CCLA35K-10W
CCLA35K-10W
    ELKAY(埃尔凯)
    ELKAY - CCLA35K-10W - Accessory, Elkay KUT35 Feed Through Terminal Blocks, Fixed Bridge
CCLA35K-10W 数据手册
KUT35 - Product Details General Information Company Elmex Group Product Category Terminal Blocks Product Group Feed Through Terminal Blocks Connection Method Screw Connection Product Data Product Name KUT35 Product Image Line Diagram Short Description Feed Through Terminal Block - Screw Connection Full Description Terminal Type - KUT35 , Feed-through terminal block, nominal voltage: 1000 V, nominal current: 125 A, connection method: Screw connection, number of connections: 2, cross section: 10 mm² - 35 mm², AWG: 8 - 1, width: 17 mm , length: 51 mm , Height : 58 mm , mounting type: TS35/7.5 , TS35/15 , and TS32 Approvals Standard Colour Gray Colour Variants Black , Blue , Green , Khakhi , Red , Yellow , Your Advantages Easy and time-saving potential supply and distribution of large currents and cross sections up to 35 mm² with reducing bridges Key Commercial Data Standard Weight 2.9 Kg Weight per Piece (excluding packing) 55.7 g Packing Unit 50 pc Minimum Order Quantity 50 pc GTIN Number 85389000 Country Of Origin India 1 Technical Data - General Number of levels 1 Number of connections 2 Potentials 1 Nominal cross section 35 mm2 Insulating Material Polyamide 6 , 6 Clamping Material CRCA Flammability rating acc. to UL 94 V2 (V0 - on customer demand) Area of application Rated surge voltage 8 kV Degree of pollution 3 Overvoltage category III Maximum power dissipation for nominal condition 4W Nominal Current IN 125 A Nominal Voltage UN 1000 V Open side panel No Back of the hand protection Guaranteed Finger Protection Guaranteed Result Of Surge Voltage Test Test passed Surge Voltage Test Setpoint 9.8 kV Result of power-frequency withstand voltage test Test passed Power frequency withstand voltage setpoint 2.2 kV Result of the test for mechanical stability of terminal points Test passed Result of bending test Test passed Bending test rotation speed 9 Bending test turns 135 Bending test conductor cross section/weight 10 mm² / 2 kg ,35 mm² / 6.8 kg Tensile test result Test passed Conductor cross section tensile test 10 mm2 Tractive force setpoint 90 N Conductor cross section tensile test 35 mm2 Tractive force setpoint 190 N Conductor cross section tensile test 35 mm2 Tractive force setpoint 190 N Result of tight fit on support Test passed Tight fit on carrier TS35/7.5 , TS35/15 , and TS32 Setpoint 10 2 Result of voltage-drop test Test passed Requirements, voltage drop
CCLA35K-10W 价格&库存
很抱歉,暂时无法提供与“CCLA35K-10W”相匹配的价格&库存,您可以联系我们找货
