ASLS10
ASLS10
    COMUS(康姆斯)
ASLS10 数据手册
FORM AE043 ISS1 PRODUCT DATA SHEET Comus Group of Companies Manufactured in UK Farnell Code : 4229060 Direction of acceleration to close contacts ❿ 18.0 (.709) Max. 0.5ø (.020) 4.6ø (.181) Max. 2.92 (.114) 6.8 (.268) Drawings not to scale All dimensions in mm (inches) nominal SPECIFICATION CONTACT FORM/STYLE SWITCHING VOLTAGE SWITCHING CURRENT SWITCHING CAPACITY (RESISTIVE) CONTACT RESISTANCE OPERATING TEMPERATURE STORAGE TEMPERATURE ACTIVATION LEVEL CASE MATERIAL Max. Vac Max. A Max. VA Max. Ω Deg. ˚C Deg. ˚C G Normally open 24 0.25 5 10 -20˚ + 85˚ -25˚ + 90˚ 10 - 14.9 Steel - gold plated NOTE: When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm (.118) to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. PART NUMBER ACCELERATION and SHOCK SWITCH ASLS-10 Rev. No. Revision Note Date Signature B Web Site 2001 1-2-01 RG As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and details of our full design and manufacturing service. All products are supplied to our standard conditions of sale otherwise agreed in writing. © 2001 Copyright Comus Group of Companies The Comus Group of Companies consist of: Assemtech Europe Limited E. Bachem GmbH Comus International W. Gunther GmbH Gunther Belgium Gunther France S.T.G.
ASLS10 价格&库存
很抱歉,暂时无法提供与“ASLS10”相匹配的价格&库存,您可以联系我们找货
