GOFORD
G33N03D3
N-Channel Trench MOSFET
Description
D1
The G33N03D3 uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
G2
G1
S1
General Features
D2
S2
Schematic diagram
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
30V
30A
< 13mΩ
< 18mΩ
⚫ 100% Avalanche Tested
⚫ RoHS Compliant
Marking and pin assignment
Application
⚫ Power switch
⚫ DC/DC converters
DFN3.3X3.3-8L
Device
Package
Marking
Packaging
G33N03D3
DFN3.3X3.3-8L
G33N03
5000pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
30
V
ID
30
A
IDM
85
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
18.5
W
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJC
6.7
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Case
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466 (A1401)
GOFORD
G33N03D3
Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250µA
30
V
Zero Gate Voltage Drain Current
IDSS
VDS = 30V, VGS = 0V
1
μA
Gate-Source Leakage
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.5
2.5
V
VGS = 10V, ID = 16A
9
13
Drain-Source On-Resistance
RDS(on)
VGS = 4.5V, ID = 14A
14.5
18
1530
250
200
15
3
mΩ
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
VGS = 0V,
VDS = 15V,
f = 1.0MHz
VDD = 15V,
ID = 9A,
VGS = 10V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
4.5
Turn-on Delay Time
td(on)
10
Turn-on Rise Time
tr
8
Turn-off Delay Time
td(off)
30
5
Turn-off Fall Time
VDD = 15V,
ID = 10A,
RG = 1.8Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
30
A
VSD
TJ = 25ºC, ISD = 16A, VGS = 0V
1.2
V
22
35
ns
12
nc
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
TJ = 25°C, IF = 10A
di/dt = 100A/μs
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical R G
www.gofordsemi.com
TEL:0755-29961263
GOFORD
G33N03D3
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GOFORD
G33N03D3
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 2. Transfer Characteristics
ID, Drain Current (A)
Figure 1. Output Characteristics
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
Figure 4. Drain Source On Resistance
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
Figure 3. Gate Charge
Qg Gate Charge(nC)
VGS=4.5V
VGS=10V
ID-Drain Current(A)
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
Is, Reverse Drain Current (A)
Figure 5. Capacitance
Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GOFORD
G33N03D3
Figure 8. Safe Operation Area
VGS = 10V
ID = 16A
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GOFORD
G33N03D3
DFN3.3*3.3 Package Information
DFN3.3X.3.3-8L.
Dim
Mim
Max
A
2.90
3.10
B
2.90
3.10
C
0.65
0.85
D
0.20
0.40
E
0.00
0.10
F
0.00
0.10
G
0.55
0.75
K
3.15
3.15
A l l Di m e n s i o n s i n mm
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G33N03D3”相匹配的价格&库存,您可以联系我们找货
