CCLAKG6-10W
CCLAKG6-10W
    ELKAY(埃尔凯)
    ELKAY - CCLAKG6-10W - Accessory, Terminal Blocks, Insulated Cross Connection Link
CCLAKG6-10W 数据手册
Accessories End Plate KPSLD Height : 46.40 mm Width : 85.10 mm Thickness : 1 mm Partition Plate With Foot BPSCA ( Partition Plate-End clamp combo with knob ) Height : 74 mm Width : 90 mm KBFA ( Partition Plate with knob ) Height : 76.6 mm Width : 90 mm Barrier Plate DBF-6 Height : 77 mm Width : 85 mm Thickness : 3 mm End Clamp SCUDD Height : 50 mm Width : 55.50 mm Thickness : 10 mm SCUSL Height : 41 mm Width : 47.50 mm Thickness : 8 mm Comb-type Shorting Link SLD6 ( 2W, 3W, 4W, 5W, 10W ) Cross Connection Insulated Link Assembly CCLAKG6 ( 2 Way, 3 Way, 4 Way, 5 Way, 6 Way, 10 Way ) Marking Label LABEL KN8 Mounting Channel (Standard Lengths 300 mm, 500 mm, 1000 mm) CHK Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHKDS (Perforated) Height : 15 mm Width : 35 mm Thickness : 1.50 mm CHKS (Perforated) Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHS Height : 15 mm Width : 32 mm Thickness : 1.50 mm Group Marking Holder GMH 10 Height : 51 mm Width : 41.50 mm Thickness : 10 mm GMH 20 Height : 51 mm Width : 41.50 mm Thickness : 20 mm PVC Transparent Protection cover BPSCACP Height : 42 mm Width : 90 mm Thickness : 1 mm PCPDBF-6 Height : 13 mm Width : 90 mm Thickness : 1 mm Note : Technical specifications may change in line with technical advances and industry standards
CCLAKG6-10W 价格&库存
很抱歉,暂时无法提供与“CCLAKG6-10W”相匹配的价格&库存,您可以联系我们找货
