275HVD
275HVD
    AEMC
    AEMC INSTRUMENTS - 275HVD - HIGH VOLTAGE DETECTOR, 240 TO 275kV, LED
275HVD 数据手册
Non-Contact High Voltage Detector Model 275HVD The Model 275HVD is designed to detect the presence of high voltage without physical contact. An eight position rotary switch selects the detection range. As the sensor is moved closer to the voltage carrying conductor, its sensor head picks up the radiated electric field. Once the range threshold is reached, the buzzer sounds and a bright red warning light warns the operator of live conductors. Model 275HVD has a self-test position that ensures that all circuitry and annunciators are working properly by energizing the complete system. and can be used both in- and out-ofdoors. A universal spline on the backend facilitates attachment to any standard hot stick. The Model 275HVD is powered by three standard Alkaline C cell batteries Model 275HVD (pdf) Technical Assistance (800) 343-1391 Rev. 05 www.aemc.com 11/05 1 of 5 Model 275HVD checking for live voltage on main feeder Applications Features • Non-contact high voltage detector • Wide range of detection; finds 80V to 275kV; one instrument fits all applications • Eight switch-selectable voltage sensitivity ranges • Lightweight, minimizes sway at the end of long hot sticks • Self-test ensures that all system functions and indicators are working properly by energizing the complete system • Non-contact detection of live voltages • Designed for use with hot sticks incorporating a universal spline adapter • Find faults in cables • Audible and visual indication of live voltage • Check and detect live high voltage cables • Check grounding equipment • Service neon lighting • Trace live wires • Check high frequency radiation • Detect residual or induced voltages Model 275HVD (pdf) Technical Assistance (800) 343-1391 Rev. 05 www.aemc.com 11/05 2 of 5 Specifications MODEL 275HVD ELECTRICAL Detection Frequency Ranges Detection 40 to 70Hz 240V, 2kV, 6kV, 11kV, 22kV, 33kV, 132kV, 275kV Selection range is detected at approximately 10" (25cm) from the voltage Greater detection distances can be obtained at lower voltage positions MECHANICAL Self Test Indicators Power Source ENVIRONMENTAL Operating Temperature Storage Temperature Humidity User selectable Bright red LED and audible buzzer Three 1.5V C cell batteries 5° to 130°F (-15° to 55°C) -4° to 150°F (-20° to 65°C) 0 to 93% RH @ 104°F (40°C) Model 275HVD (pdf) Technical Assistance (800) 343-1391 Rev. 05 www.aemc.com 11/05 3 of 5 Construction Buzzer — high audible level Rotary selector with the following settings: • • • • • Large bright red warning light (two LEDs) OFF TEST 240V 2kV 6kV • • • • • 11kV 22kV 33kV 132kV 275kV Battery holder/handle Universal spline for hot stick connection Universal spline for hot stick connection Model 275HVD includes three C cell batteries, a hard carrying case and user manual ORDERING INFORMATION CATALOG NO. Non-Contact High Voltage Detector Model 275HVD (240V to 275kV) Manual self-test. . . . . . . . . . . . . . . . . . . . . . . . . Cat. #2131.12 CIncludes three C cell batteries, padded carrying case and user manual Models 275HVD (pdf) Technical Assistance (800) 343-1391 Rev. 05 www.aemc.com 11/05 4 of 5 Contact Us United States & Canada: Chauvin Arnoux®, Inc. d.b.a. AEMC ® Instruments 200 Foxborough Blvd. Foxborough, MA 02035 USA (508) 698-2115 • Fax (508) 698-2118 www.aemc.com Customer Support – for placing an order, obtaining price & delivery: customerservice@aemc.com Sales Department – for general sales information: sales@aemc.com Repair and Calibration Service – for information on repair & calibration, obtaining a user manual: repair@aemc.com Technical and Product Application Support – for technical and application support: techinfo@aemc.com Webmaster – for information regarding www.aemc.com: webmaster@aemc.com South America, Central America, Mexico, Caribbean, Australia & New Zealand: Chauvin Arnoux®, Inc. d.b.a. AEMC ® Instruments 15 Faraday Drive Dover, NH 03820 USA (978) 526-7667 • Fax (978) 526-7605 export@aemc.com www.aemc.com All other countries: Chauvin Arnoux SCA 190, rue Championnet 75876 Paris Cedex 18, France 33 1 44 85 45 28 • Fax 33 1 46 27 73 89 info@chauvin-arnoux.com www.chauvin-arnoux.com Models 275HVD (pdf) Technical Assistance (800) 343-1391 Rev. 05 www.aemc.com 11/05 5 of 5
275HVD 价格&库存
很抱歉,暂时无法提供与“275HVD”相匹配的价格&库存,您可以联系我们找货
