370B-1
370B-1
    ELKAY(埃尔凯)
    ELKAY - 370B-1 - Timeswitch, 2 min, 1 h, 10 A, Energysense Series - Timeswitch, 2 min, 1 h, 10 A, En...
370B-1 数据手册
9541 ELKAY PUSH BUTTON & PIR 3875B-1-370B-1 INSTRUCTIONSv4_Layout 1 15/10/2014 12:27 Page 2 pirtimer energybasic pirtimer fitting and operating instructions pirtimer - three wire (for all load types) Product: 370B-1 Three wire Rating at 240V ac • Incandescent 10A • Compact Fluorescent 10A • Resistive 10A • Fluorescent 10A • Time Delay 2min - 1h Diagram 1 Diagram 2 Wiring diagram for a three wire unit. Wiring diagram for three wire additional Switches/PIR into circuit. LIVE IN NEUTRAL LIVE IN NEUTRAL LIVE OUT LIVE OUT N SL L N SL L N SL L N SL L Diagram 3 2 mins 5 mins 1. 10 mins 2. 1. 15 mins 4. 3. 2. 1. 20 mins 4. 3. 2. 1. 30 mins 4. DIP 3. DIP 4. 3. 2. 1. 40 mins ON 2. DIP 3. ON 1. 4. ON 2. DIP 3. ON 1. 4. ON 2. DIP 3. ON 4. DIP Please note that the black bar denotes the position of the dip switch. DIP 7. 8. ON 6. DIP 2. 3. 4. 5. Prior to fitting identify the Live In, Switch Live and Neutral wires. Ensure if fitting intometal back boxes lugs are removed that are not being used. Set the dip switches to the required time settings identified (See Diagram 3). Fit the Live In, Switch Live and Neutral into the terminals as marked (See Diagram 1). Rotate lux level adjustment to the + for initialisation (Turn anticlockwise). Turn on the mains power. The unit will flash for four minutes whilst the load is on and will switch off the load when ready to operate (N.B. As long as no movement is detected). Adjust lux level to the desired setting. Please note the PIR should be carefully adjusted when considering ambient light levels. The product will turn itself off once the required time has elapsed and there is no longer movement detected. Please ensure device is screwed back to the backbox once installation is complete. ON 1. 4. 3. 2. 1. 60 mins IMPORTANT NOTICE All wiring should be carried out by a competent person or a qualified electrician and should be fitted to IEE 17th Edition Wiring regulations BS7671:2008. Call +44 (0) 1675 468222 or click www.elkay.co.uk
370B-1 价格&库存
很抱歉,暂时无法提供与“370B-1”相匹配的价格&库存,您可以联系我们找货
