339306
339306
    WALTER(华德)
339306 数据手册
2P+E 4 3P+E 5 3P+N+E 110 V Poles 3 Ampère Couplers IP 44 230 V 400 V IEC/EN 60 309 > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 500 V > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 100 300 Hz over 300 500 Hz 3pole 4pole 5pole 4h 4h 4h pole 4pole 5pole 3 6h 9h 9h 3pole 4pole 5pole 9h 6h 6h 3pole 4pole 5pole 7h 7h 7h pole 4pole 5pole 3 10h 10h 10h 3pole 4pole 5pole 2h 2h 2h g Part numbers 330SL 310306 CK 16 16 4 5 310 404 SL 310 409 SL 310 406 SL 310 407 SL 310 410 SL 310 402 SL 10/60 310 504 SL 310 509 SL 310SL 10/60 261 304 32 32 32 3 4 5 10/60 330 304 SL 330 306 SL 330 309 SL 330 404 SL 330 409 SL 330 406 SL 330 407 SL 330 410 SL 330 402 SL 10/60 10/60 330 504 SL 330 509 SL 330 SL 323 342 371 Screwless couplers with insulation displacement technique, IP 44 16 3 310 304 CK 310 306 CK CK = plugs with crimp contacts, . screwless, click-together assembly, nonrewireable, tamper proof, maintenance-free 10 155 16 3 310 304 SK 310 306 SK = plugs with screw terminals, rewireable . SK 10 160 Couplers with crimp contacts, IP 44 16 16 32 32 32 330 331 360 310 404 310 504 310 409 310 509 310 406 310 407 310 410 310 402 310 10 10/60 248 270 3 4 5 330 304 330 404 330 504 330 306 330 409 330 509 330 309 330 406 330 407 330 410 330 402 330 10 10 10/60 312 328 363 10 140 3 IP 44, with screw terminals, with cable gland 315 304 Couplers IP 44 315 306 315 309 , with inverted cable entry 16 16 16 16 32 32 32 32 3 311 304 311 306 4 311 404 311 409 5 311 504 311 509 5 311 309 311 406 311 407 311 410 311 402 311 311 NI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 10 10 10 147 197 214 214 3 331 304 331 306 4 331 404 331 409 5 331 504 331 509 5 331 309 331406 331 407 331 410 331 402 331 331 NI (with nickel plated contacts + glass-fibre reinforced enclosure) 10 10 10 10 265 278 300 300 63 63 63 63 3 361 304 361 306 4 361 404 361 409 5 361 504 361 509 5 361 309 361 406 361 407 361 410 361 402 361 361 NI (with nickel plated contacts + glass-fibre reinforced enclosure) 5 5 5 5 656 771 787 787 310 309 10/60 150 310 306 AS (lockable with padlock (padlock not included) 10 Couplers IP 44 , with gland entry 16 3 16 3 16 63 5 5 5 63 63 63 3 4 5 32 310 306 4 5 Couplers 16 315 306 , with cable gland Couplers 310 304 360 304 360 404 360 504 310 306 360 306 360 409 360 509 310 NI (with nickel plated contacts and 330 NI glass-fibre reinforced enclosure) 360 NI 10 10 5 228 317 782 360 309 360 406 360 407 360 410 360 402 360 5 5 5 672 719 782 IP 44, with screw terminals, with flexible cable entry Availability of blue printed (or not listed) frequencies and voltages up to 690 V on request! Other voltages and frequencies on request. Part numbers in bold letters are standard versions. 17 3 2P+E 4 3P+E 5 3P+N+E 110 V Poles 3 Ampère Couplers IP 67 230 V 400 V and IP 44 > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 500 V > 50 - 500 V 50 a. 60 Hz 50 a. 60 Hz 100 300 Hz over 300 500 Hz 3pole 4pole 5pole 4h 4h 4h pole 4pole 5pole 3 6h 9h 9h pole 4pole 5pole 3 9h 6h 6h 3pole 4pole 5pole 7h 7h 7h 3pole 4pole 5pole 10h 10h 10h 3pole 4pole 5pole 2h 2h 2h IEC/EN 60 309 g Part numbers 3 16 319306 339 cable gland . new design 3 319 304 Couplers 319 306 339 NI 4 5 319 404 319 504 319 409 319 509 319 406 319 407 319 410 319 402 319 10 10 268 298 32 32 32 3 4 5 339 304 339 404 339 504 339 306 339 409 339 509 339 309 339 406 339 407 339 410 339 402 339 10 10 10 351 369 415 The couplers come with new design and with cable gland. Additionally they are also available as screwless version with IDC insulation displacement connection. To order a coupler as screwless version, just add „SL“ to the part number, e.g. 319SL. Couplers IP 67, with screw terminals or as screwless SL version with IDC technique and cable gland 18 for a 16 A plug/coupler use holding plate no.: for a 32 A plug/coupler use holding plate no.: 16 32 63 5 5 5 63 63 63 3 4 5 369 304 369 404 369 504 369 306 369 409 369 509 125 3 125 4 125 5 379 304 379 404 379 504 379 306 379 409 379 509 314 500 334 500 3 319 NI with nickel plated contacts + glass-fibre reinforced enclosure) 339 NI 369 NI 10 10 5 255 350 849 369 309 369 406 369 407 369 410 369 402 369 5 5 5 758 796 844 379 309 379 406 379 407 379 410 379 402 379 2 1362 2 1536 2 1710 , with gland entry, with multi contact 316 304 Angled couplers IP 44 16 317 306 A holding plate allows you to suspend a plug/coupler with cable gland from the ceiling. Holding plates, useable for plugs and couplers with cable gland 16 316 306 172 16 16 Couplers IP 67 369 10 IP 67, with screw terminals and gland entry suitable for devices with cable gland 314 500 319 309 3 Angled coupler IP 44 316 306 316 309 10 138 10 152 317 306 , with Schuko socket on reverse side Availability of blue printed (or not listed) frequencies and voltages up to 690 V on request! Other voltages and frequencies on request. Part numbers in bold letters are standard versions.
339306 价格&库存
很抱歉,暂时无法提供与“339306”相匹配的价格&库存,您可以联系我们找货
