215306SW
215306SW
    WALTER(华德)
215306SW 数据手册
Rev2-IEC60309-Catalog(2ndHalf).pdf 3 7/7/15 12:48 PM IEC60309 PIN & SLEEVE DEVICES • LIGHT & STAGE DEVICES New Light & Stage Style Standard Style Well hidden from View! It is necessary that electrical installations on stages function without interruption and not be a distraction to the viewers. The Walther Electric Solution: thus make the electrical installation on stages almost “invisible”! Now You See It 3 C 2P+E 4 3P+E 5 3P+N+E Amperage IEC/EN 60 309 Now You Don’t for Light & Stage Applications 110 V Poles Male Plugs IP 44 - 230 V 400 V 500 V 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 3pole 4pole 5pole 4h 4h 4h 3pole 4pole 5pole 6h 9h 9h 3pole 4pole 5pole 9h 6h 6h 3pole 4pole 5pole 7h 7h 7h g Part numbers M 16 16 16 32 32 32 63 63 63 125 125 125 Y CM MY CY CMY K 231SW 230SW 3 Plugs IP 44 211 406 SW 211 SW 231 306 SW 231 406 SW 231 SW 261 306 SW 279 306 SW1) Plugs with gland entry, in 16 - 63 A = IP 44 16 215306SW 211 306 SW 3 4 5 3 4 5 3 4 5 3 4 5 215 304 SW 261 406 SW 261 SW 279 406 SW1) 279 SW1) , in 125 A = IP 67 112 154 170 211 217 240 475 566 613 1185 1329 1473 10 101 1) 215 306 SW with inverted cable entry 16 5 210 SW 10/60 176 32 5 230 SW 10/60 250 Plugs IP 44 , with cable gland Consult customer service for other amperage and voltage ratings and configurations. 32 10 10 10 10 10 10 5 5 5 2 2 2 Rev2-IEC60309-Catalog(2ndHalf).pdf 4 7/7/15 12:48 PM CEEtyp LIGHT & STAGE DEVICES for Light & Stage Applications Female Connectors & Socket-Outlets IP 44 2P+E 4 3P+E 5 3P+N+E 110 V Poles 3 Amperage IEC/EN 60 309 230 V 400 V 500 V 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 50 a. 60 Hz 3pole 4pole 5pole 4h 4h 4h 3pole 4pole 5pole 6h 9h 9h 3pole 4pole 5pole 9h 6h 6h 3pole 4pole 5pole 7h 7h 7h g Part numbers 16 16 16 32 32 32 63 63 63 125 125 125 C M Y 331306SW CM 311 306 SW 3 4 5 3 4 5 3 4 5 3 4 5 311 406 SW 311 SW 331 306 SW 331 406 SW 331 SW 361 306 SW 379 306 SW2) Couplers with gland entry, 16 - 63 A = IP 44 361 406 SW 361 SW 379 406 SW2) 379 SW2) , 125 A = IP 67 10 10 10 10 10 10 5 5 5 2 2 2 147 197 214 265 278 300 656 771 787 1362 1536 1710 10 140 2) MY 16 CY 3 315 304 SW 315 306 SW CMY K 315306SW 310SW 430SW Couplers IP 44 , with inverted cable entry 16 5 310 SW 10/60 219 32 5 330 SW 10/60 311 410 406 SW 410 SW 10 10 10 128 106 165 430 406 SW 430 SW 10 10 10 208 215 226 460 406 SW 460 SW 5 5 5 586 645 776 479 406 SW3) 479 SW3) 2 2 2 990 1155 1319 Couplers IP 44 , with cable gland 410 304 SW 410 306 SW 16 16 16 3 4 5 32 32 32 3 4 5 430 306 SW 63 63 63 3 4 5 460 306 SW 125 125 125 3 4 5 479 306 SW3) Panel sockets, straight, 16 - 63 A = IP 44 , 125 A = IP 67 3), fingerproof acc. to BGV A2 Consult customer service for other amperage and voltage ratings and configurations. 33
215306SW 价格&库存
很抱歉,暂时无法提供与“215306SW”相匹配的价格&库存,您可以联系我们找货
