2118.79
2118.79
    AEMC
2118.79 数据手册
▼▼ C Accurate with results within 0.05% 0.1μΩ 1μΩ 10μΩ 0.1mΩ 1mΩ 10mΩ 100mΩ 10A 10A 10A 1A 100mA 10mA 1mA Measurement Mode FEATURES Metal Type Alpha Two – programmable set points from 0.0 to 2500.0Ω cover closed Memory Stores up to 1500 test results; Data in memory can be reviewed on the instrument display, on a PC or via direct printout CATALOG NO. DESCRIPTION 2129.81 Accessories (Optional) 1017.84 2118.70 2118.73 2118.74 2118.75 2118.76 2118.77 2118.78 2118.79 2118.80 2119.45 2129.95 2129.96 10A Micro-Ohmmeter Model 6250 TE ' RR E C TI Selectable: Copper, Aluminum or Other Metal Programmable from 000.00 to 99.99 Alarms • Measure  from 1µΩ (0.1µΩ resolution) to 2500.0Ω • Test current selection of 1mA, 10mA, 100mA, 1A and 10A • RTD temperature probe to check tested sample (optional) • Selectable metal types • Automatic and manual temperature correction • Two programmable alarm set points • Stores up to 1500 test results • Selectable inductive or resistive test modes • Automatic multiple test mode (multiple tests without pressing the test button) • Large multi-line electroluminescent display • Local or remote test setup and control • Internal rechargeable batteries conduct up to 5000 – 10A tests • Rugged, double insulated waterproof case • Includes RS-232 to USB 2.0 cable and AC line cord • Includes FREE DataView ® ­software for data storage, real-time display, a ­ nalysis and report ­generation R P E AT U Selectable: Inductive (continuous test), Resistive (instantaneous test) or Auto (multiple tests) IP 65 Rated M CO Resolution Test Current 6250 5.0000 25.000 250.00 2500.0 25.000 250.00 2500.0 mΩ mΩ mΩ mΩ Ω Ω Ω 0.15% of 0.05% of 0.05% of 0.05% of 0.05% of 0.05% of 0.05% of Reading Reading Reading Reading Reading Reading Reading +1.0μΩ + 3μΩ + 30μΩ + 0.3mΩ + 3mΩ + 30mΩ + 300mΩ 0 TEST '' Accuracy 50 ORES RE Range ST 1 MODEL CURAC S SPECIFICATIONS Y 0 . 15% A Model 6250 Special Special product product features features Power Source Rechargeable 6V, 8.5Ah NiMH battery pack (included) Battery Life Approximately 5000 10A tests ACCESSORIES Kelvin clips, set of two Catalog #1017.84 (included) (10A – Hippo) 10 ft Catalog #2118.70 (optional) (10A – Hippo) 20 ft Kelvin clips, set of two (optional) Catalog #2118.79 (1-10A) 10 ft Catalog #2118.80 (1-10A) 20 ft Kelvin probes, set of two (optional) Catalog #2118.77 (10A – spring loaded) 10 ft Catalog #2118.78 (10A – spring loaded) 20 ft Kelvin probes pistol grip, set of two (optional) Catalog #2118.75 (10A – spring loaded) 10 ft Catalog #2118.76 (10A – spring loaded) 20 ft Kelvin probes, set of two (optional) Catalog #2118.73 (1A – spring loaded) 10 ft Catalog #2118.74 (1A – spring loaded) 20 ft RTD Temperature Probe (optional) Catalog #2129.95 RTD probe plugs into faceplate Catalog #2129.96 RTD probe w/7 ft extension cable USB Stick Supplied with DataView ® software and user manual Kelvin Clips 10 ft (10A – Hippo) Kelvin Clips 20 ft (10A – Hippo) Kelvin Probes 10 ft (1A, Spring Loaded) Kelvin Probes 20 ft (1A, Spring Loaded) Kelvin Probes Pistol Grip (10A – spring loaded), set of two, 10 ft Kelvin Probes Pistol Grip (10A – spring loaded), set of two, 20 ft Kelvin Probes (10A – spring loaded), set of two, 10 ft Kelvin Probes (10A – spring loaded), set of two, 20 ft Kelvin Clips 10 ft (1-10A) Replacement for Cat #2118.71 Kelvin Clips 20 ft (1-10A) Replacement for Cat #2118.72 Cable, PC RS-232, DB9 F/F 6 ft Null Modem Cable RTD Temperature Probe (plug into faceplate for ambient temperature) RTD Temperature Probe with 7 ft extension cable Technical Assistance (800) 343-1391 N MICRO-OHMMETERS 10A Digital www.aemc.com O
2118.79 价格&库存
很抱歉,暂时无法提供与“2118.79”相匹配的价格&库存,您可以联系我们找货
