ETDD4N
ETDD4N
    ELKAY(埃尔凯)
    ELKAY - ETDD4N - DIN Rail Mount Terminal Block, Ground, 4 Ways, 4 mm², Screw
ETDD4N 数据手册
ETDD4N - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Ground Terminal Blocks Connection Method Screw Connection Product Data Product Name ETDD4N Product Image Line Diagram Short Description Multi level Ground terminal block - Screw Connection Full Description Terminal Type - ETDD4N , Multi level Ground terminal block for photo voltaic applications , connection method: Screw connection, number of connections: 4, cross section: 0.5 mm² - 4 mm² , width: 6 mm , length: 62.5 mm , height : 65.5 mm , mounting type: NS 35/7.5 , NS 35/15 Approvals Standard Colour Green-Yellow Colour Variants Key Commercial Data Standard Weight 1.9 Kg Weight per Piece (excluding packing) 21.4 g Packing Unit 50 pc Minimum Order Quantity 50 pc GTIN Number 85389000 Country Of Origin INDIA Technical Data - General Number of levels 2 1 Number of connections 4 Nominal cross section 4 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V2 Area of application Degree of pollution 3 Overvoltage category III Open side panel Yes Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 0.5 mm² / 0.3 kg , 4 mm² / 0.9 kg Tensile test result Test passed Conductor cross section tensile test 0.5 mm2 Tractive force setpoint 20 N Conductor cross section tensile test 4 mm Tractive force setpoint 60 N Result of tight fit on support Test passed Tight fit on carrier NS 35 Setpoint 5 Result of voltage-drop test Test passed Requirements, voltage drop
ETDD4N 价格&库存
很抱歉,暂时无法提供与“ETDD4N”相匹配的价格&库存,您可以联系我们找货
