CHKENDCAP
CHKENDCAP
    ELKAY(埃尔凯)
    ELKAY - CHKENDCAP - Accessory, Elkay SPT120XL High-Current Terminal Blocks, End Cap
CHKENDCAP 数据手册
SPT120XL - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group High-Current Terminal Blocks Connection Method Bolt Connection Product Data Product Name SPT120XL Product Image Line Diagram Short Description High current connectors - Bolt connection Full Description Terminal Type – SPT120XL , High current connectors with secured hinged cover , nominal voltage: 1500 V, nominal current: 269 A, connection method: Bolt connection, Bolt with clinched conical ,number of connections: 2, cross section: 16 mm² - 120 mm² , width: 32 mm , length: 219 mm , height : 80.3 mm , mounting type: TS 35/7.5 and TS 35/15 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Key Commercial Data Standard Weight 1.4 Kg Weight per Piece (excluding packing) 280 g Packing Unit 10 pc Minimum Order Quantity 10 pc Country Of Origin India Technical Data - General Number of levels 1 1 Number of connections 2 Potentials 1 Nominal cross section 120 mm2 Insulating Material Polyamide 6 , 6 Flammability rating acc. to UL 94 V2(V0 - on customer demand) Rated surge voltage 8 kV Degree of pollution 3 Overvoltage category III Nominal Current IN 269 A Nominal Voltage UN 1000 V Open side panel No Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 9.8 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 2.2 kV Result of the test for mechanical stability of terminal points Test passed Result of tight fit on support Test passed Tight fit on carrier TS 35/7.5 and TS 35/15 Result of voltage-drop test Test passed Requirements, voltage drop
CHKENDCAP 价格&库存
很抱歉,暂时无法提供与“CHKENDCAP”相匹配的价格&库存,您可以联系我们找货
