G08P06D3
G08P06D3
    GOFORD(谷峰)
    DFN-8(3x3)
    1个P沟道 耐压:60V 电流:8A
G08P06D3 数据手册
GOFORD G08P06D3 P-Channel Trench MOSFET Description The G08P06D3 uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features ⚫ ⚫ ⚫ ⚫ VDS ID (at VGS = -10V) RDS(ON) (at VGS = -10V) 100% Avalanche Tested Schematic diagram -60V -8A < 52mΩ ⚫ RoHS Compliant Application ⚫ Power switch ⚫ DC/DC converters Marking and pin assignment DFN3X3-8L Device Package Marking Packaging G08P06D3 DFN3X3-8L G08P06 5000pcs/Reel Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS -60 V ID -8 A IDM -32 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 40 W TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Case RthJC 3.13 ºC/W Thermal Resistance, Junction-to-Ambient RthJA 22 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1470) GOFORD G08P06D3 Specifications TJ = 25ºC, unless otherwise noted Value Parameter Symbol Test Conditions Unit Min. Typ. Max. Static Parameters Drain-Source Breakdown Voltage V(BR)DSS VGS = 0V, ID = -250µA -60 -- -- V Zero Gate Voltage Drain Current IDSS VDS = -60V, VGS = 0V -- -- -1 uA Gate-Source Leakage IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = -250µA -2 -2.8 -3.5 V Drain-Source On-Resistance RDS(on) VGS = -10V, ID = -6A -- 42 52 mΩ -- 2972 -- -- 110 -- -- 101 -- -- 25 -- -- 4 -- Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg VGS = 0V, VDS = -30V, f = 1.0MHz VDD = -30V, ID = -5A, VGS = -10V Gate-Source Charge Qgs Gate-Drain Charge Qgd -- 7 -- Turn-on Delay Time td(on) -- 15 -- Turn-on Rise Time tr -- 58 -- Turn-off Delay Time td(off) -- 30 -- -- 36 -- Turn-off Fall Time VDD = -30V, ID = -5A, RG = 6Ω pF nC ns tf Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- -8 A Body Diode Voltage VSD TJ = 25ºC, ISD = -5A, VGS = 0V -- -- -1.2 V Reverse Recovery Time Trr -- 20 -- ns Recerse Recovery Charge Qrr -- 19 -- nC IS = -5A, VGS = 0V di/dt=-100A/us Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. Identical low side and high side switch with identical R G www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1470) GOFORD G08P06D3 Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1470) GOFORD G08P06D3 Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 2. Transfer Characteristics -ID, Drain Current (A) -ID, Drain Current (A) Figure 1. Output Characteristics -VDS, Drain-to-Source Voltage (V) -VGS, Gate-to-Source Voltage (V) Figure 4. Gate Charge -Vgs Gate-Source Voltage(V) RDS(on), On-Resistance (mΩ) Figure 3. Drain Source On Resistance VGS = -10V - ID-Drain Current(A) Qg Gate Charge(nC) Ciss Capacitance(pF) Figure 6. Source-Drain Diode Forward -Is, Reverse Drain Current (A) Figure 5. Capacitance vs Vds Coss Crss -Vds Drain-Source Voltage(V) www.gofordsemi.com VDD = -30V ID=-5A TEL:0755-29961263 -VSD, Source-to-Drain Voltage (V) FAX:0755-29961466 (A1470) GOFORD G08P06D3 Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8. Safe Operation Area ID=-6A VGS=-10V -ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance ZthJC, Thermal Impedance (ºC/W) TJ, Junction Temperature (ºC) -VDS, Drain-Source Voltage(V) Figure 9. Normalized Maximum Transient Thermal Impedance Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1470) GOFORD G08P06D3 DFN3X3-8L Package information D1 A D2 E3 θ E5 t E2 E1 E E4 b K L e c L1 D A1 COMMON MM SYMBOL A A1 b c D D1 D2 E E1 E2 E3 E4 E5 e K L L1 t θ www.gofordsemi.com MIN NO M MAX 0.70 0.20 0.10 3.15 3.00 2.29 3.15 2.90 1.54 0.28 0.37 0.10 0.60 0.59 0.30 0.06 0 10° 0.75 0.30 0.152 3.30 3.15 2.45 3.30 3.05 1.74 0.48 0.57 0.20 0.65 0.69 0.40 0.125 0.075 12° 0.85 0.05 0.40 0.25 3.45 3.25 2.65 3.45 3.20 1.94 0.65 0.77 0.30 0.70 0.89 0.50 0.20 0.13 14° TEL:0755-29961263 FAX:0755-29961466 (A1470)
G08P06D3 价格&库存
很抱歉,暂时无法提供与“G08P06D3”相匹配的价格&库存,您可以联系我们找货
