CCLA16-10W
CCLA16-10W
    ELKAY(埃尔凯)
    ELKAY - CCLA16-10W - Accessory, Elkay KUT16 Feed Through Terminal Blocks, Fixed Bridge
CCLA16-10W 数据手册
KUT16 - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Feed Through Terminal Blocks Connection Method Screw Connection Product Data Product Name KUT16 Product Image Line Diagram Short Description Feed Through Terminal Block - Screw Connection Full Description Terminal Type - KUT16 , Feed-through terminal block, nominal voltage: 1000 V, nominal current: 76 A, connection method: Screw connection, number of connections: 2, cross section: 6 mm² - 25 mm², AWG: 12 - 3, width: 12 mm , length: 44.5 mm , hight : 52 mm , mounting type: TS35/7.5 , TS35/15 , and TS32 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Your Advantages The large wiring space enables the connection of solid and stranded conductors without ferrules, even above the rated cross section .Universal foot for mounting on NS 32 and NS 35 DIN rails. Key Commercial Data Standard Weight 1.35 Kg Weight per Piece (excluding packing) 25.5 g Packing Unit 50 pc Minimum Order Quantity 50 pc GTIN Number 85389000 Country Of Origin India 1 Technical Data - General Number of levels 1 Number of connections 2 Potentials 1 Nominal cross section 16 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V2 (V0 - on customer demand) Area of application Rated surge voltage 8 kV Degree of pollution 3 Overvoltage category III Maximum power dissipation for nominal condition 2.43 W Nominal Current IN 76 A Nominal Voltage UN 1000 V Open side panel Yes Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 9.8 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 2.2 kV Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 6 mm² / 1.4 kg , 16 mm² / 2.9 kg , 25 mm² / 4.5 kg Tensile test result Test passed Conductor cross section tensile test 6 mm2 Tractive force setpoint 80 N Conductor cross section tensile test 16 mm2 Tractive force setpoint 100 N Conductor cross section tensile test 25 mm2 Tractive force setpoint 135 N Result of tight fit on support Test passed Tight fit on carrier TS35/7.5 , TS35/15 and TS32 Setpoint 5 2 Result of voltage-drop test Test passed Requirements, voltage drop
CCLA16-10W 价格&库存
很抱歉,暂时无法提供与“CCLA16-10W”相匹配的价格&库存,您可以联系我们找货
