410306
    WALTER(华德)
410306 数据手册
IEC 309-1 AND 309-2 PIN AND SLEEVE DEVICES North American IEC309-1 & 309-2 Pin & Sleeve International IEC309-1 & 309-2 Pin & Sleeve North American IEC309 Mechanical Interlocks International IEC309 Mechanical Interlocks Manual Disconnect Switches Custom-Built Power Distribution Systems DIN EN ISO 9001 Certificate Registration No. 4678-01 ...A RECOGNIZED WORLD LEADER IN THE DESIGN AND MANUFACTURING OF IEC 309-1 AND 309-2 PIN & SLEEVE DEVICES. F. Walther Electric Corporation is a U.S. subsidiary of Walther Werke, Ferdinand Walther GmbH, located in Eisenberg, Germany. Walther is an international company committed to serving customers around the world with innovative plug and receptacle systems. With subsidiary offices and distribution centers in the United States, Germany, United Kingdom, France and Austria, cooperatively working with agents located in more than 70 other countries, product accessibility and support are available to equipment manufactures, plants and construction sites worldwide. One of Walther’s many strengths is its uncompromising attention to detail. No short cuts. Just strict standards of consummate quality. Following an aggressive program to certify its manufacturing facilities, Walther has earned ISO 9001 certification. Since 1897, Walther has been known for its innovative design and manufacturing capabilities for not only meeting, but often exceeding the industry requirements for higher safety demands, better performance and standardized electrical systems. In the years since Walther introduced the first Pin & Sleeve system built to IEC 309-1 and 309-2 specifications, thousands of new products - that are GUARANTEED to perform have been added making it the broadest line for power and control applications. This offering makes us one of the largest and best sources for pin & sleeve devices in the world. DIN EN ISO 9001 Certificate Registration No. 4678-01 TABLE OF CONTENTS IEC-309-1 and IEC-309-2 Pin and Sleeve Devices Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-5 Material Specifications . . . . . . . . . . . . . . . . . . . . . 6 North American Ratings (20 to 100 Amp) . . . . . 7-16 Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 17-18 International Ratings (16 to 125 Amp) . . . . . . 19-28 Useful Tables . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Drawings and Dimensions . . . . . . . . . . . . . . . 30-39 IEC-309-1 and IEC-309-2 Mechanical Interlocks Introduction . . . . . . . . . . . . . . . . . . . . . . . . . 42-43 North American Ratings (20 to 100 Amp) . . . . 44-49 International Ratings (16 to 125 Amp) . . . . . . 50-54 Manual Disconnect Switches Manual Disconnect Switches . . . . . . . . . . . . . . 55-57 Custom-Built Power Distribution Systems Custom-Built Power Distribution Systems . . . . . 58-65 WORLDWIDE INTERCHANGEABILITY, SAFETY AND RELIABILITY... WORLDWIDE INTERCHANGEABILITY Many proprietary pin & sleeve configurations, that do not Walther’s pin & sleeve devices are built to IEC 309-1 and 309-2 conform to the IEC standards, are designed to accommodate specifications and are interchangeable with other manufacturers multiple voltage systems. A plug wired to a piece of equipment who conform to these IEC standards and color coding system... designed to operate at one voltage system could unintentionally anywhere in the world. Manufacturers that do not comply be plugged into a receptacle wired with an unlike voltage. with these standards have their own proprietary configurations Mismatching voltages could cause damage to the equipment or and are not plug compatible with other pin & sleeve products. even personal injury and is not considered safe electrical practice. Once you have selected a proprietary configuration you are locked in to a single source. Specifying IEC 309-1 & 309-2 The voltage, of single rated Pin & Sleeve devices of the IEC devices provides convenience and flexibility that users have 309-2 type, is determined by the location of the oversized come to accept almost without thinking. female ground contact relative to the key-way located at the bottom of the housing. A clock face is used to represent the SAFETY location of the ground sleeve for a specific voltage system. IEC 309-2 configurations for plugs (or inlets) and receptacles For example, a 480 VAC receptacle or connector will have the (or connectors) are single-rated which assures proper mating oversized ground sleeve located in the 7 o'clock position. The of devices with the same voltage and amperage. It is virtually corresponding grounding pin location on the plug or inlet is a impossible to couple a plug and receptacle of different voltage mirror image of the female device. Devices of mismatched volt- and /or amperage ratings. age systems simply cannot be mated. Each device is clearly The size of the device is determined by the amperage rating. marked with the voltage system for which it is intended to be Plugs and receptacles of different amperage ratings are not used. The diagram below shows the keying position and the compatible because of the size variance. color coding that is associated with each voltage system. Walther CEEtyp Clockface Positions in Accordance with IEC 309-2 and UL 1686 5 Wire 4 Wire 3 Wire 250/440V to 265/460V (60 Hz) 125/250V 440 to 460V (60 Hz) 50 to 600V 400Hz 5 Wire 4 Wire 3 Wire supply from an isolating transformer supply from an isolating transformer Over 50V 300 to 500 Hz Over 50V 300 to 500 Hz Over 50V 100 to 300 Hz 11 12 1 10 3ØY120/ 208V 2 Hour 9 3Ø250V 11 12 250VDC 380 (50Hz) 440 (60 Hz) 120/208 to 144/250V 200 to 250V 380 to 415V 4 8 7 6 480V 2 Hour 9 3 125V 7 Over 250VDC 6 5 480 to 500V 277V 220/380 380 (50Hz) (50 Hz) 440 (60 Hz) 250/440 (60 Hz)* 50 to 250VDC 4 8 5 250V 3Ø/480V 1 10 3 Over 50V 300 to 500 Hz 100 to 130V 100 to 130V 277V 57/100 to 75/130V 200 to 250V 3Ø600V 600 to 690V 480 to 500V 380 to 415V 3ØY277/480V 3ØY347/600 277/480 to 288/500V 347/600 to 400/690V 200/346 to 240/415V North American Rating Voltage AC (Except where noted) 2 International Rating Voltage AC (Except where noted) ...BROUGHT TO YOU BY WALTHER ELECTRIC The insulated housing is made from a high impact, nylon deposits of dirt and dust and splashing water. Splashproof material. The nonmetallic device, while abuse and corrosion devices provide many of the heavy duty construction features resistant, is also nonconductive, which enhances the safety found in the watertight products, but at a more economical of the product. cost. Splashproof devices are available in 20, 30 and 60 amp (North American) ratings and 16, 32 and 63 amp ELECTRICAL INTERLOCK (International) ratings. Watertight and splashproof devices provide exceptional UV stability for superior outdoor performance. All Walther plugs and connectors are supplied with an internal cord clamp designed to firmly grip not only the outer cable jacket but also the internal conductors. The internal cord clamp eliminates strain on the terminals while providing high pull-out Plugs and receptacles rated 60 amps and above, feature an “electrical interlock” by way of a pilot pin on the plug and female sleeve on the receptacle that is shorter than the main pins. The pilot pin and female sleeve make contact last, and break contact first. This sequence turns the power on when the pilot pin and sleeve mate, and turns the power off before the phase contacts are disengaged. This prevents making or breaking the circuit under load. values without external protrusions to snag adjacent wiring or the installer. In addition to the internal cord clamp, Watertight plugs and connectors are also supplied with an external cable gland. This cable gland serves as a secondary method of eliminating RELIABILITY strain on the terminals and conductors while assuring Walther offers the widest variety of plugs, receptacles, watertight performance. Standard splashproof plugs and connectors and inlets, made of the highest quality and design connectors are also supplied with the same external gland integrity in both splashproof and watertight versions. as the watertight devices. However, a cable sleeve, designed to speedup installation, is provided with a lower cost Watertight (IP67) devices are designed for use in the most splashproof alternative. demanding environments that require safety, ease of use, reliability and durability. These devices can withstand impact and All Walther plugs and connectors, furnished with either a cable vibration and provide complete protection against dirt, dust, gland or cable sleeve, meet the cord and cable secureness water jets and even temporary flooding. Watertight devices are requirements defined in UL 1682, Section 33. available in 20, 30, 60 and 100 amp (North American) ratings and 16, 32, 63 and 125 amp (International) ratings. Splashproof (IP44) devices are suitable and recommended for use in a variety of light industrial environments and provide complete protection against contact with live parts, damaging 3 IEC 309 PIN AND SLEEVE DEVICES • DEGREES OF PROTECTION TABLE 1 - CHARACTERISTICS DEFINED BY THE CEI 70-1 - IEC 529 - IEC 144 - UTE C 20-010 - DIN 40050 STANDARDS First Digit - Protection against persons - touching and ingress of solid foreign objects IP 0_ Without protection Second Digit - Protection against the penetration of liquids IP_0 IP_1 IP_2 IP_3 IP_4 IP_5 IP_6 IP_7 IP_8 Non protected Protection against vertical falling of water drops Protection against falling of water drops at an angle up to 15° from the vertical Protection against spraying water (rain) at an angle up to 60° from the vertical Protection against splashing water from any direction (360°) Protection against water jets from any direction (360°) Protection against heavy seas (waves) Protection against effects of immersion in water under defined conditions of pressure and time Protection against continuous submersion in water IP 66 IP 67 IP 68 IP 00 IP 1_ Protection against touching with the hand and solid objects greater than 50mm dia. IP 10 IP 11 IP 12 IP 2_ Protection against touching with the finger and solid objects greater than 12mm dia. IP 20 IP 21 IP 22 IP 23 IP 3_ Protection against touching with tools, wires, etc. more than 2.5mm thick and solid objects greater than 2.5mm dia. IP 30 IP 31 IP 32 IP 33 IP 34 IP 4_ Protection against touching with tools, wires, etc. more than 1mm thick and solid objects greater than 1mm dia. IP 40 IP 41 IP 42 IP 43 IP 44 IP 5_ Unlimited protection against contact with live parts and damaging deposits of dust IP 50 IP 6_ Unlimited protection against contact with live parts and any penetration of dust IP 60 IP 54 IP 55 IP 65 In some countries a third digit (for mechanical security) is added. TABLE 2 Designation Intended Use and Description Construction Requirements 3 Outdoor use primarily to provide a degree of protection against rain, sleet, windblown dust and damage from external ice formation. Splashproof (IP44) 4 Indoor and outdoor use primarily to provide a degree of protection against windblown dust and rain, splashing water, hose-directed water and damage from external ice formation. Watertight (IP67) 4X Indoor and outdoor use primarily to provide a degree of protection against corrosion, windblown dust and rain, splashing water, hose-directed water and damage from external ice formation. Watertight (IP67) 6 Indoor and outdoor use primarily to provide a degree of protection against hose-directed water, and the entry of water during occasional temporary submersion at a limited depth and damage from external ice formation. Watertight (IP67) Indoor use primarily to provide a degree of protection against circulating dust, falling dirt, and dripping non-corrosive liquids. Splashproof (IP44) 12, 12K This information is provided only as a general guide. No specific recommendation is intended. As each application may vary, testing should be conducted by the user in the intended environment. 4 IEC 309 PIN AND SLEEVE DEVICES Retaining Device Holds the plug in position when it is in proper engagement with a connector or socket-outlet and prevents its unintentional withdraw Internal Strain Relief with “Swing-Away” Feature Designed to firmly grip not only the outer cable jacket but also the internal conductors. Eliminates strain on the terminals while providing high pull-out values. “SwingAway” feature provides easy access to terminal screws. Reliability! Ease of Use! Shrouded Pins Pins are recessed in the nylon housing and protected from deforming due to physical abuse. Eliminates the potential hazard of touching the live contacts while the plug is partially engaged. Safety! Reliability! External Cable Gland with “Onion Ring” Neoprene Bushing The compression type cable gland serves as a secondary method of eliminating strain on the terminals and conductors while assuring watertight performance. Accommodates various cable sizes. Reliability! Ease of Use! Electro Zinc Plated Steel Screws Corrosion resistant. Captive no loose parts to handle or misplace. Durability! Ease of Use! Locking Ring and Gasket Protects against intrusion of dirt, dust and moisture when the male and female devices are connected. Reliability! Spring Loaded Gasketed Covers Terminal Identification Ground, neutral and phase terminals are clearly identified for easy recognition and ease of wiring. Color Coded Avoid mismatching. Prevents confusion with regards to voltage ratings. Safety! Ease of Use! Protects against accidental encounter with live contacts. Also, protects against intrusion of dirt, dust and moisture. A bayonet coupling device is used to provide optimum stability an simplify installation. Reliability! Safety! High Impact Thermoplastic Housing The nonmetalic device, while abuse and corrosion resistant, is also nonconductive, which enhances the safety of the product. The insulated housing is made from a high impact, nylon material and is UV stabilized. Safety! Durability Staggered Contacts Oversized ground contact is farthest forward, assuring first make and last break. Neutral is next to prevent the possibility of an “open neutral” condition. Phase contact is farthest making it last to make, first to break. Safety! Retaining Device Double Terminal Screws Walther pin & sleeve devices are provided with a mechanical arrangement which holds a plug or connector in position when it is in proper engagement, and prevents its unintentional withdraw. Maximum clamping pressure without damaging strands. Double terminal screws create a large area of safe and secure contact between conductor and terminal. Screws are captive, easily accessible and supplied in the open position. Reliability! Safety! Split Contact Sleeve with Nickel Plated Steel Springs Provides optimum insertion/withdraw force and constant contact pressure Reliability! Recessed Contacts Contact sleeves are recessed in the narrow contact tubes thus, providing a “finger proof” device and protecting against any accidental encounter with live contacts. Safety! Solid Brass Pins Low contact resistance and high conductivity. Long lasting, reliable electrical contact. Reliability! Chamfered Terminals Funnel Entry. Guides and captures all wire strands. Ease of Use! Reliability! 5 IEC 309 PIN & SLEEVE DEVICES • MATERIALS PLUG CONNECTOR Assembly Screws* Friction Ring* Gland Cap Grommet Housing (Front and Back) Internal Cord Clamp Locking Ring Pins (Watertight) Pins (Splashproof) Sealing Gasket Terminal Screws Steel, Electro Zinc Plated Steel, Electro Zinc Plated Polycarbonate Blend Solid Neoprene Type 6 Nylon Type 6 Nylon Type 6 Nylon Brass, Nickel Plated Brass Neoprene Steel, Nickel Plated INLET Housing Locking Ring Mounting Flange Pins (Watertight) Pins (Splashproof) Sealing Gasket Terminal Screws Type 6 Nylon Type 6 Nylon Type 6 Nylon Brass, Nickel Plated Brass Neoprene Steel, Nickel Plated * Stainless steel available upon request Assembly Screws* Cover Cover Fastener Cover Spring Friction Ring* Gland Cap Grommet Housing (Front and Back) Internal Cord Clamp Sealing Gasket Sleeve Spring Sleeves (Watertight) Sleeves (Splashproof) Terminal Screws Steel, Electro Zinc Plated Type 6 Nylon Nickel Plated Brass, Brass or Macrolon Stainless Steel (A2) Steel, Electro Zinc Plated Polycarbonate Blend Solid Neoprene Type 6 Nylon Type 6 Nylon Neoprene Steel, Nickel Plated Brass, Nickel Plated Brass Steel, Nickel Plated RECEPTACLE Cover Cover Fastener Cover Spring Housing Mounting Flange Sealing Gasket Sleeve Spring Sleeves (Watertight) Sleeves (Splashproof) Terminal Screws Type 6 Nylon Nickel Plated Brass, Brass or Macrolon Stainless Steel (A2) Type 6 Nylon Type 6 Nylon Neoprene Steel, Nickel Plated Brass, Nickel Plated Brass Steel, Nickel Plated Manufacturing pin & sleeve devices, of superior quality, can only be accomplished through the use of high grade materials. That is an important part of the Walther Pin & Sleeve system – quality products you can depend on. Male pins and female sleeves are made of high conductivity brass. Contacts used with watertight devices are nickel plated to prevent corrosion.The insulated housing is made from a high impact, nylon material. The nonmetallic device, while resistant to most solvents, chemicals and salt water, is also nonconductive, which enhances the safety of the product. DIN EN ISO 9001 6 Certificate Registration No. 4678-01 IEC 309 PIN & SLEEVE DEVICES • PERFORMANCE SPECIFICATIONS • NORTH AMERICAN RATINGS ELECTRICAL Insulation Resistance 500V for 1 min. Resistance ≥ 5MΩ Dielectric Voltage Withstand 3000V for 1 min. Ground Path Current See Table 1 Endurance, Connect and Disconnect Cycles See Table 2 Current Interrupting Certified for current interrupting at full rated current and voltage. Overload Test Tested for current interrupting at (Power factor 0.75 - 0.80) 150% of the rated current and 100% of the rated voltage for 50 cycles. Temperature Rise Maximum 30° C rise at full rated current (after overload). Resistance to Arcing Continuation of overload test for an additional 200 cycles. MECHANICAL Mold Stress Relief Humidity Cable Secureness Impact Crushing Withdrawal Force Strength of Insulating Base and Support Polarization Integrity 70°C (158°F) for 7 hours. 32°C (89.6°F), 93% humidity for 7 days (168 hours). See Table 3 A device is wired with a 90” (2300mm) length of flexible cord and dropped from 30” (760mm) 8 times. The device is then conditioned for 6 hours at -25°C and immediately subjected to a repeated impact test. 250 lbs for 1 minute. The device is then conditioned for 6 hours at -25°C and immediately subjected to a repeated crushing test. See Table 4 110% of specified tightening torque on terminal screws. Matching devices will not mate so that the ground is energized, even when polarization feature is removed and 40 lb (180 N) insertion force is applied. ENVIRONMENTAL V-2 or better per UL 94 or CSA 22.2 No. 0.6 Minimum: -25°C (-13°F) with impact Maximum: 90°C (194°F) Ferrous parts immersed for 10 min. in a 10% solution of ammonium chloride at a temperature of 20°C. Moisture Resistance Watertight (IP67): Device immersed for 24 hours in water at a temp. of 25°C, the highest point of the device being 2” (5cm) below the water level. Splashproof (IP44): Device is sprayed with water for 10 minutes and immediately afterwards subjected to splashing water in all directions (360°). UV Resistance Exposed plastic materials are UV stabilized. Flammability Ambient Temperature Range Resistance to Corrosion TABLE 1 Ground Path Current Test Device Minimum Size Test Rating Grounding Conductor Time, Current, Amperes Seconds Amperes AWG mm2 20 12 3.3 4 470 30 10 5.3 4 750 60 10 5.3 4 750 100 8 8.4 4 1180 A test current that far exceeds the device rating, is passed through the mating devices and grounding wires. TABLE 2 Endurance Test Cycles with Device Load at Rated Rating Current and No-Load Amperes Voltage Cycles Sequence 20 5000 0 30 1000 1000 Alternating 60 1000 1000 Alternating 100 250 250 Alternating The test sequence is conducted by using a no-load, followed by a load sequence. The power factor of the load is 0.75 to 0.80. TABLE 3 Cable Secureness Test Device Maximum Force Torque Displacement Rating Amperes lb. N ft-lb. N•m Inches mm 20 30 133 0.4 0.54 3/32 2.38 30 75 333 0.5 0.68 3/32 2.38 60 150 667 1.0 1.4 3/32 2.38 100 150 667 2.0 2.7 3/32 2.38 The flexible cord or cable is simultaneously twisted and pulled. Values for the applied twisting torque and force of pull are shown in Table 3. In all cases the cord displacement is less than 3/32 inches. TABLE 4 Withdrawal Forces Test Device Minimum Withdrawal Force Rating Amperes lb. N Time, Minutes 20 5 22 1 30 6 27 1 60 15 67 1 100 20 89 1 The pressure exerted by mating contacts of a plug and connector must be sufficient to prevent unintentional withdrawal during normal use. During the test, any locking rings or retaining means are not to be engaged. These products are Listed to applicable UL Standards and requirements by Underwriters Laboratories Inc. UL 1682 UL 1686 Certified 7 20 AMPS IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS MALE PLUGS WATERTIGHT (IP67) Certified Poles and Wires 3 4 5 7 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G Voltage AC (Except where noted) 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 3 4 6 5 7 12 9 7 5 1 9 7 5 9 7 Barge Overflow 3ØY120/208 3ØY277/480 3ØY347/600 250 480 219315 219316 219306 219317 219319 218424 218409 218419 218405 218501BL 218509 218519 218505 3 4 5 7 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G 8 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 Barge Overflow 3ØY120/208 3ØY277/480 3ØY347/600 250 480 Economical Version (with cable sleeve) Low Profile Angled 90° 211315 211316 211306 211317 211319 212424 212409 212419 212405 210315 210316 210306 210317 210319 210424 210409 210419 210405 216315 216316 216306 216317 216319 216424 216409 216419 216405 212509 212519 212505 212709 212719 210509 210519 210505 210709 210719 216509 216519 216505 WATERTIGHT (IP67) Certified Voltage AC (Except where noted) Standard Version (with cable gland) Clock Position of Ground Contact FEMALE CONNECTORS Poles and Wires SPLASHPROOF (IP44) SPLASHPROOF (IP44) Standard Version (with cable gland) Economical Version (with cable sleeve) Low Profile Angled 90° 311315 311316 311306 311317 311319 312424 312409 312419 312405 310315 310316 310306 310317 310319 310424 310409 310419 310405 316315 316316 316306 316317 316319 312509 312519 312505 312709 312719 310509 310519 310505 310709 310719 Clock Position of Ground Contact 3 4 6 5 7 12 9 7 5 1 9 7 5 9 7 319315 319316 319306 319317 319319 318424 318409 318419 318405 318501BL 318509 318519 318505 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS FEMALE RECEPTACLES WATERTIGHT (IP67) Certified Poles and Wires 3 4 5 7 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G Voltage AC (Except where noted) 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 Barge Overflow 3ØY120/208 3ØY277/480 3ØY347/600 250 480 20 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 419315 419316 419306 419317 419319 419424 419409 419419 419405 419501BL 419509 419519 419505 519315 519316 519306 519317 519319 519424 519409 519419 519405 519501BL 519509 519519 519505 518315 518316 518306 518317 518319 518424 518409 518419 518405 518501BL 518509 518519 518505 410315 410316 410306 410317 410319 410424 410409 410419 410405 510315 510316 510306 510317 510319 510424 510409 510419 510405 514315 514316 514306 514317 514319 514424 514409 514419 514405 410509 410519 410505 411709 411719 510509 510519 510505 514509 514519 514505 514709 514719 Clock Position of Ground Contact 3 4 6 5 7 12 9 7 5 1 9 7 5 9 7 Note: See pages 16 and 17 for surface mount receptacles and back boxes. MALE INLETS WATERTIGHT (IP67) Certified Poles and Wires 3 4 5 7 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G Voltage AC (Except where noted) 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 Barge Overflow 3ØY120/208 3ØY277/480 3ØY347/600 250 480 Angled 80° Surface Mount* 619315 619316 619306 619317 619319 619424 619409 619419 619405 619501BL 619509 619519 619505 618315 618316 618306 618317 618319 618424 618409 618419 618405 618501BL 618509 618519 618505 SPLASHPROOF (IP44) Straight Angled 80° Surface Mount* 615315 615316 615306 615317 615319 615424 615409 615419 615405 611315 611316 611306 611317 611319 611424 611409 611419 611405 616424 616409 616419 616405 615509 615519 615505 615709 615719 611509 611519 611505 611709 611719 616509 616519 616505 616709 616719 Clock Position of Ground Contact 3 4 6 5 7 12 9 7 5 1 9 7 5 9 7 * Classified by Underwriters Laboratories Inc. to IEC Standards 309-1 and 309-2. 9 30 AMPS IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS MALE PLUGS WATERTIGHT (IP67) Certified 3 4 5 7 Poles and Wires Voltage AC (Except where noted) Clock Position of Ground Contact 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G 250 DC 125 250 277 480 125/250 3Ø250 380/440* 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 250 480 3 4 6 5 7 12 9 3 7 5 2 9 7 5 9 7 FEMALE CONNECTORS 239315 239316 239306 239317 239319 238424 238409 238403* 238419 238405 238502 238509 238519 238505 SPLASHPROOF (IP44) Standard Version (with cable gland) Economical Version (with cable sleeve) Low Profile Angled 90° 231315 231316 231306 231317 231319 232424 232409 230315 230316 230306 230317 230319 230424 230409 236315 236316 236306 236317 236319 236424 236409 232419 232405 232502 232509 232519 232505 232709 232719 230419 230405 230502 230509 230519 230505 230709 230719 236419 236405 236502 236509 236519 236505 WATERTIGHT (IP67) Certified 3 4 5 7 Poles and Wires Voltage AC (Except where noted) Clock Position of Ground Contact 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G 250 DC 125 250 277 480 125/250 3Ø250 380/440* 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 250 480 3 4 6 5 7 12 9 3 7 5 2 9 7 5 9 7 339315 339316 339306 339317 339319 338424 338409 338403* 338419 338405 338502 338509 338519 338505 * Only for refrigerated containers. Supplied with stainless steel assembly screws and friction ring. 10 SPLASHPROOF (IP44) Standard Version (with cable gland) Economical Version (with cable sleeve) 331315 331316 331306 331317 331319 332424 332409 330315 330316 330306 330317 330319 330424 330409 332419 332405 332502 332509 332519 332505 332709 332719 330419 330405 330502 330509 330519 330505 330709 330719 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS FEMALE RECEPTACLES WATERTIGHT (IP67) Certified 3 4 5 7 Poles and Wires Voltage AC (Except where noted) Clock Position of Ground Contact 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G 250 DC 125 250 277 480 125/250 3Ø250 380/440* 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 250 480 3 4 6 5 7 12 9 3 7 5 2 9 7 5 9 7 30 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 439315 439316 439306 439317 439319 439424 439409 439403* 439419 439405 439502 439509 439519 439505 539315 539316 539306 539317 539319 539424 539409 538315 538316 538306 538317 538319 538424 538409 430315 430316 430306 430317 430319 430424 430409 530315 530316 530306 530317 530319 530424 530409 534315 534316 534306 534317 534319 534424 534409 539419 539405 539502 539509 539519 539505 538419 538405 538502 538509 538519 538505 430419 430405 430502 430509 430519 430505 431709 431719 530419 530405 530502 530509 530519 530505 534419 534405 534502 534509 534519 534505 534709 534719 Note: See pages 16 and 17 for surface mount receptacles and back boxes. MALE INLETS WATERTIGHT (IP67) Certified 3 4 5 7 Poles and Wires Voltage AC (Except where noted) Clock Position of Ground Contact 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 6P + G 6P + G 250 DC 125 250 277 480 125/250 3Ø250 380/440* 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 250 480 3 4 6 5 7 12 9 3 7 5 2 9 7 5 9 7 Angled 80° Surface Mount** 639315 639316 639306 639317 639319 639424 639409 639403* 639419 639405 639502 639509 639519 639505 638315 638316 638306 638317 638319 638424 638409 638403* 638419 638405 638502 638509 638519 638505 SPLASHPROOF (IP44) Straight Angled 80° Surface Mount** 635315 635316 635306 635317 635319 635424 635409 631315 631316 631306 631317 631319 631424 631409 636315 636316 636306 636317 636319 636424 636409 635419 635405 635502 635509 635519 635505 635709 635719 631419 631405 631502 631509 631519 631505 631709 631719 636419 636405 636502 636509 636519 636505 636709 636719 * Only for refrigerated containers. ** Classified by Underwriters Laboratories Inc. to IEC Standards 309-1 and 309-2. 11 60 AMPS IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS MALE PLUGS WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 2 9 7 5 FEMALE CONNECTORS 269315 269316 269306 269317 269319 269424 269409 269419 269405 269502 269509 269519 269505 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G 12 Standard Version (with cable gland) Economical Version (with cable sleeve) 261315 261316 261306 261317 261319 261424 261409 261419 261405 261502 261509 261519 261505 260315 260316 260306 260317 260319 260424 260409 260419 260405 260502 260509 260519 260505 WATERTIGHT (IP67) Certified Poles and Wires (With pilot) SPLASHPROOF (IP44) Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 2 9 7 5 369315 369316 369306 369317 369319 369424 369409 369419 369405 369502 369509 369519 369505 SPLASHPROOF (IP44) Standard Version (with cable gland) Economical Version (with cable sleeve) 361315 361316 361306 361317 361319 361424 361409 361419 361405 361502 361509 361519 361505 360315 360316 360306 360317 360319 360424 360409 360419 360405 360502 360509 360519 360505 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS FEMALE RECEPTACLES WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 2 9 7 5 60 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 469315 469316 469306 469317 469319 469424 469409 469419 469405 469502 469509 469519 469505 569315 569316 569306 569317 569319 569424 569409 569419 569405 569502 569509 569519 569505 568315 568316 568306 568317 568319 568424 568409 568419 568405 568502 568509 568519 568505 460315 460316 460306 460317 460319 460424 460409 460419 460405 460502 460509 460519 460505 560315 560316 560306 560317 560319 560424 560409 560419 560405 560502 560509 560519 560505 564315 564316 564306 564317 564319 564424 564409 564419 564405 564502 564509 564519 564505 Note: See pages 16 and 17 for surface mount receptacles and back boxes. MALE INLETS WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 3P + N + G Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 50-600 400Hz 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 2 9 7 5 Angled 80° Surface Mount* 669315 669316 669306 669317 669319 669424 669409 669419 669405 669502 669509 669519 669505 668315 668316 668306 668317 668319 668424 668409 668419 668405 668502 668509 668519 668505 SPLASHPROOF (IP44) Straight Angled 80° 665502 665509 665519 665505 661315 661316 661306 661317 661319 661424 661409 661419 661405 661502 661509 661519 661505 * Classified by Underwriters Laboratories Inc. to IEC Standards 309-1 and 309-2. 13 100 AMPS IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS MALE PLUGS WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 9 7 5 FEMALE CONNECTORS 279315 279316 279318 279317 279319 279424 279421 279419 279417 279521 279519 279517 WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 14 14 Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 9 7 5 379315 379316 379318 379317 379319 379424 379421 379419 379417 379521 379519 379517 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS FEMALE RECEPTACLES WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G 100 AMPS Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 9 7 5 Straight Angled 15° 479315 479316 479318 479317 479319 479424 479421 479419 479417 479521 479519 479517 579315 579316 579318 579317 579319 579424 579421 579419 579417 579521 579519 579517 Note: See pages 16 and 17 for surface mount receptacles and back boxes. MALE INLETS WATERTIGHT (IP67) Certified Poles and Wires (With pilot) 3 4 5 2P + G 1P + N + G 2P + G 1P + N + G 2P + G 2P + N + G 3P + G 3P + G 3P + G 3P + N + G 3P + N + G 3P + N + G Voltage AC (Except where noted) Clock Position of Ground Contact 250 DC 125 250 277 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 3 4 6 5 7 12 9 7 5 9 7 5 Straight Surface Mount* 679315 679316 679318 679317 679319 679424 679421 679419 679417 679521 679519 679517 678315 678316 678318 678317 678319 678424 678421 678419 678417 678521 678519 678517 * Classified by Underwriters Laboratories Inc. to IEC Standards 309-1 and 309-2. 15 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS SURFACE MOUNT RECEPTACLES Certified No. of Wires 3 4 5 7 Voltage AC 2P + G 250 DC 1P + N + G 125 2P + G 250 1P + N + G 277 2P + G 480 2P + N + G 125/250 3P + G 3Ø250 3P + G 380/440** 3P + G 3Ø480 3P + G 3Ø600 3P + N + G Barge Overflow 3P + N + G 3ØY120/208 3P + N + G 3ØY277/480 3P + N + G 3ØY347/600 6P + G 250 6P + G 480 WATERTIGHT (IP67) 20 Amps 30 Amps 119315 119316 119306 119317 119319 119424 119409 139315 139316 139306 139317 139319 139424 139409 139403* 139419 139405 SPLASHPROOF (IP44) 60 Amps 100 Amps 20 Amps 30 Amps 60 Amps 169424 169409 179315 179316 179318 179317 179319 179424 179421 111315 111316 111306 111317 111319 111424 111409 131315 131316 131306 131317 131319 131424 131409 161424 161409 169419 169405 179419 179417 111419 111405 131419 131405 161419 161405 169509 169519 169505 179521 179519 179517 111509 111519 111505 111709 111719 131509 131519 131505 131709 131719 161509 161519 161505 Clock Position of Ground Contact 3 4 6 5 7 12 9 3 7 5 1 9 7 5 9 7 119419 119405 119501BL 119509 119519 119505 139509 139519 139505 * Only for refrigerated containers. **Surface mount receptacles combine a back box and receptacle into one compact device. 16 IEC 309 PIN & SLEEVE DEVICES • ACCESSORIES BACK BOXES for use with Walther watertight and splashproof receptacles. Cat. No. BE3-B75 BE3-B100 BE6-B125 BE6-B150 BE10-B150 BE10-B200 Description Hub Size A 20° angle for 20A, ⁄4” 3.34 4 and 5 wire receps. 1” and all 30A receps. 20° angle for all 1 1⁄4” 4.41 60A receptacles 1 1⁄2” 20° angle for all 1 1⁄2” 100A receptacles 2” 5.18 3 B Dimensions (inches) C D E F Cubic Inch Capacity G 0.97 1.12 4.12 4.00 0.25 20.4 1.41 2.09 5.63 5.00 0.28 3.00 59.7 1.78 2.50 7.71 5.50 .34 4.00 96.6 NOTE: For availability of straight back boxes, please contact technical service Cast Aluminum Junction Boxes for Watertight and Splashproof Receptacles Epoxy-coated junction boxes are corrosion resistant and designed to pass the 500-hour salt spray test and the UL hosedown and external icing test. BACK BOX ADAPTER PLATES for use with Hubbell back boxes. Cat. No. BB20-3W BB20-345W BB60-345W BB100-345W Walther Receptacle 20A, 3 Wire 20A, 4 & 5 Wire 30A, 3, 4 & 5 Wire 60A, 3, 4 &5 Wire 100A, 3, 4 & 5 Wire For use with Hubbell Back Box BB201W, BB301W, FT202W or FT302W BB201W, BB301W, FT202W or FT302W BB601W, BB602W or FW60/100 BB1001W, BB1002W or FW60/100 17 IEC 309 PIN & SLEEVE DEVICES • NORTH AMERICAN RATINGS • ACCESSORIES METRIC PG THREAD TO NPT THREAD ADAPTERS Cat. No. PG11-38 PG11-50 PG135-50 PG16-50 PG21-75 PG29-100 PG29-125 PG36-125 Description PG11 to 3⁄8” NPT Adapter PG11 to 1⁄2” NPT Adapter PG13,5 to 1⁄2” NPT Adapter PG16 to 1⁄2” NPT Adapter PG21 to 3⁄4” NPT Adapter PG29 to 1” NPT Adapter PG29 to 1 1⁄4” NPT Adapter PG36 to 1 1⁄4” NPT Adapter Std. Pkg. 25 25 25 25 25 10 5 5 For PG thread sizes to NPT thread sizes not shown, consult technical service for price, delivery and minimum order quantities. WATERTIGHT CLOSURE CAPS for use with watertight male plugs and inlets Cat. No. 613300 633400 663500 673500 613400 633400 663500 673500 613500 633500 663500 673500 SPLASHPROOF CLOSURE CAPS Poles and Wires 3 Wire 4 Wire 5 Wire Amperage Rating 20 30 60 100 20 30 60 100 20 30 60 100 Std. Pkg Quantity 5 5 2 2 5 5 2 2 5 5 2 2 Amperage Rating 20 30 60 20 30 60 20 30 60 Std. Pkg Quantity 5 5 2 5 5 2 5 5 2 for use with splashproof male plugs and inlets Cat. No. 614300 634400 664500 614400 634400 664500 614500 634500 664500 Poles and Wires 3 Wire 4 Wire 5 Wire PRE-INSTALLED CLOSURE CAPS Closure caps provide watertight or splashproof protection to disconnected plugs and inlets. The possibility of removing or misplacing the cap can be eliminated by securing the chain or nylon strap to the inlet flange. If the closure cap will be fastened to a plug, Walther can pre-install the cap on the device. This factory installation assures safe and reliable utilization of the two components. Contact customer service for ordering information. 18 IEC 309 PIN & SLEEVE DEVICES • PERFORMANCE SPECIFICATIONS • INTERNATIONAL RATINGS ELECTRICAL Insulation Resistance Per IEC 309-1, Clause 19 Dielectric Strength Per IEC 309-1, Clause 19 Norm. Operation, Connect & Disconnect Cycles Per IEC 309-1, Clause 21 Breaking Capacity Per IEC 309-1, Clause 20 Temperature Rise Per IEC 309-1, Clause 22 500V for 1 min. Resistance ≥ 5MΩ 3000V for 1 min. See Table 1 Tested at 110 % of the rated operating voltage and 125% of the rated current. Maximum 50 K rise at full rated current. See Table 2 A device is wired with a 2.25m length of flexible cord and dropped from a height of 75 cm, 8 times. The device is then tested for applicable degrees of protection against moisture. ENVIRONMENTAL Flammability Ambient Temperature Range Moisture Resistance UV Resistance Connect and Disconnect Cycles Cycles with Device Load at Rated Rating Current and No-Load Amperes Voltage Cycles Sequence 16 5000 p.f of 0.6 0 32 1000 p.f of 0.6 1000 Alternating 63 1000 p.f of 0.6 1000 Alternating 125 250 p.f of 0.7 250 Alternating The test sequence is conducted by using a no-load, followed by a load sequence. TABLE 2 MECHANICAL Cable Secureness Per IEC 309, Clause 23 Impact Per IEC 309, Clause 24 TABLE 1 Cable Secureness Test Device Maximum Rating Force Torque Displacement Amperes N N•m mm 16 80 0.350 2 32 100 0.425 2 63 120 0.8 2 125 200 1.5 2 The flexible cord or cable is twisted and pulled. Values for the applied twisting torque and force of pull are shown in Table 2. In all cases the cord displacement is less than 2mm. Self-extinguishing Per IEC 309-1, Clause 27 Minimum: -25°C with impact Maximum: 90°C Watertight (IP67): Device immersed for 24 hours in water at a temp. of 25°C, the highest point of the device being 5cm (2”) below the water level. Splashproof (IP44): Device is sprayed with water for 10 minutes and immediately afterwards subjected to splashing water in all directions (360°). Exposed plastic materials are UV stabilized. DECLARATION OF CONFORMITY WALTHER WERKE, Ferdinand Walther GmbH Ramsener Strasse 6 67304 Eisenberg We declare, under our sole responsibility, the conformity of the following products and standards: Plugs and Sockets (Pin and Sleeve devices) DIN EN 60 309, T. 1/BS 4343 DIN EN 60 309, T. 2 DIN EN ISO 9001 Certificate Registration No. 4678-01 This declaration of conformity is according to the EC regulations 73/23, 91/368 and 89/336 (Low Voltage Directive), module A, in consideration of DIN EN 45 014. 19 16 AMPS IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS MALE PLUGS No. of Wires WATERTIGHT (IP67) Voltage AC 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G Voltage AC 4 5 20 20 with cable gland with cable sleeve Angled 90° 211304 211306 211309 211404 211409 211406 211411 211407 211410 211402 211504 211509 211 211511 211706 210304 210306 210309 210404 210409 210406 210411 210407 210410 210402 210504 210509 210 210511 210706 216304 216306 216309 216404 216409 216406 216411 216407 216410 216402 216504 216509 216 216511 Clock Position of Ground Contact 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 FEMALE CONNECTORS (Couplers) No. of Wires SPLASHPROOF (IP44) 219304 219306 219309 219404 219409 219406 219411 219407 219410 219402 219504 219509 219 219511 WATERTIGHT (IP67) SPLASHPROOF (IP44) with cable gland with cable sleeve Angled 90° 311304 311306 311309 311404 311409 311406 311411 311407 311410 311402 311504 311509 311 311511 311706 310304 310306 310309 310404 310409 310406 310411 310407 310410 310402 310504 310509 310 310511 310706 316304 316306 316309 Clock Position of Ground Contact 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 319304 319306 319309 319404 319409 319406 319411 319407 319410 319402 319504 319509 319 319511 IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS FEMALE PANEL MOUNTED SOCKET-OUTLET No. of Wires Voltage AC 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 WATERTIGHT (IP67) 16 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 419304 419306 419309 419404 419409 419406 419411 419407 419410 419402 419504 419509 419 419511 519304 519306 519309 519404 519409 519406 519411 519407 519410 519402 519504 519509 519 519511 518304 518306 518309 518404 518409 518406 518411 518407 518410 518402 518504 518509 518 518511 410304 410306 410309 410404 410409 410406 410411 410407 410410 410402 410504 410509 410 410511 411706 510304 510306 510309 510404 510409 510406 510411 510407 510410 510402 510504 510509 510 510511 514304 514306 514309 514404 514409 514406 514411 514407 514410 514402 514504 514509 514 514511 514706 Clock Position of Ground Contact 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 Note: See page 28 for surface mount socket-outlets. MALE APPLIANCE PLUG (Inlet) No. of Wires 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 4 5 2P + G Voltage AC WATERTIGHT (IP67) Angled 80° Surface Mount 619304 619306 619309 619404 619409 619406 619411 619407 619410 619402 619504 619509 619 619511 618304 618306 618309 618404 618409 618406 618411 618407 618410 618402 618504 618509 618 618511 SPLASHPROOF (IP44) Straight Angled 80° 615304 615306 615309 615404 615409 615406 615411 615407 615410 615402 615504 615509 615 615511 615706 611304 611306 611309 611404 611409 611406 611411 611407 611410 611402 611504 611509 611 611511 611706 Surface Mount Surface Mount External Mounting Internal Mounting Clock Position of Ground Contact 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 610304 610306 610309 610404 610409 610406 610411 610407 610410 610402 610504 610509 610 610511 610706 616404 616409 616406 616411 616407 616410 616402 616504 616509 616 616511 616706 21 32 AMPS IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS MALE PLUGS No. of Wires WATERTIGHT (IP67) Voltage AC 110 230 400 3P + G 110 230 400 380/440* 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 7 6P + G 400 3 2P + G 4 5 Voltage AC 110 230 400 3P + G 110 230 400 380/440* 440 500 >50 (100/300Hz) >50 (300/500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 * Only for refrigerated containers. 22 22 with cable gland with cable sleeve Angled 90° 231304 231306 231309 231404 231409 231406 230304 230306 230309 230404 230409 230406 236304 236306 236309 236404 236409 236406 231411 231407 231410 231402 231504 231509 231 231511 231706 230411 230407 230410 230402 230504 230509 230 230511 230706 236411 236407 236410 236402 236504 236509 236 236511 Clock Position of Ground Contact 4 6 9 4 9 6 3 11 7 10 2 4 9 6 11 6 FEMALE CONNECTORS (Couplers) No. of Wires SPLASHPROOF (IP44) 239304 239306 239309 239404 239409 239406 239403* 239411 239407 239410 239402 239504 239509 239 239511 WATERTIGHT (IP67) SPLASHPROOF (IP44) with cable gland with cable sleeve 331304 331306 331309 331404 331409 331406 330304 330306 330309 330404 330409 330406 331411 331407 331410 331402 331504 331509 331 331511 331706 330411 330407 330410 330402 330504 330509 330 330511 330706 Clock Position of Ground Contact 4 6 9 4 9 6 3 11 7 10 2 4 9 6 11 6 339304 339306 339309 339404 339409 339406 339403* 339411 339407 339410 339402 339504 339509 339 339511 IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS FEMALE PANEL MOUNTED SOCKET-OUTLET No. of Wires Voltage AC 110 230 400 3P + G 110 230 400 380/440* 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 WATERTIGHT (IP67) 32 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 439304 439306 439309 439404 439409 439406 439403* 439411 439407 439410 439402 439504 439509 439 439511 539304 539306 539309 539404 539409 539406 538304 538306 538309 538404 538409 538406 430304 430306 430309 430404 430409 430406 530304 530306 530309 530404 530409 530406 534304 534306 534309 534404 534409 534406 539411 539407 539410 539402 539504 539509 539 539511 538411 538407 538410 538402 538504 538509 538 538511 430411 430407 430410 430402 430504 430509 430 430511 431706 530411 530407 530410 530402 530504 530509 530 530511 534411 534407 534410 534402 534504 534509 534 534511 534706 Clock Position of Ground Contact 4 6 9 4 9 6 3 11 7 10 2 4 9 6 11 6 Note: See page 28 for surface mount socket-outlets. MALE APPLIANCE PLUG (Inlet) No. of Wires Voltage AC 110 230 400 3P + G 110 230 400 380/440* 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 WATERTIGHT (IP67) Angled 80° Surface Mount 639304 639306 639309 639404 639409 639406 639403* 639411 639407 639410 639402 639504 639509 639 639511 638304 638306 638309 638404 638409 638406 638403* 638411 638407 638410 638402 638504 638509 638 638511 SPLASHPROOF (IP44) Surface Mount Surface Mount External Mounting Internal Mounting Straight Angled 80° 635304 635306 635309 635404 635409 635406 631304 631306 631309 631404 631409 631406 630304 630306 630309 630404 630409 630406 636304 636306 636309 636404 636409 636406 635411 635407 635410 635402 635504 635509 635 635511 635706 631411 631407 631410 631402 631504 631509 631 631511 631706 630411 630407 630410 630402 630504 630509 630 630511 630706 636411 636407 636410 636402 636504 636509 636 636511 636706 Clock Position of Ground Contact 4 6 9 4 9 6 3 11 7 10 2 4 9 6 11 6 * Only for refrigerated containers. 23 63 AMPS IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS MALE PLUGS No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 WATERTIGHT (IP67) Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 FEMALE CONNECTORS (Couplers) No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 24 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 269304 269306 269309 269404 269409 269406 269411 269407 269504 269509 269 269511 SPLASHPROOF (IP44) with cable gland with cable sleeve 261304 261306 261309 261404 261409 261406 261411 261407 261504 261509 261 261511 260304 260306 260309 260404 260409 260406 260411 260407 260504 260509 260 260511 WATERTIGHT (IP67) 369304 369306 369309 369404 369409 369406 369411 369407 369504 369509 369 369511 SPLASHPROOF (IP44) with cable gland with cable sleeve 361304 361306 361309 361404 361409 361406 361411 361407 361504 361509 361 361511 360304 360306 360309 360404 360409 360406 360411 360407 360504 360509 360 360511 IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS FEMALE PANEL MOUNTED SOCKET-OUTLET No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 WATERTIGHT (IP67) 63 AMPS SPLASHPROOF (IP44) Straight Angled 15° Angled 80° Straight Angled 15° Angled 80° 469304 469306 469309 469404 469409 469406 469411 469407 469504 469509 469 469511 569304 569306 569309 569404 569409 569406 569411 569407 569504 569509 569 569511 568304 568306 568309 568404 568409 568406 568411 568407 568504 568509 568 568511 460304 460306 460309 460404 460409 460406 460411 460407 460504 460509 460 460511 560304 560306 560309 560404 560409 560406 560411 560407 560504 560509 560 560511 564304 564306 564309 564404 564409 564406 564411 564407 564504 564509 564 564511 Note: See page 28 for surface mount receptacles. MALE APPLIANCE PLUG (Inlet) No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 WATERTIGHT (IP67) Angled 80° Surface Mount 669304 669306 669309 669404 669409 669406 669411 669407 669504 669509 669 669511 668304 668306 668309 668404 668409 668406 668411 668407 668504 668509 668 668511 SPLASHPROOF (IP44) Straight Angled 80° 665504 665509 665 665511 661304 661306 661309 661404 661409 661406 661411 661407 661504 661509 661 661511 25 125 AMPS IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS MALE PLUGS No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 WATERTIGHT (IP67) Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 FEMALE CONNECTORS (Couplers) No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 26 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 279304 279306 279309 279404 279409 279406 279411 279407 279504 279509 279 279511 WATERTIGHT (IP67) 379304 379306 379309 379404 379409 379406 379411 379407 379504 379509 379 379511 IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS FEMALE PANEL MOUNTED SOCKET-OUTLET No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 125 AMPS WATERTIGHT (IP67) Straight Angled 15° 479304 479306 479309 479404 479409 479406 479411 479407 479504 479509 479 479511 579304 579306 579309 579404 579409 579406 579411 579407 579504 579509 579 579511 Note: See page 28 for surface mount receptacles. MALE APPLIANCE PLUG (Inlet) No. of Wires 3 2P + G 3P + G 4 3P + N + G 5 Voltage AC Clock Position of Ground Contact 110 230 400 110 230 400 440 500 110 230 400 440 4 6 9 4 9 6 11 7 4 9 6 11 WATERTIGHT (IP67) Straight Surface Mount 679304 679306 679309 679404 679409 679406 679411 679407 679504 679509 679 679511 678304 678306 678309 678404 678409 678406 678411 678407 678504 678509 678 678511 27 IEC 309 PIN & SLEEVE DEVICES • INTERNATIONAL RATINGS SURFACE MOUNT SOCKET-OUTLETS (Internal Mounting) No. of Wires Voltage AC 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G 4 5 WATERTIGHT (IP67) 16 Amps 32 Amps 119304 119306 119309 119404 119409 119406 119411 119407 119410 119402 119504 119509 119 119511 139304 139306 139309 139404 139409 139406 139411 139407 139410 139402 139504 139509 139 139511 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 (External Mounting) 110 230 400 3P + G 110 230 400 440 500 >50 (100-300Hz) >50 (300-500Hz) 3P + N + G 110 230 400 440 400 7 6P + G 3 2P + G Voltage AC 4 5 28 63 Amps 125 Amps 16 Amps 32 Amps 169404 169409 169406 169411 169407 169410 169402 169504 169509 169 169511 179304 179306 179309 179404 179409 179406 179411 179407 179410 179402 179504 179509 179 179511 111304 111306 111309 111404 111409 111406 111411 111407 111410 111402 111504 111509 111 111511 111706 131304 131306 131309 131404 131409 131406 131411 131407 131410 131402 131504 131509 131 131511 131706 63 Amps Clock Position of Ground Contact SURFACE MOUNT SOCKET-OUTLETS No. of Wires SPLASHPROOF (IP44) SPLASHPROOF (IP44) 16 Amps 32 Amps 110304 110306 110309 110404 110409 110406 110411 110407 110410 110402 110504 110509 110 110511 110706 130304 130306 130309 130404 130409 130406 130411 130407 130410 130402 130504 130509 130 130511 130706 Clock Position of Ground Contact 4 6 9 4 9 6 11 7 10 2 4 9 6 11 6 161404 161409 161406 161411 161407 161410 161402 161504 161509 161 161511 USEFUL TABLES TABLE 1 North American International Outer Jacket inch Strip Length mm Conductor inch Strip Length mm Pilot Conductor inch Strip Length mm TABLE 2 60* 32 63* 100* 125* 100A 125A 4 102 1 1⁄8 28 5 ⁄8 16 20A 16A 7.1 0.8 Device Rating 30A 60A 32A 63A 7.1 17.6 0.8 2 7.1 0.8 100A 125A 35.3 4 7.1 0.8 Metric and AWG/MCM conductor size equivalents mm2 Conductor Size AWG/MCM Test Range (A) 1,0 1,5 2,5 2,5 4,0 6,0 10 16 25 35 35 50 50 70 95 95 120 150 185 185 240 18 16 14 12 10 10 8 6 4 3 2 1 1/0 2/0 3/0 4/0 250 300 350 400 500 0-8 8-12 12-15 15-20 20-25 25-32 32-50 50-65 65-85 85-100 100-115 115-130 130-150 150-175 175-200 200-225 225-250 250-275 275-300 300-350 350-400 Cable and Conductor Range Amps Poles and N.A. Intl. Wires 16 20 2P3W 30 20A 16A 2 50 1 ⁄2 12 Device Rating 30A 60A 32A 63A 2 1⁄2 3 63 76 1 3 ⁄2 ⁄4 12 19 7 ⁄16 11 Maximum Torque applied to terminal screws North American International Torque lb. - in. Terminal Screw N-m Torque lb. - in. Pilot Screw N-m TABLE 3 TABLE 4 Cable and Conductor Strip Length From AWG Type 16 S To AWG 10 Type S 3P4W 16 S 10 S 4P5W 16 S 10 S 2P3W 12 S 8 S 3P4W 12 S 8 S 4P5W 12 S 8 S 2P3W 8 S 4 S or W 3P4W 8 S 4 S or W 4P5W 8 S 4 S or W 2P3W 6 S or W 2/0 S or W 3P4W 6 S or W 2/0 S or W 4P5W 6 S or W 2/0 S or W inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm Cord Grip Range With Cable Gland With Cable SLeeve North American International North American International 0.275 - 0.530 0.275 - 0.530 0.275 - 0.675 0.275 - 0.675 7 - 13.5 7 - 13.5 7 - 17 7 - 17 .395 - .825 0.275 - 0.630 0.315 - 0.800 0.315 - 0.800 10 - 21 7 - 16 8 - 20 8 - 20 .395 - .825 0.275 - 0.630 0.315 - 0.800 0.315 - 0.800 10 - 21 7 - 16 8 - 20 8 - 20 .395 - .825 .395 - .825 0.590 - 0.950 0.435 - 0.950 10 - 21 10 - 21 15 - 24 11 - 24 0.650 - 1.10 .395 - .825 0.590 - 0.950 0.435 - 0.950 16.5 - 28 10 - 21 15 - 24 11 - 24 0.650 - 1.10 .395 - .825 0.590 - 0.950 0.435 - 0.950 16.5 - 28 10 - 21 15 - 24 11 - 24 .650 - 1.50 .650 - 1.50 0.635 - 1.30 0.600 - 1.30 16.5 - 38 16.5 - 38 16 - 33 15 - 33 .650 - 1.50 .650 - 1.50 0.635 - 1.30 0.600 - 1.30 16.5 - 38 16.5 - 38 16 - 33 15 - 33 .650 - 1.50 .650 - 1.50 0.635 - 1.30 0.600 - 1.30 16.5 - 38 16.5 - 38 16 - 33 15 - 33 .950 - 1.90 .950 - 1.90 24 - 48 24 - 48 .950 - 1.90 .950 - 1.90 24 - 48 24 - 48 .950 - 1.90 .950 - 1.90 24 - 48 24 - 48 * Pilot conductor 16 to 8 AWG 29 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. WATERTIGHT PLUGS (IP67) B A 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire 100 125 3, 4, & 5 Wire Amps N.A. Intl. SPLASHPROOF PLUGS (IP44) (with cable gland) 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire Amps N.A. Intl. SPLASHPROOF PLUGS (IP44) (with cable sleeve) A inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm 4.96 2.83 126 72 5.20 3.19 132 81 5.20 3.46 132 88 6.14 3.78 156 96 6.14 3.78 156 96 6.14 4.06 156 103 9.57 4.33 243 110 12.40 5.12 315 130 Dimensions A B 0.275 - 0.530 0.275 - 0.530 7.0 - 13.5 7.0 - 13.5 0.395 - 0.825 0.275 - 0.630 10.0 - 21.0 7.0 - 16.0 0.395 - 0.825 0.275 - 0.630 10.0 - 21.0 7.0 - 16.0 0.395 - 0.825 0.395 - 0.825 10.0 - 21.0 10.0 - 21.0 0.650 - 1.10 0.395 - 0.825 16.5 - 28.0 10.0 - 21.0 0.650 - 1.10 0.395 - 0.825 16.5 - 28.0 10.0 - 21.0 0.650 - 1.50 0.650 - 1.50 16.5 - 38.0 16.5 - 38.0 0.950 - 1.90 0.950 - 1.90 24.0 - 48.0 24.0 - 48.0 Cord Grip Range N. American International inch mm inch mm inch mm inch mm inch mm inch mm inch mm 4.84 123 5.16 131 5.16 131 6.10 155 6.10 155 6.10 155 9.45 240 0.275 - 0.530 7.0 - 13.5 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.650 - 1.10 16.5 - 28.0 0.650 - 1.10 16.5 - 28.0 0.650 - 1.50 16.5 - 38.0 Type 20 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire B 30 Cord Grip Range N. American International Type 20 A B Dimensions A B Type inch mm inch mm inch mm inch mm inch mm inch mm inch mm 2.36 60 2.68 68 2.95 75 3.11 79 3.11 79 3.46 88 3.82 97 0.275 - 0.530 7.0 - 13.5 0.275 - 0.630 7.0 - 16.0 0.275 - 0.630 7.0 - 16.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.650 - 1.50 16.5 - 38.0 Dimensions A B Cord Grip Range N. American International 5.63 143 5.79 147 6.02 153 7.13 181 7.13 181 7.13 181 9.92 252 0.275 - 0.675 7.0 - 17.0 0.315 - 0.800 8.0 - 20.0 0.315 - 0.800 8.0 - 20.0 0.590 - 0.950 15.0 - 24.0 0.590 - 0.950 15.0 - 24.0 0.590 - 0.950 15.0 - 24.0 0.635 - 1.30 16.0 - 33.0 2.36 60 2.68 68 2.95 75 3.11 79 3.11 79 3.46 88 3.82 97 0.275 - 0.675 7.0 - 17.0 0.315 - 0.800 8.0 - 20.0 0.315 - 0.800 8.0 - 20.0 0.435 - 0.950 11.0 - 24.0 0.435 - 0.95 11.0 - 24.0 0.435 - 0.95 11.0 - 24.0 0.600 - 1.30 15.0 - 33.0 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. WATERTIGHT CONNECTORS (IP67) B A C 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire 100 125 3, 4, & 5 Wire Amps N.A. Intl. SPLASHPROOF CONNECTORS (IP44) (with cable gland) B Type 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire Amps N.A. Intl. SPLASHPROOF CONNECTORS (IP44) (with cable sleeve) B 16 3 Wire inch mm inch mm inch mm inch mm inch mm inch mm inch mm 5.32 135 5.95 151 5.95 151 6.73 171 6.73 171 6.73 171 10.0 255 2.01 51 2.56 65 2.56 65 2.83 72 2.83 72 2.83 72 3.78 96 2.68 68 3.35 85 3.35 85 3.58 91 3.58 91 3.86 98 4.49 114 A Dimensions B C 6.06 154 6.54 166 6.54 166 7.72 196 7.72 196 7.72 196 10.5 266 2.01 51 2.56 65 2.56 65 2.83 72 2.83 72 2.83 72 3.78 96 2.69 68.4 2.97 75.4 3.29 83.5 3.54 90 3.54 90 3.78 96 4.41 112 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire A C inch mm inch mm inch mm inch mm inch mm inch mm inch mm 2.83 72 3.19 81 3.46 88 3.78 96 3.78 96 4.06 103 4.33 110 5.12 130 Dimensions A B C 5.35 136 5.63 143 5.63 143 6.97 177 6.97 177 6.97 177 10.0 255 13.1 332 Type 20 Dimensions B inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm Type 20 A C A 3.07 78 3.35 85 3.58 91 3.78 96 3.78 96 4.13 105 4.61 117 5.12 130 C Cord Grip Range N. American International 0.275 - 0.530 0.275 - 0.530 7.0 - 13.5 7.0 - 13.5 0.395 - 0.825 0.275 - 0.630 10.0 - 21.0 7.0 - 16.0 0.395 - 0.825 0.275 - 0.630 10.0 - 21.0 7.0 - 16.0 0.395 - 0.825 0.395 - 0.825 10.0 - 21.0 10.0 - 21.0 0.650 - 1.10 0.395 - 0.825 16.5 - 28.0 10.0 - 21.0 0.650 - 1.10 0.395 - 0.825 16.5 - 28.0 10.0 - 21.0 0.650 - 1.50 0.650 - 1.50 16.5 - 38.0 16.5 - 38.0 0.950 - 1.90 0.950 - 1.90 24.0 - 48.0 24.0 - 48.0 Cord Grip Range N. American International 0.275 - 0.530 7.0 - 13.5 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.650 - 1.10 16.5 - 28.0 0.650 - 1.10 16.5 - 28.0 0.650 - 1.50 16.5 - 38.0 0.275 - 0.530 7.0 - 13.5 0.275 - 0.630 7.0 - 16.0 0.275 - 0.630 7.0 - 16.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.395 - 0.825 10.0 - 21.0 0.650 - 1.50 16.5 - 38.0 Cord Grip Range N. American International 0.275 - 0.675 7.0 - 17.0 0.315 - 0.800 8.0 - 20.0 0.315 - 0.800 8.0 - 20.0 0.590 - 0.950 15.0 - 24.0 0.590 - 0.950 15.0 - 24.0 0.590 - 0.950 15.0 - 24.0 0.635 - 1.30 16.0 - 33.0 0.275 - 0.675 7.0 - 17.0 0.315 - 0.800 8.0 - 20.0 0.315 - 0.800 8.0 - 20.0 0.435 - 0.950 11.0 - 24.0 0.435 - 0.95 11.0 - 24.0 0.435 - 0.95 11.0 - 24.0 0.600 - 1.30 15.0 - 33.0 31 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. WATERTIGHT RECEPTACLE (IP67) (Straight) C 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 & 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire 100 125 3, 4, & 5 Wire B F H A G E G H 5.5mm (.22”) 20 and 30 Amp 6.5mm (.26”) 60 and 100 Amp Type Amps N.A. Intl. C B 15° F H Type 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 & 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire 100 125 3, 4, & 5 Wire A G E G H 5.5mm (.22”) 20 and 30 Amp 6.5mm (.26”) 60 and 100 Amp C 2.82 71.5 31.9 81 3.46 88 3.78 96 4.06 103 4.29 109 5.12 130 2.05 52 2.05 52 2.05 52 2.56 65 2.56 65 3.27 83 3.78 96 1.10 28 1.10 28 1.10 28 1.06 27 1.06 27 2.05 52 2.52 64 A B C 2.82 71.5 3.19 81 3.46 88 3.78 96 4.06 103 4.29 109 5.12 130 1.93 49 2.05 52 2.05 52 2.20 56 2.36 60 3.23 82 3.70 94 1.61 41 1.50 38 1.50 38 1.85 47 1.85 47 2.52 64 2.95 75 A B C 2.83 72 3.19 81 3.46 88 3.78 96 4.06 103 4.33 110 3.46 88 4.25 108 4.25 108 4.76 121 4.84 123 5.63 143 4.29 109 4.84 123 4.84 123 5.71 145 5.71 145 7.99 203 Dimensions D E 1.81 46 2.36 60 2.36 60 2.36 60 2.36 60 3.54 90 3.54 90 2.44 62 2.95 75 2.95 75 2.95 75 2.95 75 3.94 100 4.49 114 F G H 2.44 62 2.95 75 2.95 75 2.95 75 2.95 75 4.21 107 4.49 114 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 3.03 77 3.54 90 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 3.35 85 3.54 90 inch mm inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D E 2.01 51 2.87 73 2.87 73 2.87 73 2.87 73 3.19 81 3.54 90 2.44 62 3.62 92 3.62 92 3.62 92 3.62 92 3.94 100 4.49 114 F G H 2.68 68 3.94 100 3.94 100 3.94 100 3.94 100 4.21 107 4.49 114 1.85 47 3.03 77 3.03 77 3.03 77 3.03 77 3.03 77 3.54 90 1.85 47 3.35 85 3.35 85 3.35 85 3.35 85 3.35 85 3.54 90 F G H 2.05 52 2.60 66 2.60 66 2.95 75 2.95 75 4.49 114 2.17 55 2.68 68 2.68 68 3.07 78 3.07 78 3.54 90 1.18 30 1.57 40 1.57 40 1.77 45 1.77 45 3.54 90 D Amps N.A. Intl. WATERTIGHT RECEPTACLE (IP67) (Angled 80°) E G Type 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 & 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire FH C B A G H 32 B D WATERTIGHT RECEPTACLE (IP67) (Angled 15°) 5.5mm (.22”) 20 and 30 Amp 6.2mm (.24”) 60 Amp inch mm inch mm inch mm inch mm inch mm inch mm inch mm A D inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D max E 1.18 30 1.50 38 1.50 38 1.73 44 1.73 44 2.20 56 2.56 65 3.15 80 3.15 80 3.54 90 3.54 90 4.49 114 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. SPLASHPROOF RECEPTACLES (IP44) (Straight) C 20 16 3 Wire 20 16 4 & 5 Wire 20 16 7 Wire 30 32 3 & 4 Wire 30 32 5 Wire 30 32 7 Wire 60 63 3, 4, & 5 Wire B A F H G E G H 5.5mm (.22”) 20 and 30 Amp 6.5mm (.26”) 60 Amp Type B C 2.68 68 3.35 85 3.35 85 3.58 91 3.86 98 3.86 98 4.49 114 2.05 52 2.09 53 2.09 53 2.56 65 2.56 65 2.56 65 3.35 85 1.10 28 1.10 28 1.10 28 1.06 27 1.06 27 1.06 27 2.05 52 A B C 2.68 68 3.35 85 3.35 85 3.58 91 3.85 91 3.86 98 1.77 45 2.01 51 2.01 51 2.05 52 2.05 52 2.20 56 3.11 79 1.61 41 1.50 38 1.50 38 1.85 47 1.85 47 1.85 47 2.52 64 A B C 2.01 51 2.56 65 2.56 65 2.83 72 2.83 72 2.83 72 3.78 96 3.43 87 4.33 110 4.33 110 4.72 120 4.72 120 4.88 124 5.51 140 4.57 116 4.80 122 4.80 122 5.55 141 5.55 141 5.59 142 7.64 194 Dimensions D E 1.81 46 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.54 90 2.44 62 2.95 75 3.15 80 2.95 75 2.95 75 3.15 80 3.94 100 F G H 2.44 62 2.95 75 3.15 80 2.95 75 2.95 75 3.15 80 4.21 107 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.03 77 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.35 85 D Amps N.A. Intl. SPLASHPROOF RECEPTACLE (IP44) (Angled 15°) C B Type 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire 15° F H A G E G H 5.5mm (.22”) 20 and 30 Amp 6.5mm (.26”) 60 Amp inch mm inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D E 2.01 51 2.36 60 2.56 65 2.64 67 2.64 67 2.70 68.5 3.19 81 2.44 62 2.95 75 2.95 75 2.95 75 2.95 75 3.15 80 3.94 100 F G H 2.68 68 2.95 75 3.35 85 3.54 90 3.54 90 3.74 95 4.21 107 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.03 77 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.35 85 F G H 2.05 52 2.60 66 2.60 66 2.95 75 2.95 75 2.95 75 4.49 114 2.17 55 2.68 68 2.68 68 3.07 78 3.07 78 3.07 78 3.54 90 1.18 30 1.57 40 1.57 40 1.77 45 1.77 45 1.77 45 3.54 90 D Amps N.A. Intl. SPLASHPROOF RECEPTACLE (IP44) (Angled 80°) E G Type 20 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire FH C B A G H 5.5mm (.22”) 20 and 30 Amp 6.2mm (.24”) 60 Amp inch mm inch mm inch mm inch mm inch mm inch mm inch mm A inch mm inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D max E 1.18 30 1.50 38 1.50 38 1.73 44 1.73 44 1.73 44 2.20 56 2.56 65 3.15 80 3.15 80 3.54 90 3.54 90 3.54 90 4.49 114 D 33 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS WATERTIGHT INLETS (IP67) (Straight) C B Amps N.A. Intl. Type 100 125 3 Wire 100 125 4 Wire 100 125 5 Wire Amps N.A. Intl. Type A F H inch mm inch mm inch mm A B C 5.12 130 5.12 130 5.12 130 3.70 94 3.70 94 3.70 94 2.20 56 2.20 56 2.20 56 A B C 2.83 72 3.19 81 3.50 89 3.78 96 3.78 96 4.02 102 4.33 110 3.19 81 3.90 99 4.06 103 4.45 113 4.45 113 4.61 117 5.00 127 3.86 98 4.33 110 4.45 113 5.12 130 5.12 130 5.12 130 7.20 183 Dimensions D E 3.54 90 3.54 90 3.54 90 5.12 130 5.12 130 5.12 130 F G H 5.12 130 5.12 130 5.12 130 4.09 104 4.09 104 4.09 104 4.09 104 4.09 104 4.09 104 G E G H D 6.5mm (.26”) 60 and 100 Amp WATERTIGHT INLETS (IP67) (Angled 80°) E G H 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire 60 63 3, 4, & 5 Wire F C B A G H 5.5mm (.22”) 20 and 30 Amp 6.2mm (.24”) 60 and 100 Amp 1-Pg 16/21 Knock-Out A Amps N.A. Intl. Type 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire NPT Hub G D B inch mm inch mm inch mm inch mm inch mm inch mm inch mm 1.18 30 1.50 38 1.50 38 1.73 44 1.73 44 1.73 44 2.20 56 2.56 65 3.15 80 3.15 80 3.54 90 3.54 90 3.54 90 4.49 114 F G H 2.05 52 2.60 66 2.60 66 2.95 75 2.95 75 2.95 75 4.49 114 2.17 55 2.68 68 2.68 68 3.07 78 3.07 78 3.07 78 3.54 90 1.18 30 1.57 40 1.57 40 1.77 45 1.77 45 1.77 45 3.54 90 F G Hub Size* 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 D WATERTIGHT INLETS (IP67) (Surface Mount, Angled 80°) C1 C2 F E * North American devices supplied with NPT Hub. 34 20 Dimensions D (max) E inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D E A B C1 C2 2.83 72 3.19 81 3.46 88 3.78 96 3.78 96 4.06 103 5.51 140 5.51 140 5.51 140 5.79 147 5.79 147 5.91 150 6.06 154 6.06 154 6.06 154 6.46 164 6.46 164 6.46 164 6.73 171 6.73 171 6.73 171 7.13 181 7.13 181 7.13 181 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 3/4” 3/4” 3/4” 3/4” 3/4” 3/4” IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. SPLASHPROOF INLETS (IP44) (Straight) C B F H A G E Type 20 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 5 Wire G H inch mm inch mm inch mm inch mm inch mm inch mm inch mm A B C 1.85 47 2.09 53 2.40 61 2.48 63 2.48 63 2.72 69 2.99 76 1.85 47 1.85 47 1.85 47 2.20 56 2.20 56 2.20 56 3.27 83 0.87 22 0.87 22 0.87 22 0.87 22 0.87 22 0.87 22 1.14 29 A B C 1.71 43.5 1.97 50 2.20 56 2.24 57 2.24 57 2.52 64 2.72 69 2.83 72 3.54 90 3.62 92 4.06 103 4.06 103 4.06 103 4.57 116 3.82 97 4.33 110 4.33 110 5.08 129 5.08 129 5.08 129 7.28 185 Dimensions D E 1.97 50 2.64 67 2.64 67 2.80 71 2.80 71 2.80 71 3.39 86 2.44 62 3.15 80 3.15 80 3.15 80 3.15 80 3.15 80 4.17 106 F G H 2.44 62 3.15 80 3.15 80 3.15 80 3.15 80 3.15 80 4.33 110 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.54 90 1.85 47 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 3.54 90 5.5mm (.22”) D Amps N.A. Intl. SPLASHPROOF INLETS (IP44) (Angled 80°) E G Type 20 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire 60 63 3, 4, & 5 Wire FH C B A G H 5.5mm (.22”) 20 and 30 Amp 6.2mm (.24”) 60 and 100 Amp 1.18 30 1.50 38 1.50 38 1.73 44 1.73 44 1.73 44 2.20 56 2.56 65 3.15 80 3.15 80 3.54 90 3.54 90 3.54 90 4.49 114 F G H 2.05 52 2.60 66 2.60 66 2.95 75 2.95 75 2.95 75 4.49 114 2.17 55 2.68 68 2.68 68 3.07 78 3.07 78 3.07 78 3.54 90 1.18 30 1.57 40 1.57 40 1.77 45 1.77 45 1.77 45 3.54 90 F G Hub Size* 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 D Amps N.A. Intl. SPLASHPROOF INLETS (IP44) (Surface Mount, Angled 80°) 2-Pg 16/21 Knock-Out A NPT Hub G Type 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire D B inch mm inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D (max) E C1 C2 inch mm inch mm inch mm inch mm inch mm Dimensions D E A B C1 C2 1.97 50 2.20 56 2.24 57 2.24 57 2.52 64 5.51 140 5.51 140 5.51 140 5.51 140 5.51 140 5.95 151 5.95 151 6.30 160 6.30 160 6.30 160 6.61 168 6.61 168 6.97 177 6.97 177 6.97 177 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 3/4” 3/4” 3/4” 3/4” 3/4” F E * North American devices supplied with NPT Hub. 35 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. WATERTIGHT RECEPTACLES (IP67) (Surface Mount, Angled 80°) 20 16 Type 3 Wire 4 Wire 2-Pg 16/21 Knock-Out 5 Wire NPT Hub A 30 G 32 3 Wire D 4 Wire C1 C2 B 5 Wire F E Amps N.A. Intl. WATERTIGHT RECEPTACLES (IP67) (Surface Mount, Angled 80°) 60 63 Type 4 Wire 5 Wire Pg 29 Knock-Out D inch mm inch mm B C1 C2 2.83 72 3.19 81 3.46 88 3.78 96 3.78 96 4.06 103 5.51 140 5.67 144 5.79 147 6.06 154 6.06 154 6.14 156 6.46 164 6.46 164 6.46 164 6.93 176 6.93 176 6.93 176 7.13 181 7.13 181 7.13 181 7.60 193 7.60 193 7.60 193 A B C1 C2 4.33 110 4.33 110 7.01 178 7.01 178 8.82 224 8.82 224 9.76 248 9.76 248 A B C1 C2 5.12 130 5.12 130 5.12 130 7.48 190 7.48 190 7.48 190 16.0 406 16.0 406 16.0 406 16.9 430 16.9 430 16.9 430 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 Dimensions D E 6.77 172 6.77 172 4.76 121 4.76 121 F G 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 F G 4.09 104 4.09 104 5.35 136 5.35 136 F G 7.87 200 7.87 200 7.87 200 9.45 240 9.45 240 9.45 240 Hub Size* 3/4” 3/4” 3/4” 3/4” 3/4” 3/4” Hub Size* 1 1/4” 1 1/4” NPT Hub A B inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D E A C1 C2 G F E WATERTIGHT RECEPTACLES (IP67) (Surface Mount, Angled 80°) Amps N.A. Intl. Type 100 3 Wire 125 4 Wire Pg 42 Knock-Out NPT Hub A D B G C1 C2 F E 2-Pg 36 * North American devices supplied with NPT Hub. 36 5 Wire inch mm inch mm inch mm Dimensions D E 10.4 263 10.4 263 10.4 263 8.66 220 8.66 220 8.66 220 Hub Size* 2” 2” 2” IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. SPLASHPROOF RECEPTACLES (IP44) (Surface Mount, Angled 80°) 1-Pg 16/21 Knock-Out NPT Hub Type 20 16 3 Wire 20 16 4 Wire 20 16 5 & 7 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 & 7 Wire A G D C1 C2 B F E SPLASHPROOF RECEPTACLES (IP44) (Surface Mount, Angled 80°) 1-Pg 29 Knock-Out Amps N.A. Intl. inch mm inch mm inch mm inch mm inch mm inch mm Type 60 63 4 Wire 60 63 5 Wire inch mm inch mm Dimensions D E A B C1 C2 2.01 51 2.56 65 2.56 65 2.83 72 2.83 72 2.83 72 5.51 140 5.63 143 5.75 146 6.06 154 6.06 154 6.18 157 6.30 160 6.46 164 6.46 164 6.81 173 6.81 173 6.81 173 6.97 177 7.13 181 7.13 181 7.48 190 7.48 190 7.48 190 A B C1 C2 3.78 96 3.78 96 7.01 178 7.01 178 8.66 220 8.66 220 9.61 244 9.61 244 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.78 96 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 3.74 95 Dimensions D E 6.77 172 6.77 172 4.76 121 4.76 121 F G 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 2.62 66.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 1.87 47.5 F G 4.09 104 4.09 104 5.35 136 5.35 136 Hub Size* 3/4” 3/4” 3/4” 3/4” 3/4” 3/4” Hub Size* 1 1/4” 1 1/4” NPT Hub A D B G C1 C2 F E * North American devices supplied with NPT Hub. 37 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. WATERTIGHT INLET (IP67) (Surface Mount, Angled 80°) Pg 42 Knock-Out NPT Hub A D B C1 C2 G F E Type 60 63 3 Wire 60 63 4 Wire 60 63 5 Wire 100 125 3 Wire 100 125 4 Wire 100 125 5 Wire 2-Pg 36 inch mm inch mm inch mm inch mm inch mm inch mm Dimensions D E A B C1 C2 4.33 110 4.33 110 4.33 110 5.12 130 5.12 130 5.12 130 4.65 118 4.65 118 4.65 118 6.89 175 6.89 175 6.89 175 9.13 232 9.13 232 9.13 232 15.4 390 15.4 390 15.4 390 10.1 256 10.1 256 10.1 256 16.3 414 16.3 414 16.3 414 5.98 152 5.98 152 5.98 152 10.4 263 10.4 263 10.4 263 4.65 118 4.65 118 4.65 118 8.66 220 8.66 220 8.66 220 Hub Size* F G 4.17 106 4.17 106 4.17 106 7.87 200 7.87 200 7.87 200 4.72 120 4.72 120 4.72 120 9.45 240 9.45 240 9.45 240 1 1/4” PG 1 1/4” 1 1/4” 2” 2” 2” * North American devices supplied with NPT Hub. Note: Two (2) PG36 knock-outs are on the bottom of the 100/125 amp device only. SPLASHPROOF INLET (IP44) (Surface Mount, Angled 80°) E F PG G D C A E F PG G D C 38 Type 16 3 Wire 16 4 Wire 16 5 & 7 Wire 32 3 Wire 32 4 Wire 32 5 & 7 Wire B SPLASHPROOF RECEPTACLE (IP44) (Surface Mount, Angled 80°) A Amps N.A. Intl. B Amps N.A. Intl. inch mm inch mm inch mm inch mm inch mm inch mm Type 16 3 Wire 16 4 Wire 16 5 & 7 Wire 32 3 Wire 32 4 Wire 32 5 & 7 Wire inch mm inch mm inch mm inch mm inch mm inch mm A B C 1.71 43.5 1.97 50 2.20 56 2.24 57 2.24 57 2.52 64 2.36 60 2.87 73 2.87 73 3.15 80 3.15 80 3.39 86 4.33 110 4.61 117 4.61 117 5.55 141 5.55 141 5.55 141 A B C 2.68 68 3.35 85 3.35 85 3.58 91 3.58 91 3.86 98 2.95 75 3.39 86 3.54 90 4.06 103 4.06 103 4.13 105 4.72 120 5.04 128 5.08 129 6.06 154 6.06 154 6.10 155 Dimensions D E 2.91 74 3.15 80 3.15 80 3.82 97 3.82 97 3.82 97 2.36 60 2.91 74 2.91 74 3.23 82 3.23 82 3.23 82 Dimensions D E 2.91 74 3.15 80 3.15 80 3.82 97 3.82 97 3.82 97 2.36 60 2.91 74 2.91 74 3.23 82 3.23 82 3.23 82 F G 1.79 45.5 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 1.10 28 1.22 31 1.22 31 1.77 45 1.77 45 1.77 45 F G 1.79 45.5 2.36 60 2.36 60 2.36 60 2.36 60 2.36 60 1.10 28 1.22 31 1.22 31 1.77 45 1.77 45 1.77 45 13.5 16 16 21 21 21 PG 13.5 16 16 21 21 21 IEC 309 PIN & SLEEVE DEVICES • APPROXIMATE DIMENSIONS Amps N.A. Intl. SPLASHPROOF PLUG (IP44) (Angled) B Type 20 16 3 Wire 20 16 4 Wire 20 16 5 Wire 30 32 3 Wire 30 32 4 Wire 30 32 5 Wire C A Amps N.A. Intl. SPLASHPROOF CONNECTOR (IP44) (Angled) 20 16 inch mm inch mm inch mm inch mm inch mm inch mm Type 3 Wire inch mm A Dimensions B C Cord Grip Range 3.31 84 3.98 101 3.98 101 4.53 115 4.53 115 4.53 115 1.98 50.3 2.53 64.3 2.53 64.3 2.83 72 2.83 72 2.83 72 2.66 67.5 3.32 84.2 3.39 86 3.76 95.5 3.76 95.5 3.96 100.5 0.315 - 0.590 8.0 - 15.0 0.395 - 0.650 10.0 - 16.5 0.395 - 0.650 10.0 - 16.5 0.435 - 0.865 11.0 - 22.0 0.435 - 0.865 110. - 22.0 0.435 - 0.865 11.0 - 22.0 A Dimensions B C Cord Grip Range 3.74 95 1.98 50.3 3.15 80 0.315 - 0.510 8.0 - 13.0 A C B 39 ! NEW SCREW-LESS PLUGS AND CONNECTORS SCREW-LESS PLUGS AND CONNECTORS... ...BROUGHT TO YOU BY WALTHER ELECTRIC CEEtyp plugs and connectors, with insulation displacement technology, are designed to increase productivity and lower the installed cost of wire termination. Utilization of the quick connection system for all wiring jobs, large and small, will speed and improve wire terminations while saving you money. Time and labor savings can be up to 60% when compared to other connection systems. No wire stripping – the installation is fast and easy. The usual stripping procedure is not required. Simply cut the wires to length, fold over and position the conductors in the piercing pockets, and the connection is complete. The Walther quick connection system provides an optimum electrical bond between the conductor and the piercing metal. Once the threaded grip ring is fastened onto the strain relief, the proper amount of force has been applied providing a uniform and controlled connection. The insulation displacement connections are designed for wire sizes 18 – 14 AWG (1 – 2.5 mm2) and are suitable for use under extreme conditions such as heavy vibration. Trim cable cleanly – do not remove cable jacket at this time. Cut the tapered cable sleeve to fit snug around the cable diameter. Be careful not to cut more than necessary. Remove the backshell by depressing the locking tab that secures the contact carrier to the backshell with a small screwdriver. Slide the backshell and the threaded grip ring up the cable. Strip the outer cable jacket about 2 inches (50mm). Threaded Grip Ring Tapered Cable Sleeve Strain Relief Back Shell Slide the cable through the strain relief (do not strip the insulation on the individual conductors), fold over and position the conductors in the piercing pockets that are marked L1, L2, L3, N, and Ground. Trim excess conductors to fit flush. Positioning Key Locking Tab Piercing Pocket Align the positioning key on the strain relief with the keyway on the contact carrier and set the strain relief into the back of the contact carrier. Chamber with insulation displacement contact Contact Carrier Counter thread to the grip ring ORDERING INFORMATION Amps 16 No. of Wires 3P + N + G Voltage AC 400 Clock Position of Ground Contact 6 Male Plug Female Connector 210SL 310SL Consult customer service for other amperage and voltage ratings and configurations. 40 Screw the threaded grip ring onto the strain relief. Firm tightening by had is sufficient. This procedure presses the conductors between the piercing metal providing an optimum electrical bond while firmly gripping the outer jacket of the cable. Slide the backshell down the cable and secure it to the contact carrier by turning the backshell and snapping the locking tab in place. POWER plus CONTROL = Walther’s advanced series of CEEpro connectors combine both power and control, monitoring and sensing contacts in one plug and socket system. For more information call customer service at (800) 925-8437 100 YEARS OF MANUFACTURING EXPERIENCE BEHIND EVERY PRODUCT WORLDWIDE INTERCHANGEABILITY, SAFETY AND RELIABILITY... SAFETY Designed to combine a disconnect switch and a NEMA 4X Watertight (IP67) devices are designed for the most demanding environments and provide protection against corrosion, dirt, dust, splashing water and hose-directed water. receptacle into one Splashproof (IP44) devices provide many of the heavy-duty construc- compact device. tion features found in the watertight devices, but at a more economi- Walther’s mechanical cal cost. These units are suitable and recommended for use in a vari- interlock receptacles ety of light industrial environments and provide protection against eliminate the possibility damaging deposits of dirt and dust, rain and splashing water. of making or breaking Watertight and splashproof devices provide exceptional UV stability the circuit under load or for superior outdoor performance. making a haphazard connection. A mechanism within the enclosure prevents the switch from being turned to the "ON" position until the WORLDWIDE INTERCHANGEABILITY plug is fully engaged into the receptacle. Once inserted, the plug is Walther’s mechanical interlock receptacles are built to IEC 309-1 and locked in place when the switch is turned on and can’t be removed 309-2 specifications and are completely compatible with not only until the switch is turned to the "OFF" position. This prevents making Walther IEC 309-2 plugs, but with any manufacturer’s plugs that con- or breaking the circuit under load. form to these IEC standards and color coding system…anywhere in The integration of the switch and the receptacle in a single, compact the world. enclosure encourages the safe operating practice of disconnecting at the switch rather than the plug and receptacle. The nonmetallic enclosure, while abuse and corrosion resistant, is also non conductive, which enhances the safety of the product. The device can be connected to metallic conduit without interfering with the ground continuity. All mechanical interlock receptacles provide lockout protection for greater safety and comply with OSHA Lockout/Tagout requirements. Walther Mechanical Interlocks, with built-in circuit breakers, incorporate an interlocking receptacle with MCB Type "C" circuit breakers in a nonmetallic enclosure that meets Type 4X (Washdown, Corrosion Resistant) requirements. This new design combines the circuit breakers, switch and receptacle in a RELIABILITY single enclosure. The Type "C" circuit These horsepower rated devices are available in both splashproof breakers are mounted on DIN rail and watertight versions. directly above the switch. Walther CIRCUIT-BREAKER Mechanical Interlocks The new CIRCUIT-BREAKER Mechanical Interlock integrates a circuit breaker (which takes the place of a switch) and receptacle in a nonmetallic enclosure that meets Type 4X (Washdown, Corrosion Resistant) requirements. • Switched, Circuit Breaker Interlock Receptacles are available in 20, 30, 60 and 100 Amp (North American Ratings) and 16, 32, 63 and 125 Amp (International Ratings). • UL489 Listed 22KAIC protection. 42 IEC 309-1 and 309-2 MECHANICAL INTERLOCKS 7.2" (183mm) Max. Compliance with OSHA Lockout Requirements Compact Size Walther’s Mechanical Interlock’s bright red handle can be locked in the “OFF” position as a method of compliance with OSHA lockout requirements. The handle can accept up to a 5/16" padlock shaft. All versions and sizes are designed to fit within the web of an 8" column. This compact size allows the use of columns as a mounting location. Easy Identification Catalog number, rating and certifications are indicated on the label for easy identification of mating devices. Watertight NEMA 4X, 12K Enclosure Walther’s Mechanical Interlocks are gasketed and rated as a Watertight NEMA 4X, 12K enclosure. The nonmetallic enclosure, while abuse and corrosion resistant, is also non-conductive which enhances the safety of the product. Color Coded Receptacle Covers Receptacle covers are colorcoded by voltage in accordance with IEC 309 standard. A Pre-Molded Offset Dimple Completely Compatible A pre-molded offset dimple (drill point) is provided instead of a conduit entry hole. This allows the installer to choose the size of the conduit to be used, and the location where the conduit will be attached to the enclosure (top, bottom or side entry) without the use of knockout plugs and reducers. Arranging the conduit entry hole at the dimple location will prevent condensation from falling directly on the interior electrical components, such as the switch. It will also allow for more room to pull conductors when wiring. Completely compatible with not only Walther IEC 309-1 and 309-2 plugs, but with any manufacturer’s plugs that conform to the IEC 309 standards and color coding system...anywhere in the world. Micro Switch Swivel Mount Feet (135°) Swivel mount feet Swivel mount feet can be used for installations where irregular or tight fit applications exist. Available upon request. May be used to transmit signal when plug is inserted or when switch is turned to the “ON” position. May also be used for indicator light to display and confirm when switch is turned “ON” or “OFF”. Consult technical service for price and delivery. 43 IEC 309 MECHANICAL INTERLOCKS • NORTH AMERICAN RATINGS Amps 20 Poles and Wires 2P3W 3P4W 20, 30, 60 Amp NEMA 4X Watertight (IP67) Drawing A (See Drawing on Page 49) 4P5W 30 2P3W 3P4W 20, 30, 60 Amp Splashproof (IP44) Drawing A (See Drawing on Page 49) 4P5W 32* 3P4W 60 2P3W 3P4W 4P5W Voltage AC 120 240 480 120/240 Clock Position of Ground Contact 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 120 240 480 120/240 9 7 5 9 7 5 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 380 50Hz 440 60Hz 120 240 480 120/240 9 7 5 9 7 5 3 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 9 7 5 9 7 5 STANDARD SWITCH VERSION Horsepower Ratings 2 5 10 2 @ 120V 5 @ 240V 10 20 25 10 20 25 2 5 10 2 @ 120 5 @ 240 10 20 25 10 20 25 15 NEMA 4X Watertight (IP67) AE119316 AE119318 AE119319 Splashproof (IP44) AE110316 AE110318 AE110319 AE119424 AE110424 AE119421 AE119419 AE119417 AE119521 AE119519 AE119517 AE139316 AE139318 AE139319 AE110421 AE110419 AE110417 AE110521 AE110519 AE110517 AE130316 AE130318 AE130319 AE139424 AE130424 AE139421 AE139419 AE139417 AE139521 AE139519 AE139517 AE130421 AE130419 AE130417 AE130521 AE130519 AE130517 AE139415 3 7.5 15 3 @ 120 7.5 @ 240 15 25 30 15 25 30 AE169316 AE169318 AE169319 AE160316 AE160318 AE160319 AE169424 AE160424 AE169421 AE169419 AE169417 AE169521 AE169519 AE169517 AE160421 AE160419 AE160417 AE160521 AE160419 AE160517 3 7.5 15 3 @ 120 7.5 @ 240 15 25 30 15 25 30 AO189316 AO189318 AO189319 * 32 Amp. Only for Refrigerated Containers. 100 2P3W 3P4W 100 Amp NEMA 4X Watertight (IP67) Drawing B (See Drawing on Page 49) 44 4P5W 120 240 480 120/240 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 9 7 5 9 7 5 AO189424 AO189421 AO189419 AO189417 AO189521 AO189519 AO189517 STANDARD SWITCH VERSION with MCB’s (Miniature Circuit Breakers) IEC 309 MECHANICAL INTERLOCKS • NORTH AMERICAN RATINGS Poles and Wires 2P3W Amps 20 3P4W 20, 30, 60 Amp NEMA 4X Watertight (IP67) Drawing C 30 20, 30, 60 Amp Splashproof (IP44) Drawing C MCB 1 Pole "C" 3 Pole "C" 4P5W 3 Pole "C" 2P3W 1 Pole "C" 3P4W 3 Pole "C" 4P5W 3 Pole "C" 32* 3P4W 60 2P3W 3 Pole "C" 1 Pole "C" 3P4W 4P5W 3 Pole "C" 3 Pole "C" Voltage AC 120 240 480 120/240 Clock Position of Ground Contact 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 120 240 480 120/240 9 7 5 9 7 5 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 380 50Hz 440 60Hz 120 240 480 120/240 9 7 5 9 7 5 3 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 9 7 5 9 7 5 Horsepower Ratings 2 5 10 2 @ 120V 5 @ 240V 10 20 25 10 20 25 2 5 10 2 @ 120 5 @ 240 10 20 25 10 20 25 15 3 7.5 15 3 @ 120 7.5 @ 240 15 25 30 15 25 30 NEMA 4X Watertight (IP67) AL119316UD AL119318UD AL119319UD Splashproof (IP44) AL110316UD AL110318UD AL110319UD AL119424SA AL110424SA AL119421SA AL119419SA AL119417SA AL119521TA AL119519TA AL119517TA AL139316UD AL139318UD AL139319UD AL110421SA AL110419SA AL110417SA AL110521TA AL110519TA AL110517TA AL130316UD AL130318UD AL130319UD AL139424SA AL130424SA AL139421SA AL139419SA AL139417SA AL139521TA AL139519TA AL139517TA AL130421SA AL130419SA AL130417SA AL130521TA AL130519TA AL130517TA AL139415SA AL169316UD AL169318UD AL169319UD AL160316UD AL160318UD AL160319UD AL169424SA AL160424SA AL169421SA AL169419SA AL169417SA AL169521TA AL169519TA AL169517TA AL160421SA AL160419SA AL160417SA AL160521TA AL160419TA AL160517TA * 32 Amp. Only for Refrigerated Containers. Dimensions e b 2 x Pg r c l da n 20° l1 f b1 Drawing C Poles Amps and Unit of N.A. Int'l Wires Measure a 20 16 2P3W inch 12.44 mm 316 20 16 3P4W inch 12.44 mm 316 20 16 4P5W inch 12.44 mm 316 30 32 2P3W inch 12.44 mm 316 30 32 3P4W inch 12.44 mm 316 30 32 4P5W inch 12.44 mm 316 60 63 2P3W inch 12.44 mm 316 60 63 3P4W inch 12.44 mm 316 60 63 4P5W inch 12.44 mm 316 NEMA 4X b 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 b1 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 c 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 d 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 e 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 IP44 f 7.17 182 7.36 187 7.24 184 7.36 187 7.36 187 7.44 189 7.72 196 7.72 196 7.72 196 IP67 f 7.60 193 7.64 194 7.72 196 7.91 201 7.91 201 7.91 201 8.23 209 8.23 209 8.23 209 NEMA 4X l 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 l1 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 IP44 n 15.79 401 15.91 404 15.94 405 16.34 415 16.34 415 16.42 417 17.01 432 17.01 432 17.01 432 IP67 n 15.91 404 15.94 405 16.14 410 16.46 418 16.46 418 16.46 418 17.44 443 17.44 443 17.44 443 r 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 45 COMPACT VERSION IEC 309 MECHANICAL INTERLOCKS • NORTH AMERICAN RATINGS Amps 20 Voltage AC 120 240 480 120/240 Clock Position of Ground Contact 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 120 240 480 120/240 9 7 5 9 7 5 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 380 50Hz 440 60Hz 9 7 5 9 7 5 3 Poles and Wires 2P3W 3P4W 20, 30 Amp NEMA 4X Watertight (IP67) Drawing D 4P5W 30 2P3W 3P4W 20, 30 Amp Splashproof (IP44) Drawing D 4P5W 32* 3P4W Horsepower Ratings 2 5 10 2 @ 120V 5 @ 240V 10 20 25 10 20 25 2 5 10 2 @ 120 5 @ 240 10 20 25 10 20 25 15 NEMA 4X Watertight (IP67) AT119316 AT119318 AT119319 Splashproof (IP44) AT110316 AT110318 AT110319 AT119424 AT110424 AT119421 AT119419 AT119417 AT119521 AT119519 AT119517 AT139316 AT139318 AT139319 AT110421 AT110419 AT110417 AT110521 AT110519 AT110517 AT130316 AT130318 AT130319 AT139424 AT130424 AT139421 AT139419 AT139417 AT139521 AT139519 AT139517 AT130421 AT130419 AT130417 AT130521 AT130519 AT130517 AT139415 * 32 Amp. Only for Refrigerated Containers. Dimensions Amps N.A. Int'l 20 16 Drawing D 46 Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W NEMA 4X Unit of Measure inch mm inch mm inch Mm inch mm inch mm inch mm a 5.00 127 5.00 127 5.00 127 6.06 154 6.06 154 6.06 154 b 3.07 78 3.07 78 3.07 78 3.70 94 3.70 94 3.70 94 c 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 d 6.54 166 6.54 166 6.54 166 7.60 193 7.60 193 7.60 193 e 3.82 97 3.82 97 3.82 97 4.45 113 4.45 113 4.45 113 IP44 f 4.57 116 4.72 120 4.92 125 5.71 145 5.71 145 5.83 148 IP67 f 4.72 120 4.92 125 5.20 132 6.06 154 6.06 154 6.06 154 NEMA 4X IP44 n 7.28 185 7.28 185 7.28 185 8.46 215 8.46 215 8.46 215 IP67 n 7.28 185 7.28 185 7.28 185 8.46 215 8.46 215 8.46 215 v 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 IEC 309 MECHANICAL INTERLOCKS • NORTH AMERICAN RATINGS Amps 20 Poles and Wires 2P3W 3P4W 20, 30 Amp NEMA 4X Watertight (IP67) Drawing E 30 20, 30 Amp Splashproof (IP44) Drawing E 32* MCB 1 Pole "C" 3 Pole "C" 4P5W 3 Pole "C" 2P3W 1 Pole "C" 3P4W 3 Pole "C" 4P5W 3 Pole "C" 3P4W 3 Pole "C" Voltage AC 120 240 480 120/240 Clock Position of Ground Contact 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 120 240 480 120/240 9 7 5 9 7 5 4 6 7 12 3Ø240 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 380 50Hz 440 60Hz 9 7 5 9 7 5 3 COMPACT VERSION with MCB’s (Miniature Circuit Breakers) NEMA 4X Watertight Splashproof (IP67) (IP44) AU119316UD AU110316UD AU119318UD AU110318UD AU119319UD AU110319UD Horsepower Ratings 2 5 10 2 @ 120V 5 @ 240V 10 20 25 10 20 25 2 5 10 2 @ 120 5 @ 240 10 20 25 10 20 25 15 AU119424SA AU110424SA AU119421SA AU119419SA AU119417SA AU119521TA AU119519TA AU119517TA AU139316UD AU139318UD AU139319UD AU110421SA AU810419SA AU110417SA AU110521TA AU110519TA AU110517TA AU130316UD AU130318UD AU130319UD AU139424SA AU130424SA AU139421SA AU139419SA AU139417SA AU139521TA AU139519TA AU139517TA AU130421SA AU130419SA AU130417SA AU130521TA AU130519TA AU130517TA AU139415SA * 32 Amp. Only for Refrigerated Containers. Dimensions Amps N.A. Int'l 20 16 Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W NEMA 4X Unit of Measure inch mm inch mm inch mm inch mm inch mm inch mm a 5.00 127 5.00 127 5.00 127 6.06 154 6.06 154 6.06 154 b 3.07 78 3.07 78 3.07 78 3.70 94 3.70 94 3.70 94 c 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 d 6.54 166 6.54 166 6.54 166 7.60 193 7.60 193 7.60 193 e 3.82 97 3.82 97 3.82 97 4.45 113 4.45 113 4.45 113 IP44 f 4.57 116 4.72 120 4.92 125 5.71 145 5.71 145 5.83 148 IP67 f 4.72 120 4.92 125 5.20 132 6.06 154 6.06 154 6.06 154 NEMA 4X j 1.54 39 1.54 39 1.54 39 1.54 39 1.54 39 1.54 39 k 13.11 333 13.11 333 13.11 333 15.24 387 15.24 387 15.24 387 IP44 n 13.86 352 13.86 352 13.86 352 16.10 409 16.10 409 16.10 409 IP67 n 13.86 352 13.86 352 13.86 352 16.10 409 16.10 409 16.10 409 r 6.97 177 6.97 177 6.97 177 7.52 191 7.52 191 7.52 191 Drawing E 47 v 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 IEC 309 MECHANICAL INTERLOCKS • NORTH AMERICAN RATINGS Amps 20 Poles and Wires 2P3W 3P4W 20, 30, 60, 100 Amp NEMA 4X Watertight (IP67) Drawing B 4P5W (See Drawing on Page 49) 30 2P3W 3P4W 20, 30, 60, 100 Amp Splashproof (IP44) Drawing B (See Drawing on Page 49) 4P5W 32* 3P4W 60 2P3W 3P4W 4P5W 100 2P3W 3P4W 4P5W Voltage AC 120 240 480 120/240 3Ø240 3Ø480 3ØY120/208 3ØY277/480 120 240 480 120/240 3Ø240 3Ø480 3ØY120/208 3ØY277/480 380 50Hz 440 60Hz 120 240 480 120/240 3Ø240 3Ø480 3ØY120/208 3ØY277/480 120 240 480 120/240 3Ø240 3Ø480 3ØY120/208 3ØY277/480 Clock Position of Ground Contact 4 6 7 12 9 7 9 7 4 6 7 12 9 7 9 7 3 NEMA 4X Watertight (IP67) AJ119316SH AJ119318SH AJ119319SH AJ119424SH AJ119421SH AJ119419SH AJ119521SH AJ119519SH AJ139316SH AJ139318SH AJ139319SH AJ139424SH AJ139421SH AJ139419SH AJ139521SH AJ139519SH 4 6 7 12 9 7 9 7 4 6 7 12 9 7 9 7 AJ169316SH AJ169318SH AJ169319SH AJ169424SH AJ169421SH AJ169419SH AJ169521SH AJ169519SH AO189316SH AO189318SH AO189319SH AO189424SH AO189421SH AO189419SH AO189521SH AO189519SH * 32 Amp. Only for Refrigerated Containers. IEC 309 CIRCUIT BREAKER VERSION 48 CIRCUIT BREAKER VERSION Splashproof (IP44) AJ110316SH AJ110318SH AJ110319SH AJ110424SH AJ110421SH AJ110419SH AJ110521SH AJ110519SH AJ130316SH AJ130318SH AJ130319SH AJ130424SH AJ130421SH AJ130419SH AJ130521SH AJ130519SH AJ139415SH AJ160316SH AJ160318SH AJ160319SH AJ160424SH AJ160421SH AJ160419SH AJ160521SH AJ160419SH IEC 309 MECHANICAL INTERLOCKS • PERFORMANCE SPECIFICATIONS • NORTH AMERICAN RATINGS ENVIRONMENTAL ELECTRICAL Maximum Working Voltage 600 Volts RMS (switch version) 480 Volts RMS (circuit breaker version) Current Interrupting Certified for current interrupting at full rated current and voltage. Maximum Continuous: 60°C (140°F) Minimum Continuous: -40°C (-40°F) Operating Temperatures UV stabilized material UV Resistance Resists most standard industrial hydrocarbons, acids, bases and solvents. Chemicals MATERIALS Mechanical: 10,000 cycles Electrical: 6,000 cycles Operations UL94-5VA & V0 Classifications Flammability Suitable for use on a circuit capable of delivering not more than 10,000 RMS symmetrical amperes at the voltage rating of the receptacle. Short Circuit Withstand Rating Watertight IP67 (Washdown) - UL Type 4X Splashproof IP44 Moisture Resistance 3,000 Volts Dialectric Voltage Withstand UL94-5VA/V0, UV stabilized, impact modified ValoxR. Enclosure (all exterior components) MECHANICAL Molded arc resistant UL94-V0 thermoplastic Contact Carrier In accordance with UL 746C Impact Resistance Terminal Identification In accordance with UL, CSA and international conventions. Product Identification Identification, ratings and color code in accordance with UL, CSA and IEC requirements. Neoprene or EPDM Contacts (NEMA 4X, Watertight IP67) Brass, Nickel Plated Brass Contacts (Splashproof (IP44) Steel with zinc-plated blue chromate or nickel plating. Hardware (screws & springs) "ON" and "OFF" lockout/tagout capability at switch handle. Complies with OSHA Lockout/Tagout Gaskets APPROVALS & COMPLIANCES Reg. 29CFR 1910.147 UL 508 (switch version) Motor Disconnect Mounting Switch Version Compact Version Circuit Breaker Version Internal or external adjustable mounting feet Internal mounting Internal or external adjustable mounting feet UL 508 (compact version) Manual Motor Controller UL 231 & UL 489 (circuit breaker version) UL1682 & 1686 CSA C22.2 No. 14, 182.1 IEC 309-1 & IEC 309-2 Drawing A e b 2 x Pg Amps N.A. Int'l 20 16 c n d a 20° Dimensions Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W 60 63 2P3W 60 63 3P4W 60 63 4P5W f b1 Drawing A e b 2 x Pg c NEMA 4X Unit of Measure inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm a 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 b 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 b1 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 c 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 d 9.33 237 9.33 237 9.33 237 9.33 237 9.33 237 9.33 237 9.33 237 9.33 237 9.33 237 e 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 IP44 f 7.17 182 7.36 187 7.24 184 7.36 187 7.36 187 7.44 189 7.72 196 7.72 196 7.72 196 IP67 f 7.60 193 7.64 194 7.72 196 7.91 201 7.91 201 7.91 201 8.23 209 8.23 209 8.23 209 NEMA 4X IP44 n 10.55 268 10.63 270 10.75 273 11.10 282 11.10 282 11.18 284 11.89 302 11.89 302 11.89 302 IP67 n 10.63 270 10.71 272 10.91 277 11.22 285 11.22 285 11.38 289 12.17 309 12.17 309 12.17 309 n d a 20° Drawing B l1 Amps N.A. Int'l 100 125 f b1 Drawing B 100 125 100 125 Poles and Unit of Wires Measure a 2P3W inch 12.44 mm 316 3P4W inch 12.44 mm 316 4P5W inch 12.44 mm 316 Dimensions NEMA 4X NEMA 4X b b1 5.94 4.96 151 126 5.94 4.96 151 126 5.94 4.96 151 126 IP67 IP67 c d e f n 0.26 14.57 7.20 9.57 17.72 6.5 370 183 243 450 0.26 14.57 7.20 9.57 17.72 6.5 370 183 243 450 0.26 14.57 7.20 9.57 17.72 6.5 370 183 243 450 49 STANDARD SWITCH VERSION IEC 309 MECHANICAL INTERLOCKS • INTERNATIONAL RATINGS Amps 16 Poles and Wires 2P3W 3P4W 16, 32, 63 Amp Watertight (IP67) Drawing A (See Drawing on Page 49) 4P5W 32 2P3W 3P4W 16, 32, 63 Amp Splashproof (IP44) Drawing A (See Drawing on Page 49) 4P5W 32* 3P4W 63 2P3W 3P4W 4P5W Voltage AC 110 230 400 110 230 400 500 110 230 400 110 230 400 110 230 400 500 110 230 400 380 50Hz 440 60Hz 110 230 400 110 230 400 500 110 230 400 Clock Position of Ground Contact 4 9 6 4 9 6 7 4 9 6 4 9 6 4 9 6 7 4 9 6 3 NEMA 4X Watertight (IP67) AE119304 AE119309 AE119306 AE119404 AE119409 AE119406 AE119407 AE119504 AE119509 AE119 AE139304 AE139309 AE139306 AE139404 AE139409 AE139406 AE139407 AE139504 AE139509 AE139 4 9 6 4 9 6 7 4 9 6 AE169304 AE169309 AE169306 AE169404 AE169409 AE169406 AE169407 AE169504 AE169509 AE169 4 9 6 4 9 6 7 4 9 6 AO179304 AO179309 AO179306 AO179404 AO179409 AO179406 AO179407 AO179504 AO179509 AO179 AE139403 * 32 Amp. Only for Refrigerated Containers. 125 2P3W 3P4W 125 Amp Watertight (IP67) Drawing B (See Drawing on Page 49) 50 4P5W 110 230 400 110 230 400 500 110 230 400 Splashproof (IP44) AE110304 AE110309 AE110306 AE110404 AE110409 AE110406 AE110407 AE110504 AE110509 AE110 AE130304 AE130309 AE130306 AE130404 AE130409 AE130406 AE130407 AE130504 AE130509 AE130 AE160304 AE160309 AE160306 AE160404 AE160409 AE160406 AE160407 AE160504 AE160509 AE160 STANDARD SWITCH VERSION with MCB’s (Miniature Circuit Breakers) IEC 309 MECHANICAL INTERLOCKS • INTERNATIONAL RATINGS Poles and Wires 2P3W Amps 16 MCB 1 Pole "C" 3P4W 3 Pole "C" 4P5W 3 Pole "C" 2P3W 1 Pole "C" 3P4W 3 Pole "C" 4P5W 3 Pole "C" 32* 3P4W 63 2P3W 3 Pole "C" 1 Pole "C" 16, 32, 63 Amp Watertight (IP67) Drawing C 32 16, 32, 63 Amp Splashproof (IP44) Drawing C 3P4W 3 Pole "C" 4P5W 3 Pole "C" Voltage AC 110 230 400 110 230 400 500 110 230 400 110 230 400 110 230 400 500 110 230 400 380 50Hz 440 60Hz 110 230 400 110 230 400 500 110 230 400 Clock Position of Ground Contact 4 9 6 4 9 6 7 4 9 6 4 9 6 4 9 6 7 4 9 6 3 NEMA 4X Watertight (IP67) AL119304UD AL119309UD AL119306UD AL119404SA AL119409SA AL119406SA AL119407SA AL119504TA AL119509TA AL119TA AL139304UD AL139309UD AL139306UD AL139404SA AL139409SA AL139406SA AL139407SA AL139504TA AL139509TA AL139TA 4 9 6 4 9 6 7 4 9 6 AL169304UD AL169309UD AL169306UD AL169404SA AL169409SA AL169406SA AL169407SA AL169504TA AL169509TA AL169TA Splashproof (IP44) AL110304UD AL110309UD AL110306UD AL110404SA AL110409SA AL110406SA AL110407SA AL110504TA AL110509TA AL110TA AL130304UD AL130309UD AL130306UD AL130404SA AL130409SA AL130406SA AL130407SA AL130504TA AL130509TA AL130TA AL139403SA AL160304UD AL160309UD AL160306UD AL160404SA AL160409SA AL160406SA AL160407SA AL160504TA AL160509TA AL160TA * 32 Amp. Only for Refrigerated Containers. Dimensions e b Amps N.A. Int'l 20 16 2 x Pg r c l da n 20° l1 f b1 Drawing C Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W 60 63 2P3W 60 63 3P4W 60 63 4P5W NEMA 4X Unit of Measure inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm a 12.44 316 12.44 316 12.44 316 12.44 316 12.44 316 12.44 316 12.44 316 12.44 316 12.44 316 b 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 5.94 151 b1 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 4.49 114 c 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 0.26 6.5 d 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 14.57 370 e 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 IP44 f 7.17 182 7.36 187 7.24 184 7.36 187 7.36 187 7.44 189 7.72 196 7.72 196 7.72 196 IP67 f 7.60 193 7.64 194 7.72 196 7.91 201 7.91 201 7.91 201 8.23 209 8.23 209 8.23 209 NEMA 4X l 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 6.50 165 l1 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 7.20 183 IP44 n 15.79 401 15.91 404 15.94 405 16.34 415 16.34 415 16.42 417 17.01 432 17.01 432 17.01 432 IP67 n 15.91 404 15.94 405 16.14 410 16.46 418 16.46 418 16.46 418 17.44 443 17.44 443 17.44 443 51 r 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 8.11 206 COMPACT VERSION IEC 309 MECHANICAL INTERLOCKS • INTERNATIONAL RATINGS Amps 16 Poles and Wires 2P3W Voltage AC 110 230 400 110 230 400 500 110 230 400 110 230 400 110 230 400 500 110 230 400 380 50Hz 440 60Hz 3P4W 16, 32 Amp Watertight (IP67) Drawing D 4P5W 32 2P3W 3P4W 16, 32 Amp Splashproof (IP44) Drawing D 4P5W 32* Clock Position of Ground Contact 4 9 6 4 9 6 7 4 9 6 4 9 6 4 9 6 7 4 9 6 3 3P4W NEMA 4X Watertight (IP67) AT119304 AT119309 AT119306 AT119404 AT119409 AT119406 AT119407 AT119504 AT119509 AT119 AT139304 AT139309 AT139306 AT139404 AT139409 AT139406 AT139407 AT139504 AT139509 AT139 Splashproof (IP44) AT110304 AT110309 AT110306 AT110404 AT110409 AT110406 AT110407 AT110504 AT110509 AT110 AT130304 AT130309 AT130306 AT130404 AT130409 AT130406 AT130407 AT130504 AT130509 AT130 AT139403 * 32 Amp. Only for Refrigerated Containers. Dimensions 2 x Pg 2 x Pg Drawing D 52 Amps N.A. Int'l 20 16 Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W NEMA 4X Unit of Measure inch mm inch mm inch mm inch mm inch mm inch mm a 5.00 127 5.00 127 5.00 127 6.06 154 6.06 154 6.06 154 b 3.07 78 3.07 78 3.07 78 3.70 94 3.70 94 3.70 94 c 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 d 6.54 166 6.54 166 6.54 166 7.60 193 7.60 193 7.60 193 e 3.82 97 3.82 97 3.82 97 4.45 113 4.45 113 4.45 113 IP44 f 4.57 116 4.72 120 4.92 125 5.71 145 5.71 145 5.83 148 IP67 f 4.72 120 4.92 125 5.20 132 6.06 154 6.06 154 6.06 154 NEMA 4X IP44 n 7.28 185 7.28 185 7.28 185 8.46 215 8.46 215 8.46 215 IP67 n 7.28 185 7.28 185 7.28 185 8.46 215 8.46 215 8.46 215 v 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 COMPACT VERSION with MCB’s (Miniature Circuit Breakers) IEC 309 MECHANICAL INTERLOCKS • INTERNATIONAL RATINGS Amps 16 16, 32 Amp Watertight (IP67) Drawing E 32 Poles and Wires 2P3W 3P4W 3 Pole "C" 4P5W 3 Pole "C" 2P3W 1 Pole "C" 3P4W 3 Pole "C" 4P5W 3 Pole "C" 3P4W 3 Pole "C" 16, 32 Amp Splashproof (IP44) Drawing E 32* MCB 1 Pole "C" Voltage AC 110 230 400 110 230 400 500 110 230 400 110 230 400 110 230 400 500 110 230 400 380 50Hz 440 60Hz Clock Position of Ground Contact 4 9 6 4 9 6 7 4 9 6 4 9 6 4 9 6 7 4 9 6 3 NEMA 4X Watertight (IP67) AU119304UD AU119309UD AU119306UD AU119404SA AU119409SA AU119406SA AU119407SA AU119504TA AU119509TA AU119TA AU139304UD AU139309UD AU139306UD AU139404SA AU139409SA AU139406SA AU139407SA AU139504TA AU139509TA AU139TA Splashproof (IP44) AU110304UD AU110309UD AU110306UD AU110404SA AU110409SA AU810406SA AU110407SA AU110504TA AU110509TA AU110TA AU130304UD AU130309UD AU130306UD AU130404SA AU130409SA AU130406SA AU130407SA AU130504TA AU130509TA AU130TA AU139403SA * 32 Amp. Only for Refrigerated Containers. 2 x Pg Dimensions Amps N.A. Int'l 20 16 2 x Pg Poles and Wires 2P3W 20 16 3P4W 20 16 4P5W 30 32 2P3W 30 32 3P4W 30 32 4P5W NEMA 4X Unit of Measure inch mm inch mm inch mm inch mm inch mm inch mm a 5.00 127 5.00 127 5.00 127 6.06 154 6.06 154 6.06 154 b 3.07 78 3.07 78 3.07 78 3.70 94 3.70 94 3.70 94 c 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 d 6.54 166 6.54 166 6.54 166 7.60 193 7.60 193 7.60 193 e 3.82 97 3.82 97 3.82 97 4.45 113 4.45 113 4.45 113 IP44 f 4.57 116 4.72 120 4.92 125 5.71 145 5.71 145 5.83 148 IP67 f 4.72 120 4.92 125 5.20 132 6.06 154 6.06 154 6.06 154 NEMA 4X j 1.54 39 1.54 39 1.54 39 1.54 39 1.54 39 1.54 39 k 13.11 333 13.11 333 13.11 333 15.24 387 15.24 387 15.24 387 IP44 n 13.86 352 13.86 352 13.86 352 16.10 409 16.10 409 16.10 409 IP67 n 13.86 352 13.86 352 13.86 352 16.10 409 16.10 409 16.10 409 r 6.97 177 6.97 177 6.97 177 7.52 191 7.52 191 7.52 191 Drawing E 53 v 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 0.28 7 IEC 309 MECHANICAL INTERLOCKS • INTERNATIONAL RATINGS Amps 16 Poles and Wires 2P3W 3P4W 16, 32, 63, 125 Amp Watertight (IP67) Drawing B 4P5W (See Drawing on Page 49) 32 2P3W 3P4W 16, 32, 63, 125 Amp Splashproof (IP44) Drawing B 4P5W (See Drawing on Page 49) 32* 3P4W 63 2P3W 3P4W 4P5W 125 2P3W 3P4W 4P5W Voltage AC 110 230 400 110 230 400 110 230 400 110 230 400 110 230 400 110 230 400 380 50Hz 440 60Hz 110 230 400 110 230 400 110 230 400 110 230 400 110 230 400 110 230 400 * 32 Amp. Only for Refrigerated Containers. 54 CIRCUIT BREAKER VERSION Clock Position of Ground Contact 4 9 6 4 9 6 4 9 6 4 9 6 4 9 6 4 9 6 3 NEMA 4X Watertight (IP67) AJ119304SH AJ119309SH AJ119306SH AJ119404SH AJ119409SH AJ119406SH AJ119504SH AJ119509SH AJ119SH AJ139304SH AJ139309SH AJ139306SH AJ139404SH AJ139409SH AJ139406SH AJ139504SH AJ139509SH AJ139SH 4 9 6 4 9 6 4 9 6 4 9 6 4 9 6 4 9 6 AJ169304SH AJ169309SH AJ169306SH AJ169404SH AJ169409SH AJ169406SH AJ169504SH AJ169509SH AJ169SH AO179304SH AO179309SH AO179306SH AO179404SH AO179409SH AO179406SH AO179504SH AO179509SH AO179SH Splashproof (IP44) AJ110304SH AJ110309SH AJ110306SH AJ110404SH AJ110409SH AJ110406SH AJ110504SH AJ110509SH AJ110SH AJ130304SH AJ130309SH AJ130306SH AJ130404SH AJ130409SH AJ130406SH AJ130504SH AJ130509SH AJ130SH AJ139403SH AJ160304SH AJ160309SH AJ160306SH AJ160404SH AJ160409SH AJ160406SH AJ160504SH AJ160509SH AJ160SH MANUAL DISCONNECT SWITCH SAFETY Walther’s Manual Disconnect Switch combines a horsepower rated switch in a tough, impervious NEMA 4X or IP65 enclosure for safe motor load disconnect. The bright yellow and red padlock handle provides lockout protection, in the "OFF" position, to comply with OSHA Lockout/Tagout regulations. In addition, the enclosure cover cannot be removed from the body until the switch is turned to the "OFF" position. The nonmetallic enclosure, while abuse and corrosion resistant, is also non conductive, which enhances the safety of the product. The device can be connected to metallic conduit without interfering with the ground continuity. RELIABILITY These horsepower rated devices are available from 20 to 100 amp ratings. Type 4X and IP65 enclosures are designed for the most demanding environments and provide protection against corrosion, dirt, dust, splashing water and hose-directed water. Walther Type 4X and IP65 enclosures provide exceptional UV stability for superior outdoor performance. NEC ARTICLE 430 Walther’s Disconnect Switch is designed to meet National Electric Code, Article 430-102, requiring a disconnecting means, located within sight, from the motor location and the driven machinery location. APPROVALS & COMPLIANCES UL 508 Motor Disconnect 55 MANUAL DISCONNECT SWITCH r e b v d c a Drawing F Amps 20 Walther Part No. NS1153 30/32 NS1353 NS1353-GH 60/63 NS1653 NS1653-GH 80 NS1853 NS1853-GH 100 NS1753 NS1753-GH Auxiliary Contacts (1 N/O and 1 N/C) without auxiliary contacts without auxiliary contacts with auxiliary contacts without auxiliary contacts with auxiliary contacts without auxiliary contacts with auxiliary contacts without auxiliary contacts with auxiliary contacts inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm inch mm A 5.00 127.0 6.06 154.0 6.06 154.0 6.50 165.0 6.50 165.0 6.50 165.0 6.50 165.0 6.50 165.0 6.50 165.0 B 3.07 78.0 3.70 94.0 3.70 94.0 5.94 151.0 5.94 151.0 5.94 151.0 5.94 151.0 5.94 151.0 5.94 151.0 Approximate Dimensions C D E V 0.18 6.54 3.82 4.5 166.0 97.0 7.0 0.18 7.60 4.45 0.28 4.5 193.0 113.0 7.0 0.18 7.60 4.45 0.28 4.5 193.0 113.0 7.0 0.26 9.33 7.20 6.5 237.0 183.0 0.26 9.33 7.20 6.5 237.0 183.0 0.26 9.33 7.20 6.5 237.0 183.0 0.26 9.33 7.20 6.5 237.0 183.0 0.26 9.33 7.20 6.5 237.0 183.0 0.26 9.33 7.20 6.5 237.0 183.0 - R 4.57 116.0 5.12 130.0 5.12 130.0 7.09 180.0 7.09 180.0 7.09 180.0 7.09 180.0 7.09 180.0 7.09 180.0 For four (4) and six (6) pole switches, consult technical service for price and delivery. Materials * VaIox® available upon request. Body and Cover* Cover Screws Polyamid Steel with zinc-plated blue chromate or nickel plating. Neoprene Enclosure Gasket When ordering VaIox® change the first numerical digit from a 1 to a 3. For example: Part No. Material NS1153 Polyamid NS3153 Valox® ® Registered trademark of GE Company Horsepower Ratings Phase 1 Phase 3 Phase 56 Voltage AC 120 240 480 120 240 480 600 20 Amp 0.5 1.5 2.5 1.5 3 5 5 Horsepower Rating UL/CSA 30/32 Amp 60/63 Amp 1 2 2.5 5 5 10 2 5 5 10 10 20 10 20 80 Amp 3.5 10 20 7.5 20 40 50 100 Amp 5 15 25 10 25 50 50 MANUAL DISCONNECT SWITCH Amps 30 Walther Part No. MDS3AC MDS3 60 MDS6AC MDS6 100 MDS10AC MDS10 Auxiliary Contacts (2 N/O) With Auxiliary Contacts Without Auxiliary Contacts With Auxiliary Contacts Without Auxiliary Contacts With Auxiliary Contacts Without Auxiliary Contacts inch mm inch mm inch mm inch mm inch mm inch mm A 6.40 162.6 6.40 162.6 8.40 213.4 8.40 213.4 8.40 213.4 8.40 213.4 B 4.40 111.8 4.40 111.8 6.40 162.6 6.40 162.6 6.40 162.6 6.40 162.6 Approximate Dimensions C D E F 6.75 5.13 7.69 6.75 171.5 130.3 195.3 171.5 6.75 5.13 7.69 6.75 171.5 130.3 195.3 171.5 6.75 5.13 9.69 8.75 171.5 130.3 246.1 222.3 6.75 5.13 9.69 8.75 171.5 130.3 246.1 222.3 6.75 5.13 9.69 8.75 171.5 130.3 246.1 222.3 6.75 5.13 9.69 8.75 171.5 130.3 246.1 222.3 G 2.00 50.8 2.00 50.8 4.00 101.6 4.00 101.6 4.00 101.6 4.00 101.6 Materials Body and Cover Cover Screws Inserts for Cover Back Panel Gaskets ® VaIox® Stainless Steel Brass 14 Gauge Steel Neoprene Registered trademark of GE Company Horsepower Ratings Phase 1 Phase 3 Phase Voltage AC 120 240 480 120 240 480 600 Horsepower Rating UL/CSA 30 Amp 60 Amp 100 Amp 1 2 5 2.5 5 15 5 10 25 2 5 10 5 10 25 10 20 50 10 20 50 57 CUSTOM-BUILT COMBINATION OUTLETS Combination Outlets Save 50 – 75% in Time and Material Costs Walther Electric introduces a custom-built power distribution system, made up of multiple variations of receptacles, that we call "Combination Outlets". Combination outlets combine multiple receptacles or an assortment of receptacles into one compact enclosure. By combining numerous receptacles within one electrical enclosure, multiple conduit runs with individual branch circuit wiring can be eliminated; as a result, significantly reducing material costs. These combination outlets are supplied complete with all internal wiring and in most cases only require one connection to the incoming electrical supply conduit. The Walther combination outlet system utilizes standard NEMA wiring devices, IEC309 pin and sleeve connectors, or practically any type of connection that meets your specific requirements (European "Schuko", French, United Kingdom, Australian, Italian, Swiss, Israeli, Danish, Japanese, etc.). Because of the compact size of these combinations, installation of multiple receptacles in tight or limited space is normally not a problem. In fact, many of the enclosures are designed to fit within the web of an 8" column allowing the use of columns as a mounting location. Best of all, overload protection is typically provided with built-in circuit breakers within the enclosure, which are easily accessible by opening the see-through cover. This cover can be secured by a choice of methods ranging from a simple thumbscrew to lockout protection for greater safety and compliance with OSHA Lockout/Tagout regulations. The Walther combination outlet system also utilizes fuses, RCD’s, GFCI breakers or practically any type of overload protection that meets your specific requirements. The high impact thermoplastic and solid rubber enclosures, while abuse and corrosion resistant, are also non conductive, which enhances the safety of the product (consult technical service for stainless steel enclosures). Each combination is checked in accordance with EN 60 439-1; 1994 table 7 and test certificates are provided with each unit. This test data is saved and can be retrieved at any time. Walther Electric welcomes the opportunity to manufacture custom combinations of receptacles and inlets built to your specific needs and requirements. The examples shown in this section represent only a small fraction of the possible combinations available. Our application engineers are at your service to help plan and construct combination units according to your specific requirements. Simply call 1-800-WALTHER. 59 CUSTOM-BUILT COMBINATION OUTLETS PEDESTALS AND FRAMES FOR CUSTOM-BUILT COMBINATION OUTLETS NEW ! HANGING COMBINATIONS NEW ! Walther Electric welcomes the opportunity to manufacture custom combinations of receptacles and inlets built to your specific needs and requirements. The examples shown in this section represent only a small fraction of the possible combinations available. Our application engineers are at your service to help plan and construct combination units according to your specific requirements. Simply call 1-800-WALTHER. 60 CUSTOM-BUILT RUBBER DISTRIBUTION BOXES NEW ! Plug (Input) NEMA L21-30P 30A 3ØY120/208 VAC No. 3 (Output) Receptacles NEMA 5-20R 20A 125VAC Overload Protection 3 MCB's 1 Pole 20A>>C>C>C>B>C
410306 价格&库存
很抱歉,暂时无法提供与“410306”相匹配的价格&库存,您可以联系我们找货
