AU2100-0
AU2100-0
    COMUS(康姆斯)
AU2100-0 数据手册
FORM AE043 ISS1 PRODUCT DATA SHEET Comus Group of Companies Farnell Code : 4229101 3.17 (.125) 2.44 (.096) 6.35 (.250) 1.98 (.078) .46 (.018) Contact Open Differential Angle 15° Deg. Max. Horizontal Contact Closed SWITCH OPERATION Drawings not to scale All dimensions in mm (inches) nominal SPECIFICATION CONTACT FORM/STYLE SWITCHING VOLTAGE SWITCHING CURRENT SWITCHING CAPACITY CONTACT RESISTANCE OPERATING TEMPERATURE STORAGE TEMPERATURE CASE MATERIAL FEATURES Max. Vac Max. A Max. VA Max. Ω Deg. ˚C Deg. ˚C Non Mercury 50 0.15 2.0 30 -37 +100 -37 +125 Steel, gold plated Gold plated contacts. Hermetically sealed construction NOTE: When cutting or bending switch leads it is important that the glass seal is not damaged. The cutting or bending point should be no closer than 3mm to the glass to metal seal and the lead should be supported between the cutting or bending point and the glass to metal seal. TILT SWITCH / MOTION SENSOR PART NUMBER Micro-Miniature AU2100-0 The Comus Group of Companies consist of: Assemtech Europe Limited A Web Site 2002 1-10-02 RG E. Bachem GmbH As part of the company policy of continued product improvement, specifications may change without notice. Our sales Comus International office will be pleased to help you with the latest information on this product range and details of our full design and W. Gunther GmbH Gunther Belgium manufacturing service. All products are supplied to our standard conditions of sale otherwise agreed in writing. Gunther France S.T.G. ©2001 Copyright Comus Group of Companies Rev. No. Revision Note Date Signature
AU2100-0 价格&库存
很抱歉,暂时无法提供与“AU2100-0”相匹配的价格&库存,您可以联系我们找货
AU2100-0
    • 1+126.10116
    库存:98
