Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
Loudspeakers and
Accessories
and
Search
Accessories
Home | Single Drivers / Accessories | Kits | Car-Hifi | High End | Industry | Public Address |
Industry
FRS 5 8 OHM
New products
Fullrange Systems
F 8 SC 8 OHM
FR 10 4 OHM
FR 10 8 OHM
FR 10 F 4 OHM
FR 10 HM 4 OHM
FR 10 HM 8 OHM
FR 10 WP 4 OHM (black)
FR 10 WP 4 OHM (white)
FR 12 4 OHM
FR 12 8 OHM
FR 13 4 OHM
FR 13 WP 4 OHM (black)
FR 13 WP 4 OHM (white)
FR 16 WP 4 OHM (black)
FR 16 WP 4 OHM (white)
FR 6,5" 8 OHM
FR 7 4 OHM
FR 8 4 OHM
FR 87 4 OHM
FR 8 8 OHM
FR 8 JS 8 OHM
FR 8 WP 4 OHM (black)
FR 8 WP 4 OHM (white)
FR 8 WP 8 OHM (white)
FR 9.15 4 OHM
FRS 10 WP 4 OHM
(black)
FRS 10 WP 4 OHM
(white)
FRS 10 WP 8 OHM
(black)
FRS 10 WP 8 OHM
(white)
FRS 5 8 OHM
FRS 7 4 OHM
FRS 7 8 OHM
FRS 7 S 8 OHM
FRS 7 W 8 OHM
FRS 8 4 OHM
FRS 8 8 OHM
FRS 8 M 8 OHM
FRWS 5 4 OHM
FRWS 5 8 OHM
FRWS 5 R 8 OHM
FRWS 5 SC 8 OHM
K 50 8 OHM
K 50 SQ 8 OHM
K 50 WP 50 OHM
K 50 WP 8 OHM
Art. No. 2231
5 cm (2") full-range speaker with a special basket design
featuring two fixing lugs. Suitable as a medium-range driver
in speaker systems for HiFi and background music and for
100V PA systems. Thanks to the slim construction, also
suitable as a control speaker in electronic devices.
Typical applications:
- Very narrow network column speakers
- Control speaker for electronic devices
- Model construction
- Electronic musical instruments
Attributes:
- Moisturised cone
- Metal basket
Technical Data:
Rated power
Maximum power
Nominal impedance Z
Frequency response
sketch
Mean sound pressure
level
Maximum cone
displacement
Resonance frequency fs
Magnetic induction
Magnetic flux
frequency- and impedance response
http://www.visaton.com/en/industrie/breitband/frs5_8.html (1 of 2)20/01/2009 09:12:25
5W
8W
8 Ohm
150–20000 Hz
84 dB (1 W/1 m)
4 mm
270 Hz
0,95 T
105 µWb
Height of front pole-plate
2,5 mm
Voice coil diameter
14 mm
Height of winding
3,7 mm
Cutout diameter
46 mm
Net weight
0,126 kg
D.C. resistance Rdc
7,2 Ohm
Mechanical Q factor Qms
3,19
Electrical Q factor Qes
1,81
Total Q factor Qts
1,15
Equivalent volume Vas
0,2 l
Effective piston area Sd
Dynamically moved
mass Mms
Force factor Bxl
12 cm²
0,5 g
1,6 T m
K 64 WP 50 OHM
K 64 WP 8 OHM
K 64 WPT 8 OHM
R 10 S 4 OHM
R 10 S 8 OHM
R 10 SC 4 OHM
R 10 SC 8 OHM
SC 4.7 ND 4 OHM
SC 4.7 ND 8 OHM
SC 5.9 8 OHM
SC 5.9 ND 4 OHM
SC 5.9 ND 8 OHM
SC 8 N 8 OHM
SL 713 4 OHM
SL 87 WPM 4 OHM
SL 87 WPM 8 OHM
Bass Midranges
Miniature Speakers
Magnetically Shielded
Speakers
Waterproof Speakers
Re-Entrant Horn Speakers
Inductance of the voice
coil L
0,2 mH
−25 ... 70 °C
Heat resistance
Similar Products
Radiation pattern 2000 Hz
http://www.visaton.com/en/industrie/breitband/frs5_8.html (2 of 2)20/01/2009 09:12:25
FRWS 5 4 OHM
FRWS 5 8 OHM
FRWS 5 R 8 OHM
FRWS 5 SC 8 OHM
K 50 8 OHM
K 50 SQ 8 OHM
K 50 WP 50 OHM
K 50 WP 8 OHM
Radiation pattern 5000 Hz
Radiation pattern 10000 Hz
很抱歉,暂时无法提供与“2231”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+144.99030
- 2+136.91024
- 3+128.83017
- 5+120.75011
- 10+112.65818
- 20+110.41569
