DCKNMLH
DCKNMLH
    ELKAY(埃尔凯)
    ELKAY - DCKNMLH - Accessory, Elkay KUDF 4 Feed Through Terminal Blocks, Group Marking Carrier
DCKNMLH 数据手册
KUDF 4 Approvals General Data Type KUDF 4 Wire Termination Technology Screw Clamp Ratings 800 V/6.3 A/4 sq mm/0.4 Nm GTIN / Harmonize Custom Code 85389000 Standard Packing Qty (in No) 100 Country of Origin India Screw Size M3 Dimensions & Weight Height (mm) 44 Height (inches) 1.73 Width (mm) 54.50 Width (inches) 2.13 Thickness (mm) 8 Weight For Standard Packing Qty (Kg) 1.38 Material Data Housing PA 6,6 Standard Colour Grey Other Color Variants Black, Blue, Green, Khakhi, Red, Yellow Rated Conductor Size Stranded Wire - min (sq mm) 0.5 Stranded Wire - max (sq mm) 4 Solid Wire - min (sq mm) 0.5 Solid Wire - max (sq mm) 4 Ratings - IEC Standard IEC 60947-7-1 Rated Voltage (V) 800 Rated Current (A) 6.3 Rated Cross Section (sq mm) 4 Short Time Withstand Current (kA) 0.48 Rated Impulse Withstand Voltage(kV) 8 Pollution Degree III Ratings-ATEX Certificate No 420 Rated Current (A) 5 Rated Cross Section (sq mm) 2.5 Ratings-CSA Rated Voltage (V) 600 Rated Current (A) 7 Wire Cross Section - min (AWG) 20 Wire Cross Section - max (AWG) 12 Ratings-uL Rated Voltage (V) 600 Rated Current (A) 7 Conductor Size - min (AWG) 20 Conductor Size - max (AWG) 12 Accessories Partition Plate With Foot KBZF Height : 65 mm Width : 65 mm Thickness : 1.50 mm End Clamp DCKN (Screwless - 35 mm Rail Mounted) Height : 33 mm Width : 43.50 mm Thickness : 6 mm DCKN10 (Screwless - 35 mm Rail Mounted) Height : 33 mm Width : 43.50 mm Thickness : 10 mm SCKN (35 mm Rail Mounted) Height : 35.50 mm Width : 50.60 mm Thickness : 8 mm SCUN (Universal Rail Mounted) Height : 35.50 mm Width : 50.60 mm Thickness : 9.50 mm Comb-type Shorting Link UFSL ( ( 2W, 3W, 4W, 5W, 10W) ) Marking Label LABEL KN8 Group Marking Carrier DCKNMLH Height : 45.50 mm Width : 43.50 mm Thickness : 6 mm SCKNMLH Height : 45.50 mm Width : 48 mm Thickness : 8 mm SCUNMLH Height : 53.50 mm Width : 50.60 mm Thickness : 8 mm Mounting Channel (Standard Lengths 300 mm, 500 mm, 1000 mm) CHK Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHKD Height : 15 mm Width : 35 mm Thickness : 1.50 mm CHKDS (Perforated) Height : 15 mm Width : 35 mm Thickness : 1.50 mm CHKS (Perforated) Height : 7.5 mm Width : 35 mm Thickness : 1 mm CHS Height : 15 mm Width : 32 mm Thickness : 1.50 mm Group Marking Holder GMH 10 Height : 51 mm Width : 41.50 mm Thickness : 10 mm GMH 20 Height : 51 mm Width : 41.50 mm Thickness : 20 mm Note : Technical specifications may change in line with technical advances and industry standards
DCKNMLH 价格&库存
很抱歉,暂时无法提供与“DCKNMLH”相匹配的价格&库存,您可以联系我们找货
