269306
269306
    WALTER(华德)
269306 数据手册
Plugs IP 44 3P+E 3P+N+E 110 V Poles 2P+E 5 4 Ampère 2 3 230 V 400 V and IP 67 > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 500 V > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 3pole 4pole pole 4h 4h 4h pole 4pole 5pole 3 6h 9h 9h pole 4pole 5pole 3 9h 6h 6h 3pole 4pole 5pole 7h 7h 7h pole 4pole 5pole 3 10h 10h 10h 3pole 4pole 5pole 2h 2h 2h 100 300 Hz IEC/EN 60 309 over 300 500 Hz g Part numbers 16 16 16 3 4 5 216 304 216 404 216 504 216 306 216 409 216 509 216 309 216 406 216 407 216 410 216 402 216 10 10 10/60 106 150 163 32 32 32 3 4 5 236 304 236 404 236 504 236 306 236 409 236 509 236 309 236 406 236 407 236 410 236 402 236 10 10 10 214 230 251 plugs 236 16 5 210 PH 10 180 16 5 210 PHNI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 183 32 5 230 PH 10 257 32 5 230 PHNI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 264 Phase inverters 230 PH IP 44, with flexible cable entry 16 5 211 PH 10 174 16 5 211 PHNI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 180 32 5 231 PH 10 245 32 5 231 PHNI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 257 Phase inverters 231 PH IP 44, angled, back part RAL 7035 light grey IP 44, with gland entry 16 16 4 5 210 406 DF 210 DF 10 10 144 173 32 32 63 63 4 5 230 406 DF for voltage ranges of 110 V - 690 V 230 DF 10 10 198 241 4 5 260 406 DF 260 DF 10 5 603 685 10 133 Phase sequence control plugs 230DF 16 3 219 304 219 306 IP 44 219 309 (with gland entry and screw terminals) All red marked plugs come with new design and cable gland. Additionally these are also available as screwless version with IDC insulation displacement connection. To order a plug as screwless version, just add „SL“ to the part number, e.g. 219SL. ▲ gland entry 219306 cable  ► gland 239 16 16 32 32 32 new design 269 14 4 5 219 404 219 504 219 409 219 509 219 406 219 407 219 410 219 402 219 10 10 212 236 3 4 5 239 304 239 404 239 504 239 306 239 409 239 509 239 309 239 406 239 407 239 410 239 402 239 10 10 10 290 300 340 Plugs IP 67, with screw terminals or as screwless SL version with insulation displacement technique 16 32 63 125 5 5 5 5 63 63 63 3 4 5 269 304 269 404 269 504 269 306 269 409 269 509 269 309 269 406 269 407 269 410 269 402 269 5 5 5 125 3 125 4 125 5 279 304 279 404 279 504 279 306 279 409 279 509 279 309 279 406 279 407 279 410 279 402 279 2 1185 2 1329 2 1473 Plugs 219 NI (with nickel plated contacts and 239 NI glass-fibre reinforced enclosure) 269 NI 279 NI 10 199 10 286 5 771 2 1473 501 623 668 IP 67, with gland entry Availability of blue printed (or not listed) frequencies and voltages up to 690 V on request! Other voltages and frequencies on request. Part numbers in bold letters are standard versions. n n Øu Øu 16 32 63 Amp. 16 16 32 Poles 3 5 5 3 4 5 Poles 4 5 3 / 4 5 150-161 Ø 65 111 36.5 Ø 81 7.5 / 19.5 150-161 Ø 65 111 36.5 Ø 89 7.5 / 19.5 174-183 Ø 72 127 45.5 Ø 95 9.6 / 24.5 174-183 Ø 72 127 45.5 Ø 100 9.6 / 24.5 143 153 181 252 252 252 51 65 72 81 81 81 60 75 88 97 97 97 108 117 138 192 192 192 37 37 46 67 67 67 7/13 8/21 11/24 15/33 15/33 15/33 d Ø e m n Ø u Ø p d d d Øe f m n Øp m m Amp. Øp Øp 210 306, 260 etc. and NI versions Amp. Poles d e f n p Øe Øe Page 14, item 5b 219, 239 etc. (red part nos.) 16 32 Amp. 16 32 63 125 3 4 5 3 4 5 Poles 5 5 3 4 5 3 4 5 166 135 46 103 18-24.5 243 195 67 110 18-35 243 195 67 110 18-35 243 195 67 110 18-35 315 258 75.5 130 24-45 315 258 75.5 130 24-45 315 258 75.5 130 24-45 85 98 98 115 115 115 50.3 64.3 64.3 72 72 72 70 86 86 96 96 100 37 37 37 45.8 45.8 45.8 8/15 10/16.5 10/16.5 11/22 11/22 11/22 216, 236 etc. Amp. 16 Poles 5 d Øe f m n Øp d m n u Øp 219 NI, 239 NI, 269, 279 etc. Amp. Poles 5 b c d e f l n M 153 181 65 72 75 88 117 138 37 46 8/21 11/24 32 5 5 d 131 155 Øe 65 73 f 75 88 m 112 133 n 37 46 Øp 7.5 - 14.5 10 - 19.5 Amp. Poles b c d e f l n v M Poles d Øe f n 16 32 5 4 5 4 5 65 58 68 37 65 65 75 37 155 72 79 46 72 72 88 46 240 81 97 67 81 81 97 67 230 DF etc. Einbauöffnung Einbauöffnung 16 Poles 3 d m n u Øp a b c d e f h n p y z 4 5 45.5 60 60 60 60 5.3 5.3 5.3 5.3 5.3 74 80 80 97 97 60 74 74 82 82 60 73 73 80 80 28 31 31 45 45 110 117 117 141 141 20 20 20 25 25 60 5.3 97 82 86 45 141 25 16 32 4 3 4 5 5 66.5 66.5 66.5 66.5 66.5 5 5 5 5 5 96 96 96 96 96 95 95 95 95 95 140 140 140 140 140 47.5 47.5 47.5 47.5 47.5 151 151 160 160 160 7 7 7 7 7 20/25 20/25 20/25 20/25 20/25 3 30 55 5.5 52 65 72 38 97 9.5 30 36 16 32 4 5 3 4 5 3 4 5 45 78 5.5 75 90 103 60 129 9.5 44 54 90 90 6.2 114 114 116 70 185 6 56 65 90 90 6.2 114 114 116 70 185 6 56 65 90 90 6.2 114 114 116 70 185 6 56 65 40 40 45 45 68 68 78 78 5.5 5.5 5.5 5.5 66 66 75 75 80 80 90 90 90 92 103 103 52 52 60 60 110 110 129 129 9.5 9.5 9.5 9.5 38 38 44 44 46 46 54 54 Page 15, item 4 63 611, 631, 661 etc. Amp. Poles a b c d e f h n p 126 110 37 72 7.5-14.5 219 306 etc. (black part nos.) 32 3 Page 15, item 3 fixing fixinghole hole Amp. 5 616, 636 etc. 63 4 4 Page 15, item 2 Amp. Poles Amp. 16 610, 630 etc. M 211 PH, 231 PH & NI versions 3 Page 15, item 1 M 16 139 114 37 88 10-19.5 Page 14, item 6 32 210 PH, 230 PH & NI versions Amp. Poles 32 16 32 3 4 5 3 4 5 47 47 5.5 62 62 47 50 22 8.5 60 60 5.5 80 80 47 67 22 8.5 60 60 5.5 80 80 47 67 22 8.5 60 60 5.5 80 80 56 71 22 8.5 60 60 5.5 80 80 56 71 22 8.5 60 60 5.5 80 80 56 71 22 8.5 13 615, 635 etc. 51
269306 价格&库存
很抱歉,暂时无法提供与“269306”相匹配的价格&库存,您可以联系我们找货
