2502-2722-020
2502-2722-020
    COMUS(康姆斯)
2502-2722-020 数据手册
Reed Switch - Miniature - Normally Open Contacts Part Number : GC2722 Product Data Sheet PICTURE DIMENSIONS 2.6Ø (0.102) 19 (0.748) 55.0 (2.165) 0.55Ø (0.0217) Drawings not to scale All dimensions in mm (inches) nominal. SPECIFICATION Contact Form Contact Material Switching Capacity Switching Voltage Switching Current Carrying Current Dielectric Strength Contact Resistance Insulation Resistance Pull - In - Sensitivity Drop - Out - Sensitivity Bounce Time Release Time Resonant Frequency Operating Frequency Vibration (10-1000Hz) Shock (11 ms) Capacitance Operating Temperature Range Test Coil Normally Open Rhodium 12 VA 230 VAC/DC 1.0 A 2.0 A 400 VDC 100 mOhms 11 10 30 - 50 AT 5 0.5 ms 0.10 ms 2900 Hz 200 Hz 35 g 50 0.5 pF -40°C + 125°C 1700 Max. Max. Max. Max. Min. Max. Min. Min. Max. Max. Typ. Max. Typ. Type NOTE Ordering Information When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm (.118in.) to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. We offer a crop and form service for Reed Switches to be customized to your specification. Did you know we also sell? Float Switches Magnets Movement Sensors Proximity Switches Acceleration / Shock Switches Reed Relays Solid State Relays PART NUMBER 2722 30 50 Type Minimum (AT) Sensitivity Maximum (AT) Sensitivity Example: Type 2722 Standard Sensitivity. Pull-in sensitivity between 30-50 AT is PART NO: 2722 30 50 Available in ranges of 5 AT e.g: 30-35, 35-40 etc. Rev. No. Revision Note Date Signature 2 Datasheet Redesign 26-05-06 NG As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone : (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 ©2006 Copyright Comus International Ltd, 454 Allwood Road, Clifton, New Jersey, 07012, USA.
2502-2722-020 价格&库存
很抱歉,暂时无法提供与“2502-2722-020”相匹配的价格&库存,您可以联系我们找货
    库存:2830
    2502-2722-020
      库存:2830
      2502-2722-020
      • 1+11.45522
      • 15+11.23653
      • 50+10.89288
      • 100+10.63253
      • 500+10.40343
      库存:151
