DBK 1X8
DBK 1X8
    ELKAY(埃尔凯)
    ELKAY - DBK 1X8 - Panel Mount Barrier Terminal Block, 57 A, 800 V, 17 Pole, 1, Screw, 1 AWG
DBK 1X8 数据手册
DBK 1X8 Approvals General Data Type DBK 1X8 Wire Termination Technology Screw Clamp Ratings 800 V/IC-114 A,OG-57 A/IC-35 sq mm,OG-10 sq mm/IC-6 Nm,OG-1.2 Nm GTIN / Harmonize Custom Code 85389000 Standard Packing Qty (in No) 5 Country of Origin India Screw Size M4 Dimensions & Weight Height (mm) 49.70 Height (inches) 1.96 Width (mm) 67.50 Width (inches) 2.66 Thickness (mm) 113 Weight For Standard Packing Qty (Kg) 2.00 Material Data Housing PA 6,6 Standard Colour Grey Other Color Variants Black, Blue, Green, Khakhi, Red, Yellow Rated Conductor Size Stranded Wire - min (sq mm) IC-10 , OG-2.5 Stranded Wire - max (sq mm) IC-50 , OG-10 Solid Wire - min (sq mm) IC-10 , OG-2.5 Solid Wire - max (sq mm) IC-50 , OG-16 Ratings - IEC Standard IEC 60947-7-1 Rated Voltage (V) 800 Rated Current (A) IC-114 , OG-57 Rated Cross Section (sq mm) IC-35 , 0G-10 Short Time Withstand Current (kA) 4.20 Rated Impulse Withstand Voltage(kV) - Pollution Degree III Ratings-uL Rated Voltage (V) 600 Rated Current (A) IC-130 , OG-130 Conductor Size - min (AWG) IC-8 , OG-16 Conductor Size - max (AWG) IC-1 , OG-6 Accessories Partition Plate Without Foot KBX Height : 43 mm Width : 54 mm Thickness : 1.50 mm Partition Plate With Foot End Clamp SCUDD Height : 50 mm Width : 55.50 mm Thickness : 10 mm SCUSL Height : 41 mm Width : 47.50 mm Thickness : 8 mm Marking Label LABEL KN10 Mounting Channel (Standard Lengths 300 mm, 500 mm, 1000 mm) CHK Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHKD Height : 15 mm Width : 35 mm Thickness : 1.50 mm CHKDS (Perforated) Height : 15 mm Width : 35 mm Thickness : 1.50 mm CHKS (Perforated) Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHS Height : 15 mm Width : 32 mm Thickness : 1.50 mm Group Marking Holder GMH 10 Height : 51 mm Width : 41.50 mm Thickness : 10 mm GMH 20 Height : 51 mm Width : 41.50 mm Thickness : 20 mm Note : Technical specifications may change in line with technical advances and industry standards
DBK 1X8 价格&库存
很抱歉,暂时无法提供与“DBK 1X8”相匹配的价格&库存,您可以联系我们找货
