CCLADD-10W
CCLADD-10W
    ELKAY(埃尔凯)
    ELKAY - CCLADD-10W - Accessory, Elkay KU2D4 Multi Level Terminal Blocks, Fixed Bridge
CCLADD-10W 数据手册
KU2D4 - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Multi Level Terminal Blocks Connection Method Screw Connection Product Data Product Name KU2D4 Product Image Line Diagram Short Description Multi level terminal block - Screw Connection Full Description Terminal Type - KU2D4 , Multi level terminal block, nominal voltage: 500 V, nominal current: 24 A, connection method: Screw connection, number of connections: 4, cross section: 0.5 mm² - 4 mm², AWG: 20 12 , width: 6 mm , length: 50 mm , height : 50.8 mm , mounting type: NS 35/7.5, NS 35/15 , NS 32/15 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Your Advantages Since there are two function shafts per level, all potential distribution tasks can be implemented quickly . Two separate potentials can by routed side by side with the help of bridging between non-adjacent terminal blocks . Key Commercial Data Standard Weight 1.25 Kg Weight per Piece (excluding packing) 11.4 g Packing Unit 100 pc Minimum Order Quantity 100 pc GTIN Number 85389000 Country Of Origin INDIA 1 Technical Data - General Number of levels 2 Number of connections 4 Potentials 2 Nominal cross section 2.5 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V0/V2 Area of application Rated surge voltage 6 kV Degree of pollution 3 Overvoltage category III Maximum power dissipation for nominal condition 0.77 W Nominal Current IN 24 A Nominal Voltage UN 500 V Open side panel Yes Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 7.3 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 1.89 kV Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 0.5 mm² / 0.3 kg , 2.5 mm² / 0.7 kg , 4 mm² / 0.9 kg Tensile test result Test passed Conductor cross section tensile test 0.5 mm2 Tractive force setpoint 20 N Conductor cross section tensile test 2.5 mm2 Tractive force setpoint 50 N Conductor cross section tensile test 4 mm2 Tractive force setpoint 60 N Result of tight fit on support Test passed Tight fit on carrier NS 32 / NS 35 Setpoint 1 2 Result of voltage-drop test Test passed Requirements, voltage drop
CCLADD-10W 价格&库存
很抱歉,暂时无法提供与“CCLADD-10W”相匹配的价格&库存,您可以联系我们找货
