GOFORD
G3035-23
Description
D
The G3035-23 uses advanced trench technology to provide
excellent RDS(ON), This device is suitable for use as a load
G
switch or in PWM applications.
General Features
S
VDSS
RDS(ON)
RDS(ON)
ID
58mΩ
40 mΩ
-5 A
@ -4.5V(Typ) @ -10V (Typ)
-30V
Schematic diagram
● High power and current handing capability
● Lead free product is acquired
Marking and pin assignment
● Surface mount package
Application
● PWM applications
● Load switch
● Power management
SOT-23
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
ID
-5
A
IDM
-20
A
PD
1.2
W
TJ,TSTG
-55 To 150
RθJA
90
℃/W
Drain Current-Continuous
Drain Current-Pulsed
(Note 1)
Maximum Power Dissipation
Operating Junction and Storage Temperature Range
Thermal Characteristic
Thermal Resistance,Junction-to-Ambient (Note 2)
Electrical Characteristics (TA=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=-250μA
-30
V
Zero Gate Voltage Drain Current
IDSS
VDS=-24V,VGS=0V
-1
μA
Off Characteristics
HTTP://www.gofordsemi.com TEL:0755-29961262 FAX:0755-29961466
Page 1
GOFORD
G3035-23
Parameter
Symbol
Condition
Min
Typ
Max
Unit
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=-250μA
-1
-1.55
-3
V
Drain-Source On-State Resistance
RDS(ON)
VGS=-10V, ID=-1A
40
55
mΩ
VGS=-4.5V, ID=-1A
58
85
mΩ
VDS=-5V,ID=-4.1A
5.5
S
650
PF
105
PF
65
PF
8.5
nS
Gate-Body Leakage Current
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
gFS
(Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
Crss
VDS=-15V,VGS=0V,
F=1.0MHz
(Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=-15V,RL=3.6Ω
4.5
nS
td(off)
VGS=-10V,RGEN=3Ω
26
nS
Turn-Off Delay Time
Turn-Off Fall Time
tf
12.5
nS
Total Gate Charge
Qg
12.5
nC
Gate-Source Charge
Qgs
2.8
nC
Gate-Drain Charge
Qgd
2.7
nC
-1.2
V
VDS=-15V,ID=-4A,VGS=-10V
Drain-Source Diode Characteristics
Diode Forward Voltage
(Note 3)
VSD
VGS=0V,IS=-1A
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
Page 2
GOFORD
G3035-23
Typical Electrical and Thermal Characteristics
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
PD Power(W)
ID- Drain Current (A)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(mΩ)
Figure 3 Power Dissipation
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
Figure 6 Drain-Source On-Resistance
Page 3
GOFORD
Normalized On-Resistance
G3035-23
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Figure 11 Gate Charge
Vsd Source-Drain Voltage (V)
Figure 12 Source- Drain Diode Forward
Page 4
GOFORD
G3035-23
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
Page 5
很抱歉,暂时无法提供与“G3035”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30143
- 100+0.23922
- 300+0.20812
- 3000+0.16859
- 6000+0.14991
- 9000+0.14062
- 国内价格 香港价格
- 3000+0.657113000+0.08502
- 6000+0.592316000+0.07663
- 9000+0.559269000+0.07236
- 15000+0.5221015000+0.06755
- 21000+0.5000821000+0.06470
- 30000+0.4786730000+0.06193
- 国内价格 香港价格
- 1+3.084581+0.39908
- 10+1.9158510+0.24787
- 100+1.19776100+0.15497
- 500+0.88635500+0.11468
- 1000+0.785571000+0.10164
