pushbutton & touchsensor fitting and operating instructions
energyoutdoor
yout 1 25/02/2010 14:43 Page 1
pushbutton/touchsensor
master unit - two wire
Instruction
Data
| 350A-1
| 360A-1
Product:
350A-1, 350A-2,
360A-1,
360A-2, 750A-1,
760A-1,
550A-3, 550A-4, 560A-3, 560A-4 Two wire
| 550A-3 | 560A-3
energysense
Master push button and touch timer
uchsensor
energystyle
Fitting and operating
instructions – Two wire (Lin-Lout). For lighting only
Rating at 240V ac
• Incandescent 16A • Compact Fluorescent 16A
• Resistive
16A • Fluorescent 16A • Time Delay 2min - 2h
energyoutdoor
The pushbutton/touch timer are part of the Elkay family of
switches, timers and detectors which save energy and increase
convenience in and around your home, garden or premises.
ng the
he
A
am 2).
Wiring diagram for a single sensor unit.
Time
Delay:FOR
2min-2hr
Please note
that the trigger2terminal Diagram
is the third terminal.
NOT
SUITABLE
USE WITH CONTACTORS. DO NOT MEGGER
continuo
Diagram
2 This
LIVE IN
Voltage:
240Va.c. RESISTANCE
50Hz
product requires a 24 hour power supply. The battery inside the
TEST
OR INSULATION
TEST THIS PRODUCT.
operatio
NEUTRAL
Wiring
diagram
for
a
sensor
unit with slave.
REMOVE
BEFORE&TESTING
OR TEST
CIRCUIT
PRIOR
TO that
FITTING.
switched
Load Rating
Type: 16A
for all
lighting
loads
are LED, unit recharges when the light source or appliance is switched
OFF. Where the supply may be interrupted or isolated regularly
Compact Fluorescent and Fluorescent, Incandescent
and
*Optional
wire
for indicator
blue indicator 4. At one m
OUT
*Optional
for blue
we must recommend our products from the three
wirewire
range.
Your Elkay unit is compatible with a single gang,LIVE
25mm
deep
red LED
Resistive.
ringonon
push
button
ring
push
button
slavesslaves
only only
British Standard accessory plate. Please ensure that the
of opera
(This
Push
button
touch timer
be boxes
used on contactors.
Battery
Installation Steps
top
and
bottom
lugs and
are removed
fromcannot
metal wall
the light
4.timers
Please
use Elkay
threeboxes
wire Master
3.
DO
NOT
APPLY
MAINS
UNTIL
INSTRUCTED!
prior
to fitting.
For 16mm
Elkay provide
a
spacer
plate
2.
1.
and sensors)
Step
1
Ensure
that
the
mains
power
to
the
circuit
is
switched
off.
(product
code220A-1) to take boxLuxdepth
to
25mm.
level
Operation N
adjustment DIL
switches
Place the previously identified Live In into the terminal marked L In
If the Elkay Tim
and the switched Live Out into the L Out terminal.
Slave fitting
the unit into s
timers
are core
partcable
of the
Elkay family
When
connecting with slaves
use three
connecting
the of Step 2 - Switch the battery (switch 4) – you will notice a red LED
the unit press
light flashing on the front of the unit- which will be flashing
live
in, live out
and trigger
terminals aswhich
shown save
in Diagram
2. The
switches,
timers
and detectors
energy
and increase
the red LED sh
optional
wire to in
theand
slaves
only applies
to the 350A
and 550A
convenience
around
your home,
garden
or premises. rapidly. Whilst this is in action please select the desired timings
to a flash ever
by selecting the appropriate time settings shown in diagram 3.
push button slave units and is ideal for retrofitting (See diagram 2).
off. The unit w
Usage
automatically
The push button/touch timers are general purpose time controls.
Master
Slave
Step 3 - Attach the unit with the screws to the wall, then clip
Applications for suitable use include lighting and fans with
350A-1*
350A-3*
Outdoor Inst
on
the front fascia plate. The red LED light
will now change to a
IMPORTANT
NOTICE
lighting.The
timers
can be used independently or as a master unit
360A-1
360A-3
Please note on
single
every
3 seconds
approximately.
All wiring should be carried out by a competent person or a qualified electrician and should be
fittedflashing
to IEE 17thlight
Edition
Wiring
regulations
BS7671:2008. You are now
when using slave trigger switches. One master product only for
550A-3*
550A-5*
suitable for us
ready
to apply the mains power. The light
or chosen appliance
Please
note
that
the
trigger
terminal
is
the
third
terminal.
This
in conjunction
will
now start. Press and hold the button,
the red flashing light
each circuit being switched with additional slave units at other
560A-3
560A-5
product
requires
surface moun
goes off and the blue locator ring will light up around the
positions
in theacircuit.
and to ensure
push &
button/touch
Your light source or appliance will
Slave
Momentarypad.
Fitting
When used with some low wattage lighting, low voltage
cable gland an
now be
switched off
readyuse
for operation.
When
connecting
withand
slaves
three core cable connecting
lighting, LED fittings and 2D flouresecents, please ensure
the live in, live out and trigger terminals as shown in Diagram 2. surface moun
weamust
recommend our products from the three wire range.
capacitor of 4 microfarads is fitted at the load across the
Operation
The optional wire to the slaves only applies to the 350A and 550A supplied. Plac
switch live and neutral. Only one is required per circuit.
1. button
Press the
pushbutton/touch
padfor
andretrofitting
the red LED(See
will light
push
slave
units and is ideal
diagram 2). essential that
Installation
Steps
Supplies of suitable Elkay capacitors can be found at your
the IP66 rating
once. Your light source or appliance will now be switched
DOlocal
NOTstockist
APPLY MAINS
UNTIL
INSTRUCTED!
without seals
Please
theterminal
pushbutton
has third
an audible
click.
(ref PFCC-1).
Pleaseon.
note
thatnote
the that
trigger
is the
terminal.
Step 1 - Ensure that the mains power to the circuit is switched off.
2.
At
any
time
during
the
working
of
the
light
source
or
Momentary or activating switches can also be used and can be
IMPORTANT
Please
note that
essential
that the
live inLand
Turn off main
appliance,
push
padterminal
can be pressed
Place
the previously
identified
Live itInisinto
the terminal
marked
In
connected
to thethe
Live
In button/touch
and the Trigger
of the to
master.
are identified
prior
commencing
the installation and
reset the
timing sequence
topower
the originally
set time,
andlive
theout
switched
Live Out
intotothe
L Out terminal.
This product
requires
a 24 hour
supply.
The battery inside as per previou
steps
1
3
are
followed
precisely.
No
neutral
is
required
on
this
when the timing
is 30source
minutes,orif appliance
pressed 15 minutes
the unite.grecharges
whenperiod
the light
is switched onto surface
product (See diagram 1). Do not install the switch timer with the
ensuring even
into the sequence, the timer will reset to 30 minutes.
light
OFF. Where the supply may be interrupted or isolated regularly we
over left and
3. To end the timing sequence prematurely, press and hold the
mains power on as this can damage the product.
must recommend our products from the three wire range.
Re-instate ma
push button/touch pad until the red LED flashes
by Do
selecting
the appropriate
time settings
shown intest
diagram
3.
not megger
test or insulation
resistance
this product.
Your Elkay unit is compatible with a single gang, 25mm deep
Remove before testing or test circuit prior to fitting.
that the 3
top
Diagram
- and
time settings
Please ensure that when emergency fittings are tested for
bottom lugs are removed from metal
Forthe position of
Please wall
note boxes
that theprior
blacktobarfitting.
denotes
3 hr test that battery switch number 4 on the product is
16mm boxes Elkay provide a spacer plate (product code 220A-1)
switched off first and switched back on after test.
4. to 25mm. 4.
4.
4.
4.
to take box depth
LIVE IN
NEUTRAL
LIVE OUT
Battery
Lux level
adjustment
4.
3.
2.
1.
DIL
switches
Call +44 (0) 1675 468222 or click www.elkay.co.uk
ified electrician and should be fitted to IEE 17th Edition Wiring regulations BS7671:2008.
3.
2.
1.
2 mins
3.
2.
1.
5 mins
10 mins
3.
2.
1.
20 mins
3.
2.
1.
DIP
ate
Diagram 1
ON
eep
DIP
ING.
4.
3.
2.
1.
DIL
switches
ON
GGER
Battery
Lux level
adjustment
DIP
and
n
ed on
er
LIVE OUT
ON
ND
LIVE IN
NEUTRAL
8526 PUSH BUT & TOUCH INSTRUCTIONSv3_Layout 1 25/02/2010
DIP
A
ON
rols.
ng
tly or
er
slave
IMPORTANT
note that it is essential
the live in and
Touch
Push Pushbutton
ButtonPlease
Master
Touchthat
Master
live out are identified prior to commencing the installation
and steps 1 – 3 are followed precisely. No neutral is required on
this product (See diagram 1). Do not install the switch timer
with
the mains power on as this can damage the product.
Features
DiagramDiagram
1
1
DIP
ase
WHEN USED WITH SOME LOW WATTAGE LIGHTING,
HEATING AND VENTILATION CIRCUITS PLEASE ENSURE A
CAPACITOR OF 2 MICROFARADS (MINIMUM) IS FITTED.
SUPPLIES OF SUITABLE ELKAY CAPACITORS CAN BE FOUND
AT YOUR STOCKIST (REF PFCC-1)
Touch
ON
n - 2h
Usage
The push button/touch timer are general purpose time controls.
Applications for suitable use include lighting and some heating
and ventilation controls. The timers can be used independently or
as a master unit when using slave trigger switches. One master
product only for each circuit being switched with additional slave
units at other positions in the circuit.
Pushbutton
3.
2.
1.
40 mins
For further wiring diagrams and more information on our products ple
3.
onto surface mount box using the fixing screws at all four corners
ensuring even connection with the seal - Place screw hole seals
over left and right screw cavities - Clip on front fascia plate Re-instate mains supply.
e.g when the timing period is 30 minutes, if pressed 15 minutes
Diagram 3
Diagram 3 - time settings
2 mins
5 mins
10 mins
2.
1.
2.
20 mins
1.
40 mins
3.
2.
1.
60 mins
90 mins
4.
3.
2.
1.
DIP
4.
DIP
3.
DIP
DIP
DIP
4.
ON
1.
3.
ON
2.
4.
ON
1.
3.
ON
2.
4.
ON
1.
3.
ON
ON
2.
4.
DIP
3.
ON
DIP
4.
DIP
Please note that the black bar denotes the position of the dip switch
Please note that the black bar denotes the position of the dip switch.
4.
3.
2.
1.
120 mins
For further wiring diagrams and more information on our products please visit our website on www. elkay.co.uk
Installation Steps
Standby/Sleep Mode
IMPORTANT
NOTICE
DO NOT APPLY
MAINS UNTIL INSTRUCTED!
If the Elkay Timer does not receive power then the unit will put
be sleep
fitted to
IEE 17th
Wiring
BS7671:2008.
theshould
unit into
mode
to Edition
conserve
the regulations
battery. The
unit will
TECHNICAL
HELPLINE
attempt to latch on to the mains power 25 times automatically
off.
Place
the
previously
identifi
ed
Live
In
into
the
terminal
marked
For further help or assistance or information on this or other products in the range please call the Elkay Technical team on 01675 468222.
beforeIngoing
to sleepevent
mode
as you
mentioned
To manually
L In and
Out into
thereturning
L Out terminal.
Please
callthe
theswitched
TechnicalLive
helpline
before
any products to your stockist.
the unlikely
that
have to above
return .your
product
reactivate the unit press and hold for a period of 15 seconds
please ensure you switch the battery off first.
approximately, the red LED should start to flash rapidly, release
light flashing on the front of the unit- which will be flashing rapidly.
button, the LED changes to a flash every 3 seconds, press and
select
the
desired
timings
by
Elkay Electrical, Coleshill, Birmingham, England.hold again until load switches off. Leave in OFF condition for at
least 30 minutes before re-pressing.
Tel: +44 (0) 1675 468222 www.elkay.co.uk
on the front fascia plate. The red LED light will now change to a
single flashing light every 3 seconds approximately. You are now
ready to apply the mains power. The light or chosen appliance
will now start. Press and hold the button, the red flashing light
goes off and the blue locator ring will light up around the push
button/touch pad. Your light source or appliance will now be
switched off and ready for operation.
Operation
1. Press the pushbutton/touch pad and the red LED will light
once. Your light source or appliance will now be switched on.
Please note that the pushbutton has an audible click.
2. At any time during the working of the light source or appliance,
the push button/touch pad can be pressed to reset the timing
sequence to the originally set time, e.g when the timing period is
30 minutes, if pressed 15 minutes into the sequence, the timer
will restart to 30 minutes.
3. At one minute prior to the end of the timing sequence, the
red LED will begin to flash continuously for the last minute of
operation. The blue locator ring will then illuminate once the light
source or appliance has gone off.
4. To end the timing sequence prematurely, press and hold the
push button/touch pad until the red LED flashes continuosly
indicating the last minute countdown is in operation. Your light
source or appliance will be switched off after one minute.
IMPORTANT NOTICE All wiring should be carried out
by a competent person or qualified electrician and be
fitted to current IEE Edition wiring regulations.
Outdoor Installation (550A and 560A only)
Please note only products in the Elkay energy outdoor range
are suitable for use outdoors. Elkay energy outdoor can only
be used in conjunction with the surface mount box supplied.
Take the surface mount box and remove knockouts as required.
Ideally remove with a hole-saw for cleanest effect and remove
any burrs. Drill a small 3mm drain hole at the back of the box
in the position marked‘ DRAIN‘. Drill outwards from the inside
of the box. If required and to ensure IP66 waterproof rating,
please use a suitable M20 cable gland and use appropriate
sealing washers. Two yellow sealing washers are added for
your convenience. Mount the surface mount box on a secure
surface using the mounting pack supplied. Place screw cover
seals over the mounting screws. It is essential that the correct
IP66 rated connections are made to keep the IP66 rating of the
back box. Steel wire armored connections without seals are not
appropriate.
Turn off mains supply before proceeding with installation - Install
as per Installation Steps in these instructions. Mount unit onto
over left and right screw cavities - Clip on front fascia plate - Reinstate mains supply.
Emergency Light Fittings
When carrying out the 3hr annual Emergency test please ensure
that during the test that this timer is switched off at number 4 for
the duration of the test.
This intelligent timer can detect failed Emergency fittings or
ballasts and may go into Standby Mode. If this occurs remove
the faulty emergency fitting and follow the Standby/Sleep Mode
notes above.
TECHNICAL HELPLINE
01675 468222. Please call the Technical helpline before returning any products to your stockist. In the unlikely event that
you have to return your product please ensure you switch the battery off first.
UK Head Office, Station Road. Coleshill, Birmingham B46 1HT
Tel: +44 (0) 1675 468 222 Fax: +44 (0) 1675 464 930
www.elkay.co.uk
The Company‘s policy is one of continuous improvement and reserves
the right to change specifications at any time without prior notice.
