CCLA6N-10W
CCLA6N-10W
    ELKAY(埃尔凯)
    ELKAY - CCLA6N-10W - Accessory, Elkay KUT6N Feed Through Terminal Blocks, Fixed Bridge
CCLA6N-10W 数据手册
KUT6N - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Feed Through Terminal Blocks Connection Method Screw Connection Product Data Product Name KUT6N Product Image Line Diagram Short Description Feed Through Terminal Block - Screw Connection Full Description Terminal Type - KUT6N , Feed-through terminal block for photo voltaic applications , nominal voltage: 1000 V, nominal current: 41 A, connection method: Screw connection, number of connections: 2, cross section: 0.5 mm² - 10 mm², AWG: 20 - 8, width: 8 mm , length: 44.25 mm , height : 51 mm , mounting type: NS 35/7.5, NS 35/15 , NS 32/15 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Key Commercial Data Standard Weight 1.5 Kg Weight per Piece (excluding packing) 13.8 g Packing Unit 100 pc Minimum Order Quantity 100 pc GTIN Number 85389000 Country Of Origin INDIA Technical Data - General Number of levels 1 1 Number of connections 2 Potentials 1 Nominal cross section 6 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V2 Area of application Rated surge voltage 12 kV Degree of pollution 3 Overvoltage category III Maximum power dissipation for nominal condition 1.31 W Nominal Current IN 41 A Nominal Voltage UN 1000 V Open side panel Yes Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 14.8 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 2.2 kV Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 0.5 mm² / 0.3 kg , 6 mm² / 1.4 kg , 10 mm² / 2.0 kg Tensile test result Test passed Conductor cross section tensile test 0.5 mm2 Tractive force setpoint 20 N Conductor cross section tensile test 6 mm2 Tractive force setpoint 80 N Conductor cross section tensile test 10 mm2 Tractive force setpoint 90 N Result of tight fit on support Test passed Tight fit on carrier NS 32/NS 35 Setpoint 5 Result of voltage-drop test Test passed Requirements, voltage drop
CCLA6N-10W 价格&库存
很抱歉,暂时无法提供与“CCLA6N-10W”相匹配的价格&库存,您可以联系我们找货
