
330511
330706
Clock
Position
of Ground
Contact
4
6
9
4
9
6
3
11
7
10
2
4
9
6
11
6
339304
339306
339309
339404
339409
339406
339403*
339411
339407
339410
339402
339504
339509
339
339511
No. of
Wires
Voltage AC
110
230
400
3P + G
110
230
400
380/440*
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
WATERTIGHT (IP67)
32 AMPS
SPLASHPROOF (IP44)
Straight
Angled 15°
Angled 80°
Straight
Angled 15°
Angled 80°
439304
439306
439309
439404
439409
439406
439403*
439411
439407
439410
439402
439504
439509
439
439511
539304
539306
539309
539404
539409
539406
538304
538306
538309
538404
538409
538406
430304
430306
430309
430404
430409
430406
530304
530306
530309
530404
530409
530406
534304
534306
534309
534404
534409
534406
539411
539407
539410
539402
539504
539509
539
539511
538411
538407
538410
538402
538504
538509
538
538511
430411
430407
430410
430402
430504
430509
430
430511
431706
530411
530407
530410
530402
530504
530509
530
530511
534411
534407
534410
534402
534504
534509
534
534511
534706
Clock
Position
of Ground
Contact
4
6
9
4
9
6
3
11
7
10
2
4
9
6
11
6
No. of
Wires
Voltage AC
110
230
400
3P + G
110
230
400
380/440*
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
WATERTIGHT (IP67)
Angled 80°
Surface
Mount
639304
639306
639309
639404
639409
639406
639403*
639411
639407
639410
639402
639504
639509
639
639511
638304
638306
638309
638404
638409
638406
638403*
638411
638407
638410
638402
638504
638509
638
638511
SPLASHPROOF (IP44)
Straight
Angled 80°
635304
635306
635309
635404
635409
635406
631304
631306
631309
631404
631409
631406
630304
630306
630309
630404
630409
630406
636304
636306
636309
636404
636409
636406
635411
635407
635410
635402
635504
635509
635
635511
635706
631411
631407
631410
631402
631504
631509
631
631511
631706
630411
630407
630410
630402
630504
630509
630
630511
630706
636411
636407
636410
636402
636504
636509
636
636511
636706
Clock
Position
of Ground
Contact
4
6
9
4
9
6
3
11
7
10
2
4
9
6
11
6
23
63 AMPS
MALE PLUGS
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
WATERTIGHT (IP67)
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
24
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
269304
269306
269309
269404
269409
269406
269411
269407
269504
269509
269
269511
SPLASHPROOF (IP44)
with cable gland
with cable sleeve
261304
261306
261309
261404
261409
261406
261411
261407
261504
261509
261
261511
260304
260306
260309
260404
260409
260406
260411
260407
260504
260509
260
260511
WATERTIGHT (IP67)
369304
369306
369309
369404
369409
369406
369411
369407
369504
369509
369
369511
SPLASHPROOF (IP44)
with cable gland
with cable sleeve
361304
361306
361309
361404
361409
361406
361411
361407
361504
361509
361
361511
360304
360306
360309
360404
360409
360406
360411
360407
360504
360509
360
360511
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
WATERTIGHT (IP67)
63 AMPS
SPLASHPROOF (IP44)
Straight
Angled 15°
Angled 80°
Straight
Angled 15°
Angled 80°
469304
469306
469309
469404
469409
469406
469411
469407
469504
469509
469
469511
569304
569306
569309
569404
569409
569406
569411
569407
569504
569509
569
569511
568304
568306
568309
568404
568409
568406
568411
568407
568504
568509
568
568511
460304
460306
460309
460404
460409
460406
460411
460407
460504
460509
460
460511
560304
560306
560309
560404
560409
560406
560411
560407
560504
560509
560
560511
564304
564306
564309
564404
564409
564406
564411
564407
564504
564509
564
564511
Note: See page 28 for surface mount receptacles.
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
WATERTIGHT (IP67)
Angled 80°
Surface
Mount
669304
669306
669309
669404
669409
669406
669411
669407
669504
669509
669
669511
668304
668306
668309
668404
668409
668406
668411
668407
668504
668509
668
668511
SPLASHPROOF (IP44)
Straight
Angled 80°
665504
665509
665
665511
661304
661306
661309
661404
661409
661406
661411
661407
661504
661509
661
661511
25
125 AMPS
MALE PLUGS
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
WATERTIGHT (IP67)
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
26
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
279304
279306
279309
279404
279409
279406
279411
279407
279504
279509
279
279511
WATERTIGHT (IP67)
379304
379306
379309
379404
379409
379406
379411
379407
379504
379509
379
379511
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
125 AMPS
WATERTIGHT (IP67)
Straight
Angled 15°
479304
479306
479309
479404
479409
479406
479411
479407
479504
479509
479
479511
579304
579306
579309
579404
579409
579406
579411
579407
579504
579509
579
579511
No. of
Wires
3
2P + G
3P + G
4
3P + N + G
5
Voltage AC
Clock
Position
of Ground
Contact
110
230
400
110
230
400
440
500
110
230
400
440
4
6
9
4
9
6
11
7
4
9
6
11
WATERTIGHT (IP67)
Straight
Surface Mount
679304
679306
679309
679404
679409
679406
679411
679407
679504
679509
679
679511
678304
678306
678309
678404
678409
678406
678411
678407
678504
678509
678
678511
27
SURFACE MOUNT SOCKET-OUTLETS
(Internal Mounting)
No. of
Wires
Voltage AC
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
400
7 6P + G
3
2P + G
4
5
WATERTIGHT (IP67)
16 Amps
32 Amps
119304
119306
119309
119404
119409
119406
119411
119407
119410
119402
119504
119509
119
119511
139304
139306
139309
139404
139409
139406
139411
139407
139410
139402
139504
139509
139
139511
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
(External Mounting)
110
230
400
3P + G
110
230
400
440
500
>50 (100-300Hz)
>50 (300-500Hz)
3P + N + G
110
230
400
440
6P
G
400
7
3
2P + G
Voltage AC
4
5
28
63 Amps
125 Amps
16 Amps
32 Amps
169404
169409
169406
169411
169407
169410
169402
169504
169509
169
169511
179304
179306
179309
179404
179409
179406
179411
179407
179410
179402
179504
179509
179
179511
111304
111306
111309
111404
111409
111406
111411
111407
111410
111402
111504
111509
111
111511
111706
131304
131306
131309
131404
131409
131406
131411
131407
131410
131402
131504
131509
131
131511
131706
63 Amps
Clock
Position
of Ground
Contact
No. of
Wires
SPLASHPROOF (IP44)
SPLASHPROOF (IP44)
16 Amps
32 Amps
110304
110306
110309
110404
110409
110406
110411
110407
110410
110402
110504
110509
110
110511
110706
130304
130306
130309
130404
130409
130406
130411
130407
130410
130402
130504
130509
130
130511
130706
Clock
Position
of Ground
Contact
4
6
9
4
9
6
11
7
10
2
4
9
6
11
6
161404
161409
161406
161411
161407
161410
161402
161504
161509
161
161511
很抱歉,暂时无法提供与“210304”相匹配的价格&库存,您可以联系我们找货
