DUTKD4EP
DUTKD4EP
    ELKAY(埃尔凯)
    ELKAY - DUTKD4EP - Accessory, Elkay DUTKD4 Knife Disconnect Terminal Blocks, End Cover
DUTKD4EP 数据手册
DUTKD4 - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Knife Disconnect Terminal Blocks Connection Method Screw Connection Product Data Product Name DUTKD4 Product Image Line Diagram Short Description Knife Disconnect Terminal block - Screw Connection Full Description Terminal Type - DUTKD4 , Knife Disconnect Terminal block , nominal voltage: 1000 V, nominal current: 20 A, connection method: Screw connection, number of connections: 2, cross section: 0.5 mm² – 4 mm², width: 6 mm , height: 56 mm , Length : 62 mm , mounting type: TS35/7.5 , TS35/15 and TS32 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Your Advantages Convenient separation of circuits using lever-type disconnect knife. Safe operation since the disconnect lever is latched into the end positions. Key Commercial Data Standard Weight 1.4 Kg Weight per Piece (excluding packing) 13.5 g Packing Unit 100 pc Minimum Order Quantity 100 pc Country Of Origin India Technical Data - General Number of levels 1 Number of connections 2 Potentials 1 1 Nominal cross section 4 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V2 (V0 - on customer demand) Area of application Rated surge voltage 4 kV Degree of pollution 3 Overvoltage category III Maximum power dissipation for nominal condition 0.77 W Nominal Current IN 20 A Nominal Voltage UN 1000 V Open side panel Yes Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 4.8 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 2.2 kV Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 0.5 mm² / 0.3 kg , 4 mm² / 0.9 kg Tensile test result Test passed Conductor cross section tensile test 0.5 mm Tractive force setpoint 20 N Conductor cross section tensile test 4 mm2 Tractive force setpoint 60 N Result of tight fit on support Test passed Tight fit on carrier TS35/7.5 , TS35/15 and TS32 Setpoint 1 Result of voltage-drop test Test passed Requirements, voltage drop
DUTKD4EP 价格&库存
很抱歉,暂时无法提供与“DUTKD4EP”相匹配的价格&库存,您可以联系我们找货
