GC1917 80/120
GC1917 80/120
    COMUS(康姆斯)
    COMUS - GC1917 80/120 - Reed Switch, GC1917, SPDT, Through Hole, 1 A, 400 V, 60 VA
GC1917 80/120 数据手册
Reed Switch - Standard - Change-Over Contacts Part Number : GC1917 Product Data Sheet PICTURE DIMENSIONS 5.6Ø (0.2205) 2.5 x 0.5 (0.0984 x 0.0197) 36 (1.4173) 70 (2.7559) Drawings not to scale All dimensions in mm (inches) nominal. SPECIFICATION Contact Form Contact Material Switching Capacity Switching Voltage Switching Current Carrying Current Dielectric Strength Contact Resistance Insulation Resistance Pull - In - Sensitivity Drop - Out - Sensitivity Bounce Time Release Time Resonant Frequency Operating Frequency Vibration (10-1000Hz) Shock (11 ms) Capacitance Operating Temperature Range Test Coil Change-Over Rhodium 60 VA 400 VAC/DC 1.0 A 2.0 A 1000 VDC 100 mOhms 9 10 50 - 80 AT 20 0.5 ms 0.15 ms 100 Hz 35 g 50 1.0 pF -40°C + 125°C 1500 Max. Max. Max. Max. Min. Max. Min. Min. Max. Max. Typ. Max. Typ. Type NOTE Ordering Information When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm (.118in.) to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. We offer a crop and form service for Reed Switches to be customized to your specification. Magnets Movement Sensors Proximity Switches Acceleration / Shock Switches Reed Relays 1917 50 80 Type Minimum (AT) Sensitivity Maximum (AT) Sensitivity Example: Type 1917 Standard Sensitivity. Pull-in sensitivity between 50-80 AT is PART NO: 1917 50 80 Available in ranges of 5 AT e.g: 50-55, 55-60 etc. Did you know we also sell? Float Switches PART NUMBER Solid State Relays Rev. No. Revision Note Date Signature 2 Datasheet Redesign 05-06-06 NG As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone : (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 ©2006 Copyright Comus International Ltd, 454 Allwood Road, Clifton, New Jersey, 07012, USA.
GC1917 80/120 价格&库存
很抱歉,暂时无法提供与“GC1917 80/120”相匹配的价格&库存,您可以联系我们找货
