GOFORD
G6N02L
N-Channel Trench MOSFET
Description
The G6N02L uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
RDS(ON) (at VGS = 2.5V)
100% Avalanche Tested
RoHS Compliant
Schematic diagram
20V
6A
< 11.3mΩ
< 14.1mΩ
G6N02
Marking and pin assignment
Application
⚫ Power switch
⚫ DC/DC converters
SOT-23-3L
Device
Package
Marking
Packaging
G6N02L
SOT-23-3L
G6N02
3000pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
V
ID
6
A
IDM
24
A
Gate-Source Voltage
VGS
±12
V
Power Dissipation
PD
1.8
W
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJA
80
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Ambient
www.gofordsemi.com
TEL:0755-29961263
FAX:0755 -29961466
GOFORD
G6N02L
Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250µA
V
Zero Gate Voltage Drain Current
IDSS
VDS = 20V, VGS = 0V
1
μA
Gate-Source Leakage
IGSS
VGS = ±12V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
0.5
0.7
0.9
V
VGS = 4.5V, ID = 3A
10
11.3
Drain-Source On-Resistance
RDS(on)
VGS = 2.5V, ID = 3A
12
14.1
VDS=5V,ID=6A
50
1140
165
110
12.5
1.2
Forward Transconductance
mΩ
gFS
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
VGS = 0V,
VDS = 10V,
f = 1.0MHz
VDD = 4.5V,
ID = 6A,
VGS = 10V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
2.7
Turn-on Delay Time
td(on)
2.7
Turn-on Rise Time
tr
3
Turn-off Delay Time
td(off)
37
7
Turn-off Fall Time
VDD = 4.5V,
ID = 3A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
6
A
VSD
TJ = 25ºC, ISD = 1A, VGS = 0V
0.6
1
V
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
FAX:0755 -29961466
GOFORD
G6N02L
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
FAX:0755 -29961466
GOFORD
G6N02L
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
ID, Drain Current (A)
15
VDS = 5V
10
TJ = 125ºC
5
TJ = 25ºC
VDS, Drain-to-Source Voltage (V)
VGS = 2.5V
10
VGS = 4.5V
5
2
4
6
8
1.5
2
Figure 4. Gate Charge
Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
25
VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
15
0.5
5
VDS = 10V
ID=6A
4
3
2
1
ID-Drain Current(A)
2
4
6
8
10
Qg Gate Charge(nC)
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
Is, Reverse Drain Current (A)
Figure 5. Capacitance vs Vds
Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
FAX:0755 -29961466
GOFORD
G6N02L
Figure 8. Safe Operation Area
Figure 7. Drain-Source On-Resistance
1.4
ID, Drain Current(A)
RDS(on), (Normalized)
1.6
VGS =4.5V
ID=6A
1.2
1
0.8
50
75
100
125
150
175
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
FAX:0755 -29961466
GOFORD
G6N02L
SOT-23-3L Package Information
Dimensions in Millimeters
Symbol
MIN.
NOM.
MAX.
A
2.80
2.90
3.00
B
1.50
1.60
1.70
C
1.00
1.10
1.20
D
0.30
0.40
0.50
E
0.25
0.40
0.55
G
1.90
H
0.00
0.10
J
0.047
0.127
0.207
K
2.60
2.80
3.00
All Dimensions in mm
www.gofordsemi.com
TEL:0755-29961263
FAX:0755 -29961466
很抱歉,暂时无法提供与“G6N02L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.970631+0.51609
- 10+2.4101310+0.31326
- 50+1.7406850+0.22625
- 100+1.52176100+0.19779
- 500+1.13494500+0.14752
- 国内价格 香港价格
- 3000+0.850273000+0.11052
- 9000+0.728889000+0.09474
