8601-0211-015
8601-0211-015
    COMUS(康姆斯)
8601-0211-015 数据手册
Reed Switch - Sub-Micro - Normally Open Contacts Part Number : ORD211 Product Data Sheet PICTURE DIMENSIONS 2Ø (0.079) 0.4Ø (0.0157) 10 (0.398) 35.7 (1.41) Drawings not to scale All dimensions in mm (inches) nominal. SPECIFICATION Contact Form Contact Material Switching Capacity Switching Voltage Switching Current Carrying Current Dielectric Strength Contact Resistance Insulation Resistance Pull - In - Sensitivity Drop - Out - Sensitivity Bounce Time Release Time Resonant Frequency Operating Frequency Vibration (10-1000Hz) Shock (11 ms) Capacitance Operating Temperature Range Test Coil Normally Open Rhodium 1 VA 24 VAC/DC 0.1 A 0.3 A 150 VDC 100 mOhms 9 10 10 - 40 AT 5 0.3 ms 0.05 ms 7500 Hz 500 Hz 20 g 30 0.2pF -40°C + 125°C 0211 Max. Max. Max. Max. Min. Max. Min. Min. Max. Max. Typ. Max. Typ. Type NOTE Ordering Information When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm (.118in.) to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. We offer a crop and form service for Reed Switches to be customized to your specification. Did you know we also sell? Float Switches Magnets Movement Sensors Proximity Switches Acceleration / Shock Switches Reed Relays Solid State Relays PART NUMBER ORD211 10 40 Type Minimum (AT) Sensitivity Maximum (AT) Sensitivity Example: Type ORD211 Standard Sensitivity. Pull-in sensitivity between 10-40 AT is PART NO: ORD211 10 40 Available in ranges of 5 AT e.g: 10-15, 15-20 etc. Rev. No. Revision Note Date Signature 2 Datasheet Redesign 08-06-06 NG As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone : (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 ©2006 Copyright Comus International Ltd, 454 Allwood Road, Clifton, New Jersey, 07012, USA.
8601-0211-015 价格&库存
很抱歉,暂时无法提供与“8601-0211-015”相匹配的价格&库存,您可以联系我们找货
