FRS 7 W - 8 OHM
FRS 7 W - 8 OHM
    VISATON
    FULL-RANGE SPEAKER
FRS 7 W - 8 OHM 数据手册
CONTROL 25-1 Compact Indoor/Outdoor Background/Foreground Speaker Professional Series Features: Components: • 5-¼” woofer with woven fiberglass cone • 3/4” PEI diaphragm tweeter with fluid cooling Contemporary, high-design appearance Built-in InvisiBall® mounting hardware*, plus available U-bracket Weather resistant enclosure and transducers Wide 100° x 100° coverage 100 Watt power handling (200 Watt program) in direct 8Ω setting, plus built-in 30 Watt 70V/100V multi-tap transformer. High fidelity sound character with broad frequency response of 60 Hz – 20 kHz. Applications: The Control® 25-1 is a two-way 5” speaker with rich sonic character, wide coverage, consistent dispersion, versatile mounting, and a contemporary highdesign look that fits into a wide range of decors. This makes Control 25-1 an excellent choice for a wide variety of applications, including retail stores, restaurants, health clubs, theme parks, educational facilities, hospitality, music cafes, leisure venues, and anywhere where a top quality high-output indoor/ outdoor foreground/background music (and/or paging) speaker is required. The unique InvisiBall mounting hardware is included with each system, making short work of permanent installation. The InvisiBall mounting method provides a high degree of both vertical and horizontal rotation, and because InvisiBall adjustments are made through a hidden access behind the logo badge, the grille never needs to be removed, and there exists a high degree of theft deterrence as well. Integrated M6 mounting points for an optional U-bracket adds to the installation versatility. The LF driver’s woven fiberglass cone provides durability and weather capable performance. The light weight high temperature fiberglass voice coil former and high temperature voice coil wire ensure high sensitivity and high power handling, while also providing stable performance under long-term high-power working conditions. The pure butyl rubber surround delivers clean sound and robust operation. JBL’s WeatherEdge™ is a seamless, rubberized extension of the woofer surround that provides added protection to critical transducer elements. Cone geometry is optimized for smooth frequency response and consistent off-axis performance, while an FEA-optimized motor construction and linear suspension spider helps to lower harmonic distortion. The HF driver’s low viscosity ferro-magnetic fluid increases voice coil cooling for higher long-term power handling. The softened PEI diaphragm delivers a smooth and pure high frequency sound quality. The light weight Kapton™ voice coil former increases durability while providing better high frequency response extension. All these factors also contribute toward making the driver especially rugged for outdoors and other stressful applications. In addition to the driver designs contributing toward a high degree of weather resistance, the cabinet provides excellent endurance against sun, salt and moisture. Grilles are heavily zinc-plated and finished in a tough, high-grade powder coating for rust resistance. The optional MTC-25WMG WeatherMax™ grilles are available for especially difficult environments and to break up driving rain. Connection is made via weather-capable screw-down terminals. The optional MTC-PC2 and MTC-PC3 panel covers are available to protect the terminal compartment, providing a water-tight sealed gland-nut entrance (when used with round-jacketed cable within the specified diameter range). The frequency response is extremely smooth, resulting in a very natural sound character, and the response extends down to 60 Hz, providing strong bass capability. The system is capable of handling 100 Watts continuous pink noise (200 Watts program) at its 8 ohm setting and is also equipped with a built-in 30 Watt 70V/100V multi-tap transformer for operation on distributed speaker lines. The combination of high sensitivity and power handling provides high Max SPL of 110 dB. The Control 25-1 readily accepts a variety of paints and finishes to match any décor. Available in black or white (-WH). CONTROL 25-1 Compact Indoor/Outdoor Background/Foreground Speaker Specifications: Frequency Range (-10 dB): Frequency Response (+/-3 dB): Power Rating2: Maximum Input Voltage: Maximum SPL3: Sensitivity4: Coverage Angle5: 60 Hz to 20 kHz 85Hz - 17 kHz 200 W Continuous Program (2 hrs) 100 W (400W peak), Continuous Pink Noise (2 hrs) 75 W (300W peak) Continuous Pink Noise (100 hrs) 25.3 V RMS (2 hrs), 50.6 V peak 110 dB ave. Continuous Pink Noise (116 dB peak) 90 dB, 1W/1m (ave. 100 Hz – 10 kHz) 100° x 100° Directivity Factor (Q): 6.04 (averaged 1kHz – 16kHz) Directivity Index (DI): 7.6dB (averaged 1kHz – 16kHz) Nominal Impedance: Crossover Type: 8 ohms (THRU setting) 2nd order low-pass, 3rd order high-pass Circuitry: Transformer Taps: Recommended Protective High-Pass6: 70V: 30W, 15W, 7.5W, 3.7W 100V: 30W, 15W, 7.5W Insertion Loss
FRS 7 W - 8 OHM 价格&库存
很抱歉,暂时无法提供与“FRS 7 W - 8 OHM”相匹配的价格&库存,您可以联系我们找货
FRS 7 W - 8 OHM
  • 75+105.6728975+13.67041
