GC3817 30/50
GC3817 30/50
    COMUS(康姆斯)
    COMUS - GC3817 30/50 - REED SWITCH, SPST-NO, 3A, 400V
GC3817 30/50 数据手册
Reed Switch - Compact - Normally Open Contacts Part Number : GC3817 Product Data Sheet PICTURE DIMENSIONS 3.80Ø (0.1496) 24.5 (0.965) 55 (2.165) 0.8Ø (0.0315) Drawings not to scale All dimensions in mm (inches) nominal. SPECIFICATION Contact Form Contact Material Switching Capacity Switching Voltage Switching Current Carrying Current Dielectric Strength Contact Resistance Insulation Resistance Pull - In - Sensitivity Drop - Out - Sensitivity Bounce Time Release Time Resonant Frequency Operating Frequency Vibration (10-1000Hz) Shock (11 ms) Capacitance Operating Temperature Range Test Coil Normally Open Rhodium 60 VA 400 VAC/DC 3.0 A 4.0 A 1000 VDC 80 mOhms 11 10 30 - 70 AT 15 0.5 ms 0.10 ms 2400 Hz 200 Hz 35 g 50 0.5 pF -40°C + 125°C 1800 Max. Max. Max. Max. Min. Max. Min. Min. Max. Max. Typ. Max. Typ. Type NOTE Ordering Information When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm (.118in.) to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. We offer a crop and form service for Reed Switches to be customized to your specification. Magnets Movement Sensors Proximity Switches Reed Switches Reed Relays 3817 30 70 Type Minimum (AT) Sensitivity Maximum (AT) Sensitivity Example: Type 3817 Standard Sensitivity. Pull-in sensitivity between 30-70 AT is PART NO: 3817 30 70 Available in ranges of 5 AT e.g: 30-35, 35-40 etc. Did you know we also sell? Float Switches PART NUMBER Solid State Relays Rev. No. Revision Note Date Signature 2 Datasheet Redesign 26-05-06 NG As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone : (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 ©2006 Copyright Comus International Ltd, 454 Allwood Road, Clifton, New Jersey, 07012, USA.
GC3817 30/50 价格&库存
很抱歉,暂时无法提供与“GC3817 30/50”相匹配的价格&库存,您可以联系我们找货
GC3817 30/50
    库存:598
